Error Proofing Verification - Layered Audit Question
BradM
#11
Suppose you have a process where you push a pin in a hole to a depth of 1 inch. I was considering whatever mechanism controls the press depth (lvdt, encoder etc…) to be the error proofing device.
IMO, error proofing is performing A DMAIC or other type analyses to ascertain the applicable variables and controlling them. Above, there are multiple facets that would need to be identified to minimize/eliminate error. The mechanism to measure distance, depth, etc. would be one tool. The sharpness of the pin, temperature, density variations of the material, etc. would all come into play.
Does that sound close?
#12
This thread has taken an interesting 'twist'.
One of the challenges that automotive suppliers have is that we don't get to discuss terminology, 'correctness' of application etc. or other, deeper, philosophies. The customer wants error proofing to be done as part of LPA's and that means 'testing' the system with a reject part (or similar) to see if the equipment etc is capable of letting it go on, unchecked.
Helmut Jilling
Auditor / Consultant
#13
I agree. Let's not overthink this. Any device that protects the customers, or reduces the possibility of making bad parts, is a good thing. Go with it.
BradM
#14
Thank you Andy, very much. I have been rambling a bit in this thread, as I have been unclear what the intentions/ requirements are of the OP. NOTE: That is not meant negatively towards anyone, just means I have a lack of understanding on this particular application.
Andy (or others), please if you don't mind, elaborate on this process/application in the automotive industry.
Too, a bit about LPA would benefit me also
V
vanputten
#15
I am not over thinking anything. The differnece between error prevention (poka yoke, mistake proofing, error proofing) and escape controls (error detection) is not an advacned concept. It is a very important concept.
In all of the literature I have read, the main purpose of mistake proofing is to ensure no errors are made. If no errors are made, then there is no need to detect errors and stop them from escaping.
Advance Product Quality Planning put the emphasis on the process design to ensure quality output. Same thing for mistake proofing - the main prupose is to ensure quality output so the organization should not have to dedicate excess resources to inspection and escapes. Spend time and effort to prevent erros as opposed to spending time detecting them.
The Layerd Process Audit question should concentrate more on verifying that controls are in place to prevent errors and less emphasis on inspections to detect errors already made.
Regards,
Dirk
#16
I'll try to help....I've got some similar fixtures.
Let's say that your automatic fixture twists a potentiometer clockwise until it gets a signal from a multimeter that the voltage is in specification. Can you unplug the connection between the two? Can you put an insulator between your part and the measuring fixture so it never gets a signal? So you've got a pot twister and a meter, somewhere there must be a power supply to turn the part on. Can you turn off the power supply to your parts so they never turn on? What happens? Be creative.
We had an "error-proof" system that worked something like this...until we figured out that the power supply had failed and was running at 1/2 the set input and every pot was set wrong. We had to add a check of of the input voltage to the existing output check in our test software.
#17
No problem, Brad:
Simply put, a Layered Process Audit is a check of a workstation (or similar) in a manufacturing process (assembly, welding, etc) by various 'layers' of management from line supervision to the top manager of the facility, to watch the operator 'doing' the process. These are done at a frequency which ranges from per shift (supervisor) to weekly/monthly. A simple audit checklist ensures the same topics are covered each time plus any actionable items found, which are, in effect, escalated to top management each time they do an LPA.
An error proofing audit is a type of LPA but done by specific individuals (process technicians etc.) Typically it consists of running a known reject part down the process to 'trigger' any error proofing systems such as position detectors, vision systems, etc. Other systems rely on proximity detectors which can be 'fooled' and tested to see if the line still functions and will 'accept' defective parts.
The underlying reason for these 'audits' is to re-inforce operators 'following work instructions'............because some people think that's why we get poor product quality!
There are other threads here about LPA's (I don't know how to link them:eek: )
Helmut Jilling
#18
Regards,
Dirk
What I meant by overthinking was that the terms are used somewhat interchangeably, to the point where the differences are lost in context.
However, I trust we all agree there are different levels of execution, regardless of which term is applied.
The best approach is a system that prevents the error from even occuring. Sometimes that is not possible, or feasible. Many times, the best we can do is put automated inline sensors and inspection equipment to 100% check the output, without adding labor. This does not prevent the making of bad parts, but prevents them from passing.
Regardless of which term we assign to that, it still protects the customer, but is not as ideal as preventing it in the first place.
Either way, the customer receives benefit. The Layered Audits are supposed to verify these systems work.
P IATF 16949 requirement - error-proofing in control plan IATF 16949 - Automotive Quality Systems Standard 3
R Error Proofing Label process Manufacturing and Related Processes 4
D Error proofing ideas sheet metal punches Manufacturing and Related Processes 8
K Documented problem solving and documented error-proofing - IATF 16949 10.2.3 & 10.2.4 Internal Auditing 7
P IATF 16949 Clause 10.2.4 - Error Proofing IATF 16949 - Automotive Quality Systems Standard 25
optomist1 Error Mistake Proofing Color Parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
M Are 'Error Proofing Methods' required to be mentioned in Control Plans? FMEA and Control Plans 7
C List Error Proofing in the Process FMEA or the Control Plan FMEA and Control Plans 2
T Error Proofing / Poka-Yoke Textbook by Productivity Inc Book, Video, Blog and Web Site Reviews and Recommendations 7
S Manufacturing Error-proofing Packers mixing up which 4 Mats go together in a Kit Manufacturing and Related Processes 3
M Machine Feature: Is it possible to consider it Error Proofing? FMEA and Control Plans 6
D Error Proofing Workstation FOD (Foreign Objects and Debris) Problem Solving, Root Cause Fault and Failure Analysis 7
E Error Proofing to prevent Length Short - CNC Turning Process Manufacturing and Related Processes 4
M Error Proofing Packing Process Problem Solving, Root Cause Fault and Failure Analysis 11
AnaMariaVR2 Healthcare Focused Error Proofing Hospitals, Clinics & other Health Care Providers 3
M Label Error Proofing - Mislabeled parts in a small automotive company Manufacturing and Related Processes 25
C Need help error proofing valve. All ideas welcome. Human Factors and Ergonomics in Engineering 31
S Definition Error Proofing vs. Mistake Proofing - Differences? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 11
C Are Error Proofing Statistics Correct Nonconformance and Corrective Action 20
N Error-proofing tools/methods to suggest? TS16949 Clause 8.5.2.2 IATF 16949 - Automotive Quality Systems Standard 2
D Definition Error-Proofing vs. Mistake-Proofing - Differences Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 5
C What is Error-Proofing Methods? TS 16949 Clause 7.3.2.2 IATF 16949 - Automotive Quality Systems Standard 3
M Metal forming - Brake presses - Need error-proofing advice Manufacturing and Related Processes 8
B Definition Error Proofing vs. Programmable Logic Controls (PLCs) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 1
L Seeking examples - Error-Proofing Methodology - Used with regard to corrective action IATF 16949 - Automotive Quality Systems Standard 10
Marc Error Proofing - Brief Powerpoint .ppt files General Information Resources 0
K Compliance of Control Plans to Annex A - Addressing Error Proofing FMEA and Control Plans 13
S TS 16949:2002 - Error Proofing Column Required in Control Plan II FMEA and Control Plans 22
A Error Proofing In Every Corrective Action? QS-9000 - American Automotive Manufacturers Standard 2
D Seeking Information on Poka Yoke - Error Proofing Nonconformance and Corrective Action 3
R Clinical accuracy and repeatability of IR(infrared) thermometer, no maximum error criteria is recommended in ISO Other Medical Device Related Standards 11
F No reproducibility Error in Gage R&R? Reliability Analysis - Predictions, Testing and Standards 4
M Error trying to Start a New Thread Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 2
M Trouble with Europa website - Internal Server Error (March 2019) EU Medical Device Regulations 5
Marc Definition MPEE - Maximum Permissible Error for Length Measurement Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
S Need help wrapping my head around confidence vs beta error Statistical Analysis Tools, Techniques and SPC 2
G How to include machine error in uncertainty calculations? Measurement Uncertainty (MU) 5
R Rank Deficiency Error Minitab Using Minitab Software 7
W IMDS - Help (Common Warning and Error Fixes) RoHS, REACH, ELV, IMDS and Restricted Substances 9
M Methods of reducing/eliminating the systematic component of error General Measurement Device and Calibration Topics 0
chris1price Error in data recording - Recording measurements in SAP Capability, Accuracy and Stability - Processes, Machines, etc. 2
J Hardness inspection Audit Finding Employee error Nonconformance and Corrective Action 6
G ANAB ISO 17025 Accreditation - Uncertainty and systematic error? ISO 17025 related Discussions 6
shimonv IEC 60601-1-8 - When does an error message become an alarm signal? IEC 60601 - Medical Electrical Equipment Safety Standards Series 14
E Non Conformity due to Outsourced Internal Audit Error ISO 14001:2015 Specific Discussions 2
T Human Error vs Technique Root Cause (Categories) Human Factors and Ergonomics in Engineering 9
W Using MPE (Mean Percentage Error) for Linearity and Type-1 study Measurement Uncertainty (MU) 1
