ESD Protection in the Assembly Bay
  • Thread starter karthika subramaniam
  • Start date
K
Just checking some clarification point on how to ensure the ESD protection during integration testing in the assembly bay?
Can anyone please advise?
Thanks in advance!
Karthika.cs
DRAMMAN
You can't eliminate ESD, only manage it. There is a global ESD organization but I forget its name. It is a great place to start your ESD education. Another is the IPC organization. ESD management involves multiple levels with the most fundamental being grounding the employee with a wrist strap system. From there you can take many more actions....ESD work mats, grounded floor coatings, ESD shoes, ESD totes for material handling, grounding all mobile carts and vehicles, constant monitoring, ESD bags for parts/PCBA's, ESD air fans, hand lotions, gloves, training programs, audits, performance metrics, company certifications, etc, etc. To what extent you go depends on the products you make and impact of field failure. If you are coffe makers your ESD counter measures will usually not be as extensive as if you are producing aviation electronics.
Check you tube. There are alott of free trainings videos out there.
V
Vthouta
If these are followed strictly, ESD damage could be prevented. We have continuous monitoring at our ESD work stations, if someone doesn't pass the ESD, they are not allowed to work on the job until unless the system passes them. Foot straps and wrist straps must be used strictly and who ever sits they should be plugged in .This is one of the best practice.
Link: http://www.eis-inc.com/files/pdf/su...loads/3mesd/EOS_ESD_Management_Assessment.pdf
K
Thank you all!
In the soldering station, we have regular ESD practices in place (mats, wrist strap).
But at our test area where we integrate the boards with machine and perform tests and shop floor we don?t implement ESD because
- the plant is a "shop environment", not a "electronic environment" ;
- the product that is being tested is on (maybe not continuously but a specific amount of time).
- it is our understanding with ESD protection devices that there is a risk for electrical shock and could even be dangerous for technicians if they were wearing ESD protection (mat, wrist strap, etc.).
harrysons
Realistic Quality
Better you check with the facility or electrician guy for grounding of electrical connection, then you can ensure not only the ESD risk but even the electrical shock for your technician too. As you have mentioned for "Shop Environment" shall be categorized as the Test environment means the ESD control shall controlled properly.
the electrical grounding connection for your solder station must checked regularly.
DanteCaspian
Sounds like a strawman argument, if I understand you correctly. If you are building or working with components that are sensitive to electrostatic charge, then you need ESD controls to mitigate product failure..
- the product that is being tested is on (maybe not continuously but a specific amount of time). Static charge only needs a millisecond.
- it is our understanding with ESD protection devices that there is a risk for electrical shock and could even be dangerous for technicians if they were wearing ESD protection (mat, wrist strap, etc.)Not if you have your wiring properly set up! I have never heard of this being an issue or excuse.
DRAMMAN
ESD protection methods are not a risk for electrocution. Unless your ground is energized which would cause you much greater safety problems.
Anytime you are handling a circuit board you should have protections in place. The best ESD programs have multiple levels of protection. It all depends on what you make and balancing the ESD damage risks, impacts, and costs. When I was making mission critical electronics the entire factory (500K sqft) had an ESD floor, everyone issued ESD shoes, floor straps, wrist straps, air deionizers, smocks, ESD totes, grounded forklifts, constant monitoring, training, ESD engineers, etc, etc. My current employer would go broke doing all of this.
howste
Thaumaturge
If the device is inactive and ESD sensitive, ESD protection is very appropriate. If the device is being used or tested with a live current or with charged capacitors, ESD "protection" can be very dangerous. If you touch a live circuit while strapped up, YOU become the path for the current to ground.
Which is why there are 1 Meg ohm resistors in the wrist strap lead. And in the lead from the mat. And the mat's top surface is "static dissipative" whilst the under-surface is conductive.
Electric shock risk can be reduced by using "earth free zones". ESD protection measures can still be used within earth free zones. (Note this applies to "low voltages". High voltage / energy systems would need extra protection means).
L ESD Protection and Danger for Operators Manufacturing and Related Processes 3
K Employee ESD Protection Methodologies - Need input. Training - Internal, External, Online and Distance Learning 8
P Can anyone help with ESD Protection (PCBA)? How is ESD generated? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
D ESD cleanroom Manufacturing and Related Processes 4
A Metal Enclosure Connected to PCB Ground for ESD Reasons IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
A Preparing an ESD workstation Preventive Action and Continuous Improvement 6
F Does anyone have an ESD quality/cooler talk to share? Training - Internal, External, Online and Distance Learning 4
F ESD workbench "calibration" Manufacturing and Related Processes 2
Ed Panek Auditor driving us nuts - ESD requirements ISO 13485:2016 - Medical Device Quality Management Systems 23
M ESD (Electrostatic Discharge) Training Misc. Quality Assurance and Business Systems Related Topics 2
Q AS9120B - ESD monitoring devices part of 7.1.5 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
Q AS9120 Vendor of ESD Monitoring Equipment needs to be in the Approved Supplier List? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
R Laminate ESD Mats - Low resistance (RTT) readings Manufacturing and Related Processes 6
Tagin Recommendations for calibration labels for ESD floor mats General Measurement Device and Calibration Topics 9
I ESD - Dissipative foam on a seat for where the people sit at benches Manufacturing and Related Processes 6
C Looking for RED ESD Bags that preferably say NON-CONFORMING Manufacturing and Related Processes 5
N ESD and Humidity Monitoring in Work Areas Manufacturing and Related Processes 1
M ESD flooring - The difference between tile and epoxy floors Reliability Analysis - Predictions, Testing and Standards 3
B ESD Floor Wax on standard tile Manufacturing and Related Processes 5
W EMC, ESD for battery operated apparatus Other Medical Device and Orthopedic Related Topics 1
B Detachable Power Supply Cable Connection ESD Clarification IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
L ESD Label ... but in French Misc. Quality Assurance and Business Systems Related Topics 1
L Wearing an ESD Smock with Rolled Up Sleeves Misc. Quality Assurance and Business Systems Related Topics 4
L Calibration of ESD Wrist Strap Tester General Measurement Device and Calibration Topics 14
L ESD for Class 2 Wafer Fab products Manufacturing and Related Processes 2
I Device Can't Pass IEC 60601-2 ESD Requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
D ESD Policy Content Best Practices Manufacturing and Related Processes 8
R ESD issue with capacitive touch screen IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
D ESD Auditor - Qualifications Various Other Specifications, Standards, and related Requirements 2
L Drinking Water Bottle at an ESD Station Manufacturing and Related Processes 2
N IEC 60601-1-2 ESD: Lower Compliance Level for ESD Immunity IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
S Can I use a ESD cart on non-ESD flooring? Manufacturing and Related Processes 2
JoCam ESD Flooring vs. Concrete - Pros and Cons Manufacturing and Related Processes 2
S Differences between Conductive vs. Dissipative ESD Flooring Manufacturing and Related Processes 3
C ESD Bags and Paper Labels (Dymo) on the Bags (Packaging) Misc. Quality Assurance and Business Systems Related Topics 5
B How often do you clean your ESD mat? Manufacturing and Related Processes 4
J ESD and Soldering Training Supplier Recommendations Needed Training - Internal, External, Online and Distance Learning 7
P ESD and Bio-Hazards in a Medical Equipment Repair/Maintenance Facility Manufacturing and Related Processes 2
J Where to find info about equivalent standards? ESD issues Other ISO and International Standards and European Regulations 4
Q How to Inspect for ESD (Electro-Static Discharge) Damage Manufacturing and Related Processes 5
B ESD Mats on Workbenches and ESD Surface Resistivity Meter Readings Manufacturing and Related Processes 6
D ESD Quantification - Standalone instrument that can log ESD field strength ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S ESD Flooring Requirements - Seperate room for soldering process and assembly Manufacturing and Related Processes 5
S MIL-STD-1686 for ESD Compliance help wanted Various Other Specifications, Standards, and related Requirements 3
J NoiseKen ESD Simulators - Opinions on ESD simulator ESS-2002EX Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
A ESD Control Program (Flooring Requirement) Manufacturing and Related Processes 4
B Must chairs be grounded for ESD (electrostatic discharge)? Manufacturing and Related Processes 26
Z Packaging and shipping of multiple PWBA/PCBAs in one ESD protective bag Supplier Quality Assurance and other Supplier Issues 5
Q Validating ESD (Electrostatic Discharge) Flooring ISO 13485:2016 - Medical Device Quality Management Systems 2
