ERP Audit Trail audit by FDA? Regular audit trail report template?
v9991
#11
I wonder if someone can give me hints for how an "audit trail report" of an ERP (Electronic Resource Planning) system should look like to fulfill the requirements of FDA Quality System audits of medical device manufacturers? /QUOTE]
this has been outlined in the recently published Q&A on
Data Integrity and Compliance With Drug CGMP Questions and Answers Guidance for Industry
I am wondering which regulatory requirement spawns the need for a regular audit trail report? My memory (and cursory re-examination) of 21CFR Part 11 doesn't show that to be the case.
While awaiting your response on the source../QUOTE]
logically :- one would review the physical document in its entirety before clearing/approval. and audit trail of an record represents 'entirity'.
in certain (re)presentations, this has been traced to various responsibilities of quality unit or QC unit.
its long list....appended at end of post...here's ref/links.
Pharmaceutical Quality Control Labs (7/93) :- GUIDE TO INSPECTIONS OF PHARMACEUTICAL QUALITY CONTROL LABORATORIES
PART 211CURRENT GOOD MANUFACTURING PRACTICE FOR FINISHED PHARMACEUTICALS
in audit interactions, further scenario of especially for hybrid systems; the electronic data is not only limited to e-systems;
for example, the PLC has an recipe or set points or record/storage of data, however the organization relies on manual entries in the physical/e-records ==> in such instances it is recommended to review the PLC-data along with the physical records.
We expect raw laboratory data to be maintained in bound, (not loose or scrap sheets of paper), books or on analytical sheets for which there is accountability, such as prenumbered sheets. For most of those manufacturers which had duplicate sets of records or "raw data", non-numbered loose sheets of paper were employed. Some companies use discs or tapes as raw data and for the storage of data. Such systems have also been accepted provided they have been defined (with raw data identified) and validated.
Carefully examine and evaluate laboratory logs, worksheets and other records containing the raw data such as weighings, dilutions, the condition of instruments, and calculations. Note whether raw data are missing, if records have been rewritten, or if correction fluid has been used to conceal errors. Results should not be changed without explanation. Cross reference the data that has been corrected to authenticate it. Products cannot be "tested into compliance" by arbitrarily labeling out-of-specification lab results as "laboratory errors" without an investigation resulting in scientifically valid criteria.
Test results should not have been transcribed without retention of the original records, nor should test results be recorded selectively. For example, investigations have uncovered the use of loose sheets of paper with subsequent selective transcriptions of good data to analyst worksheets and/or workbooks. Absorbance values and calculations have even been found on desk calendars.
Cut charts with injections missing, deletion of files in direct data entry systems, indirect data entry without verification, and changes to computerized programs to override program features should be carefully examined. These practices raise questions about the overall quality of data.
The firm should have a written explanation when injections, particularly from a series are missing from the official work-sheets or from files and are included among the raw data. Multiple injections recorded should be in consecutive files with consecutive injection times recorded. Expect to see written justification for the deletion of all files.
Determine the adequacy of the firm's procedures to ensure that all valid laboratory data are considered by the firm in their determination of acceptability of components, in-process, finished product, and retained stability samples. Laboratory logs and documents when cross referenced may show that data has been discarded by company officials who decided to release the product without a satisfactory explanation of the results showing the product fails to meet the specifications. Evaluate the justification for disregarding test results that show the product failed to meet specifications.
7. Who should review audit trails? Audit trail review is similar to assessing cross-outs on paper when reviewing data. Personnel responsible for record review under CGMP should review the audit trails that capture changes to data associated with the record as they review the rest of the record (e.g., §§ 211.22(a), 211.101(c) and (d), 211.103, 211.182, 211.186(a), 211.192, 211.194(a)(8), and 212.20(d)). For example, all production and control records, which includes audit trails, must be reviewed and approved by the quality unit (§ 211.192). The regulations provide flexibility to have some activities reviewed by a person directly supervising or checking information (e.g., § 211.188). FDA recommends a quality system approach to implementing oversight and review of CGMP records. 12
M Go Live With New ERP System before Recertification Audit General Auditing Discussions 6
M ERP / QMS related software standards for Validation IEC 62304 - Medical Device Software Life Cycle Processes 6
B Oracle Cloud ERP Validation during Quarterly Patch ISO 13485:2016 - Medical Device Quality Management Systems 1
qualprod Assign a name to a home-made ERP system? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
N ERP Software Implementation Manufacturing and Related Processes 3
K ERP System Software Validation - ISO13485 2016 4.1.6 Design and Development of Products and Processes 8
Q Software SOP - Use and maintenance of an ERP system Software Quality Assurance 6
qualprod What is the Normal Flow in an ERP for Manufacturing? Manufacturing and Related Processes 0
K Identification and Traceability with an ERP system - Barcode Labels? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
L Off the Shelf Software VISUAL ERP system ISO 13485:2016 - Medical Device Quality Management Systems 1
S Where to keep Enterprise Resource Planning software (ERP) Validation Records ISO 13485:2016 - Medical Device Quality Management Systems 1
J PMA Device - Lot # change in New ERP Software - What are the FDA Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
D eQMS/ERP System Admin Work Instructions - Where do they fit? Misc. Quality Assurance and Business Systems Related Topics 5
S Small Business ERP System - Recommendations wanted Manufacturing and Related Processes 5
S ERP Software and Quality Department Procedures Integration Misc. Quality Assurance and Business Systems Related Topics 4
J ERP Systems and Your Pain Coffee Break and Water Cooler Discussions 5
pbojsen ERP Data Control Requirements ISO 13485:2016 - Medical Device Quality Management Systems 4
G Paper Based Manufacturing with an Unvalidated ERP ISO 13485:2016 - Medical Device Quality Management Systems 3
A Lean and ERP software Lean in Manufacturing and Service Industries 0
W QMS and/or ERP software choices for both US and China Quality Assurance and Compliance Software Tools and Solutions 2
R Document Control when an ERP System Produces most Forms and other Paperwork Document Control Systems, Procedures, Forms and Templates 7
L Managing ITP with an ERP system Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
C New ERP System: Any Free Gantt Chart Software Recommendations Out There Quality Assurance and Compliance Software Tools and Solutions 2
A Which ERP system complies to medical device regulations? ISO 13485:2016 - Medical Device Quality Management Systems 4
D AS9100C 4.2.3 - Obsolete Electronic ERP Documents AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
R ISO 13485 - Security and Control of ERP System ISO 13485:2016 - Medical Device Quality Management Systems 1
K Validation of ERP/CRM Software Using Sandbox Qualification and Validation (including 21 CFR Part 11) 4
S Configuration Management System software that can also be linked to our ERP system AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
I ERP Software Validation - required or not? ISO 13485:2016 - Medical Device Quality Management Systems 3
I ERP acronym has double meaning in our company Internal Auditing 6
B Using Job Shop ERP Software for a QMS Quality Assurance and Compliance Software Tools and Solutions 2
Stijloor ERP (Enterprise Resource Planning) Manufacturing Software Recommendations Manufacturing and Related Processes 3
P ERP (Emergency Response Plan) for Small Air Operator EASA and JAA Aviation Standards and Requirements 7
T Document Control of ERP Report Format from Software Document Control Systems, Procedures, Forms and Templates 13
smryan M2M (Made2Manage ERP System) newby questions Document Control Systems, Procedures, Forms and Templates 2
I MRP/ERP for small CM/EMS Manufacturing and Related Processes 3
M Is ERP (Enterprise Resource Plannning) software like SAP in scope of AS9100 7.5.1.3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C Setting Up Part Masters in ERP Systems - How are others doing it? Document Control Systems, Procedures, Forms and Templates 1
K Any one with experience on 'EPICOR' ERP System? Quality Assurance and Compliance Software Tools and Solutions 14
N Work Instructions for ERP (Enterprise Resource Planning) software Process Maps, Process Mapping and Turtle Diagrams 3
A Naming Convention for our ERP System Purchase Parts Document Control Systems, Procedures, Forms and Templates 4
W Validation of SAP for ERP - Inventory, shipping, and monitoring expiration dates Qualification and Validation (including 21 CFR Part 11) 18
I New ERP system - Need Doc. Numbers for ERP generated PO's, Packing Slips, etc? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T Utilization of new ERP system - (IFS- Industrial and Financial Systems) Quality Assurance and Compliance Software Tools and Solutions 8
M NetSuite ERP and CRM features Validation for a medical device company ISO 13485:2016 - Medical Device Quality Management Systems 4
K Part Naming Convention for SAP ERP Application Document Control Systems, Procedures, Forms and Templates 4
T Any Input on new ERP package? Service Industry Specific Topics 1
A New ERP system Validation ISO 13485:2016 - Medical Device Quality Management Systems 7
P Global Shop Software ERP management system questions Quality Assurance and Compliance Software Tools and Solutions 5
DanteCaspian ERP Systems: Monitoring, Inventory and Lean Lean in Manufacturing and Service Industries 7
