Establish a Documented Procedure (4.2.3) vs. Establish Process (7.6)
DAWELAH
Dear Friends,:)
What does the following mean
1- Establish a documented procedure ( as 4.2.3)
2- Establish Process ( 7.6)
Really I’m confused between Procedure and Process:bonk:
If I Prepare for an example “a documented procedure for Control of Documents “
And then divide this procedure to
- Purpose of Procedure
- Scope of Procedure
- Definition
- General ( gives some information related to procedure implementation )
- Related Procedure
- And then attached a flow chart, with given name “ Control of Document Process “
This process explain the step by step action needs to control mentioned Procedure ( Control of Document ) the Responsibilities and required documents are identified in the flowchart
What is your opinion? Is it work?:nope:
Please need your kind advice ?:nope:
:thanx:
Pancho
wikineer
It may be useful to refer to ISO 9000-2005, which defines these terms:
  • §3.4.1 process: set of interrelated or interacting activities which transforms inputs into outputs
  • §3.4.5 procedure: specified way to carry out an activity or a process
Back in ISO 9001-2008, §4.2.3 requires you to document the way in which you control your documents, and §7.6 requires you to have processes to control your monitoring and measuring equipment. In the first case, a single procedure may be sufficient to meet the requirement, and the standard demands it be documented. In the second case, the requirement may be met by having one or more of your processes incorporate the proper monitoring and measuring activities, and the standard demands only records documentation of the calibration and verification of your equipment.
- Definition
- Related Procedure
The format of the documented procedure is not as important as the content. From the definition cited above, the way in which you do document control is the substance of the procedure. Scope, Purpose, Definition, General, Related procedures, may be nice supplemental info, but the "step by step action" is what really matters. Feel free to post the substance of your procedure for some constructive criticism.
somashekar
Dear Friends,:)
- Definition
- Related Procedure
:thanx:
How transforms ?
By a procedure for each activity.
Is the procedure documented and controlled ?
Yes
Doumented procedure
DAWELAH
Thanks Pancho
Thanks Somashekar
I attached a draft
As you see, it is named “ Internal Quality Audit Procedure “ and the Internal Quality Audit Process ( Flowchart) is an appendixes of the procedure which is explain step by step activities with responsibilities and evidences documents .
is there any comments about the titles?
Is it fine ?
is it acceptable documentation?
somashekar
Thanks Pancho
Thanks Somashekar
I attached a draft
Is it fine ?
Just call it 'Internal Audit Procedure'
Opening / closing meeting, if required ? Who decides it ?
Why not drop them ?
NC classification, Why ? Who decides them ? What are the guidelines for it ?
Why not drop them ?
Pancho
wikineer
Thanks Pancho
Thanks Somashekar
I attached a draft
Is it fine ?
Looks good. I'd suggest that instead of giving instructions here about NC handling and CAs, you make reference to the corresponding dedicated procedures that you probably already have. Also, on format, I think that the substance of your procedure, the step by step instructions, shouldn't be relegated to an appendix.
DAWELAH
Thank you soooooooooooooooo much friends
Your comments are very useful ?
One more query :
the step by step activities ( the appendix ) has been identified as ( Internal Audit Process )
and the chapter name is ( Internal Audit Procedure )
Is there a problem with this ?
V
vanputten
I can't remember where I got this document or how to find the it now. I think this document is available somewhere on the ISo_Org website or the Technical Committee (TC) 176 website (http://www.tc176.org/).
The following text is from TC176's Guidance on Documentation document:
c) Documented procedures:
 ISO 9001:2008 specifically requires the organization to have “documented procedures” for the following six activities:
 4.2.3 Control of documents
 4.2.4 Control of records
 8.2.2 Internal audit
 8.3 Control of nonconforming product
 8.5.2 Corrective action
 8.5.3 Preventive action
 These documented procedures have to be controlled in accordance with the requirements of clause 4.2.3
 Some organizations may find it convenient to combine the procedure for several activities into a single documented procedure (for example, corrective action and preventive action). Others may choose to document a given activity by using more than one documented procedure (for example, internal audits). Both are acceptable.
 Some organizations (particularly larger organizations, or those with more complex processes) may require additional documented procedures (particularly those relating to product realization processes) to implement an effective QMS.
 Other organizations may require additional procedures, but the size and/or culture of the organization could enable these to be effectively implemented without necessarily being documented. However, in order to demonstrate compliance with ISO 9001:2008, the organization has to be able to provide objective evidence (not necessarily documented) that its QMS has been effectively implemented.
V
vanputten
Well, I just learned that one cannot post the same attachment twice throughout all of the Elsmar Cove which seems odd to me.
Anyway, if you want to see ISO/TC176's Guidance on Documentation, go the the thread called "What defines a Quality Record?"
T What does AS9100 mean when it says you must establish a process to do X? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
O How to establish Datum Planes with two cylinders? Various Other Specifications, Standards, and related Requirements 0
H How to Establish and Document Competence of Employees in a Small Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
shimonv 21 CFR 820.20(d) says: Each manufacturer shall establish a Quality Plan 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
K Historical Data to establish Control Limits Manufacturing and Related Processes 4
R Does "establish, implement and maintain a procedure" require a Document - OHSAS 18001 Occupational Health & Safety Management Standards 1
S How to establish a Sampling Plan from the Rework percentage? AQL - Acceptable Quality Level 6
T To establish ISO 9001:2008 in a ISO 17025 accredited Company ISO 17025 related Discussions 4
G Characterization Studies: Analyzing Data to Establish Conclusions Statistical Analysis Tools, Techniques and SPC 1
F FAA Letter of Need to establish Continuing Need Federal Aviation Administration (FAA) Standards and Requirements 1
B Airbus to establish assembly line in United States AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
G NADCAP - How do I establish if a process is covered? Manufacturing and Related Processes 3
Q How to Establish Microbiological Limits in Foods Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
R How to establish Quality Objectives per TS 16949 Clause 5.4.1 Requirements IATF 16949 - Automotive Quality Systems Standard 7
K How to establish critical limit for Critical Control Points (CCPs) Food Safety - ISO 22000, HACCP (21 CFR 120) 7
L Criteria to Establish a Relevant Due Date for Closing Corrective Actions Internal Auditing 8
Z How to Establish a Process in Terms of more Added Value? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Z Can we establish system documents with VIDEO or HUMAN? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T How to Establish Internal Quality Control Planning APQP and PPAP 4
T How to establish KPI Disposal and Follow Up Process Quality Tools, Improvement and Analysis 7
G Quality Policy Requirements - Establish and implement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C How should I establish Quality Systems in my small company Manufacturing and Related Processes 7
C The organisation shall Establish, Implement & Maintain a Procedure(s)? ISO 14001 ISO 14001:2015 Specific Discussions 21
C Do I have to establish a software validation procedure? Qualification and Validation (including 21 CFR Part 11) 11
C How to establish a Design History file (DHF)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
R Anyone know how to establish one piece flow in apparel industry? Lean in Manufacturing and Service Industries 9
M How to Establish criteria for acceptance of products ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Ajit Basrur FDA on path to establish offices in China US Food and Drug Administration (FDA) 0
H Is it possible to establish a new subforum for TL9000? TL 9000 Telecommunications Standard and QuEST 7
Z How to Establish Quality Manual Not Following the Structure of the Standard? Quality Management System (QMS) Manuals 3
Z How to Establish Quality Policy Based on Vision of Organization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
Q How can I Establish a New Medical Device Laboratory? ISO 13485:2016 - Medical Device Quality Management Systems 12
Z How to Establish a TS 16949 QMS in an ISO 9001 Registered Company? IATF 16949 - Automotive Quality Systems Standard 2
Z How to Establish Simple and Efficient Procedures and Operating Instructions Document Control Systems, Procedures, Forms and Templates 16
A Establish a New Quality System based on Lean - Starting A Late Career in Quality Lean in Manufacturing and Service Industries 7
R What statistical method to establish a specification? Statistical Analysis Tools, Techniques and SPC 16
T How to establish the 4M (Man Machine Method Material) change control Manufacturing and Related Processes 5
C How to establish an effective ISO/TS16949 System? IATF 16949 - Automotive Quality Systems Standard 2
A How to establish linkage between specs/control plan/FMEA/process flow? Document Control Systems, Procedures, Forms and Templates 10
Douglas E. Purdy Acceptability of Perishable Tooling - How do you establish the standards/requirements Various Other Specifications, Standards, and related Requirements 2
apestate Job Shop Inspection and Test - Where should we establish inspections? Why? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 22
Raffy Do we need to establish Quality Objectives per department? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Geoff Cotton Taguchi quality loss function - How do I establish the 'Consumer Loss' element? Quality Tools, Improvement and Analysis 6
Sidney Vianna Release of ISO 10013:2021, Quality management systems – Guidance for documented information Other ISO and International Standards and European Regulations 0
T Controlled Forms or documented requirements for records? ISO 13485:2016 - Medical Device Quality Management Systems 2
qualprod Documented actions and changes in the QMS by COVID 19 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
C Missing routers/documented information Nonconformance and Corrective Action 5
