Error proofing ideas sheet metal punches
Hello all! New here though been searching your site for years.
Great site.
I have searched with little luck trying to get ideas on error proofing (poke yoke) metal cnc punches. Have had some issues with operators loading in parts backwards.
We use amada punches.
Thanks all
Two common approaches that take advantage of asymmetries in the part would include:
  • Inclusion of a physical obstacle in the holding fixture that will obviously prevent the part from laying flat unless it has been correctly oriented. A sensor can be added to prevent the machine from cycling if the part does not lay flat.
  • Inclusion of a sensor in the holding fixture that looks for the presence or absence of a feature to determine if the part is correctly oriented. Again, the sensor can prevent the machine from cycling if the conditions are not correct.
Ninja
Looking for Reality
In addition...have you looked at WHY this is happening?
How can the part be stored/delivered to the punch machine in an orientation that makes the right way the easiest to do?
If you have a stack of plates waiting for punching...error proof the queue fixture as well, so the part is already in the correct position even while waiting its turn.
Golfman25
Ah. The beauty of hard tooling. :) Turn it into a hard tool in which the part will only fit the proper way.
Your other option is what miner and andy said. You need some type of nest to hold the part properly. Good luck.
Thanks all for the great suggestions.
I come from a cnc machining background where it is easy to error proof fixtures. These punch sheet metal cnc are not as easy I'm finding out since it's harder to put locater pins and such on and this is a job shop (not long running) still some great ideas
Understood - so, bring you folks together and do some structured problem solving! They will figure it out and "own" the solution...
C Need help error proofing valve. All ideas welcome. Human Factors and Ergonomics in Engineering 31
J Error Proofing sensors in PFMEA FMEA and Control Plans 2
P IATF 16949 requirement - error-proofing in control plan IATF 16949 - Automotive Quality Systems Standard 3
R Error Proofing Label process Manufacturing and Related Processes 4
K Documented problem solving and documented error-proofing - IATF 16949 10.2.3 & 10.2.4 Internal Auditing 7
P IATF 16949 Clause 10.2.4 - Error Proofing IATF 16949 - Automotive Quality Systems Standard 33
optomist1 Error Mistake Proofing Color Parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
M Are 'Error Proofing Methods' required to be mentioned in Control Plans? FMEA and Control Plans 7
C List Error Proofing in the Process FMEA or the Control Plan FMEA and Control Plans 2
T Error Proofing / Poka-Yoke Textbook by Productivity Inc Book, Video, Blog and Web Site Reviews and Recommendations 7
S Manufacturing Error-proofing Packers mixing up which 4 Mats go together in a Kit Manufacturing and Related Processes 3
M Machine Feature: Is it possible to consider it Error Proofing? FMEA and Control Plans 6
D Error Proofing Workstation FOD (Foreign Objects and Debris) Problem Solving, Root Cause Fault and Failure Analysis 7
E Error Proofing to prevent Length Short - CNC Turning Process Manufacturing and Related Processes 4
M Error Proofing Packing Process Problem Solving, Root Cause Fault and Failure Analysis 11
AnaMariaVR2 Healthcare Focused Error Proofing Hospitals, Clinics & other Health Care Providers 3
M Label Error Proofing - Mislabeled parts in a small automotive company Manufacturing and Related Processes 25
Q Error Proofing Verification - Layered Audit Question Process Audits and Layered Process Audits 17
S Definition Error Proofing vs. Mistake Proofing - Differences? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 11
C Are Error Proofing Statistics Correct Nonconformance and Corrective Action 20
N Error-proofing tools/methods to suggest? TS16949 Clause 8.5.2.2 IATF 16949 - Automotive Quality Systems Standard 2
D Definition Error-Proofing vs. Mistake-Proofing - Differences Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 5
C What is Error-Proofing Methods? TS 16949 Clause 7.3.2.2 IATF 16949 - Automotive Quality Systems Standard 3
M Metal forming - Brake presses - Need error-proofing advice Manufacturing and Related Processes 8
B Definition Error Proofing vs. Programmable Logic Controls (PLCs) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 1
L Seeking examples - Error-Proofing Methodology - Used with regard to corrective action IATF 16949 - Automotive Quality Systems Standard 10
Marc Error Proofing - Brief Powerpoint .ppt files General Information Resources 0
K Compliance of Control Plans to Annex A - Addressing Error Proofing FMEA and Control Plans 13
S TS 16949:2002 - Error Proofing Column Required in Control Plan II FMEA and Control Plans 22
A Error Proofing In Every Corrective Action? QS-9000 - American Automotive Manufacturers Standard 2
D Seeking Information on Poka Yoke - Error Proofing Nonconformance and Corrective Action 3
Lee Taylor Indentifying human error as a root cause Human Factors and Ergonomics in Engineering 33
Ed Panek How to address a QMS Entry Error ISO 13485:2016 - Medical Device Quality Management Systems 8
Melissa CAR is not good enough! Operator Error! ISO 13485:2016 - Medical Device Quality Management Systems 39
D Use Error Risk Controls and Control Verification ISO 14971 - Medical Device Risk Management 6
H California Instrument AC Load - 222 Error Message Manufacturing and Related Processes 0
O Problem in Minitab - ERROR * Factor Voltage is highly correlated with other terms Using Minitab Software 10
bobdoering Informational Ndc Calculation Error Caution Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
I IMDS Error Message Question RoHS, REACH, ELV, IMDS and Restricted Substances 1
R Clinical accuracy and repeatability of IR(infrared) thermometer, no maximum error criteria is recommended in ISO Other Medical Device Related Standards 11
F No reproducibility Error in Gage R&R? Reliability Analysis - Predictions, Testing and Standards 4
M Error trying to Start a New Thread Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 2
M Trouble with Europa website - Internal Server Error (March 2019) EU Medical Device Regulations 5
Marc Definition MPEE - Maximum Permissible Error for Length Measurement Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
S Need help wrapping my head around confidence vs beta error Statistical Analysis Tools, Techniques and SPC 2
G How to include machine error in uncertainty calculations? Measurement Uncertainty (MU) 5
R Rank Deficiency Error Minitab Using Minitab Software 7
