I agree with Jennifer. The floor wax is secondary to the systems in place to mitigate ESD at the stations where the work is done. That is where most problems will occur.
If the floor wax is your primary (or only) ground, then I'm going to suggest that you should probably investigate a better system. If not, I wouldn't put too much energy into it, especially if it hasn't been a problem.
