Establishing Internal Audit Nonconformity Level Criteria - Major vs. Minor?
Sidney Vianna
Post Responsibly
#31
Re: Internal Audits - Establishing nonconformity level criteria - Major/Minor?
C.vanDijk said:
When something is prioritized, this usually means that something else is considered not to be as important and before you know it, things end up not being done.Cornelis.
My take is totally the opposite. Managing risks does require prioritization of resources. Some mistakes could have lethal consequences to customers, while others would be just a nuisance.
Management requires prioritization of resources.
If less critical issues don't get resolved, you have organizational discipline problems. But to consider all problems without some type of risk rating does not make any sense, imo.
C.vanDijk
#32
Thanks for your explanation on how you view minors or majors. I have never quite looked at it from that perspective.
We seem to have different views on the matter but I do see how you're making a point. We do have a system in place for risk rating and it is translated into the type of action that will be taken, the resources that are assigned and the due date attached to the action. So far, it's working really well.
I would still not be in favor of using the terms minor or major but that's a matter of personal oppinion, I guess.
Cornelis.
Rajeeva
Quality Manager, CMQ/OE, CQA
#33
RCBeyette said:
Welcome to the Cove, Rajeeva and congratulations on your first post! :bigwave:
When you state "documented requirement" are you referring to the standard or a requirement contained within a documented process?
Thanks! As we are discussing about the internal auditing, it is the requirement of documented procedures/ processes.
Rajeev
Rajeeva
#34
Laura M said:
I typically do not rank Internal Audit N/C's because I want them all addressed. I may in a cover letter indicate, if I believe appropriate 'a registrar may assess this to be a major n/c.'
I do agree Nonconformance is nonconformance and it must be addressed whether it is major or minor. But without categorizing it in to major or minor, how the auditor can agree/ decide the "proposed action completion date". He/ She must categorize the N/Cs' depending upon the seriousness or level of non-compliance detected and accordingly agree the action.
Internal quality auditing is a very valuable tool for the Management to know whether the system is implemented and maintained, and to know what extent the planned arrangements are suitable to achieve the desired results.
Thus the internal auditor must bear in his/her mind what kind of feedback is he/she giving to Management and with that objective, need to carry out audit to know how seriously documented requirements are understood and implemented.
So, when n/cs found and it is categorized into major or minor, it gives an indication to the auditee how serious is the issue. And accordingly, corrective actions could be discussed and implemented. Similarly, auditor can also categorize clubbing many minor non-conformances of similar issue into a major N/C.
In summary, unless n/cs are categorized, the n/cs do not get the attention they deserve.
Rajeev
stanislavd
#35
As I see, the nonconformities grading is useful and accepted by most of you. The main idea of this topic is "How to categorize them, based on what criterion?". Anyone with experience, please provide some examples.
Martijn
#36
If you really want to get into this in detail I suggest you do the IRCA lead auditor course, but here's the outline:
Question 1:
Is the finding inconsistent with customer agreements, legislation, ISO 9001:2000 standard, policy & goals, procedures, etc?
No --> not a finding to begin with
Don't know --> Finding is an observation, find more info
Yes --> Question 2:
Are the facts recorded (in other words can you prove the finding)?
No --> Finding is an observation, find more info
Yes --> Question 3:
Is the impact on customer satisfaction/product quality/system integrity:
Large? --> Major (for example Customer satisfaction: 7 customer complaints in the last 3 months on exactly the same topic and no proper actions taken, or system integrity: customer review meetings are never done, system is not implemented, or Product Quality: Proof of non functioning quality control resulting in bad products being sent to customer over a longer period of time)
Small? --> Minor (example same as above really, but not something consistent, but more an incident)
Hope this helps. This is always a bit subjective obviously, but if you use common sense and these rules it's not that hard to distinguish major from minor. Mostly a major starts with a feeling that something is really wrong :eek:
RoxaneB
#37
Rajeev
That's what I thought...so what do you do if a process is not documented? How do you audit the process? How do you classify/categorize findings? Or is the finding just that the process is not documented?
I apologize for my questions but I guess I no longer see merit in auditing solely against the documented procedure. I look at the overall process, the people involved, inputs and outputs, resource allocation and how the results of the process are treated (i.e., improvements, nonconfomances, corrective action, etc.).
Martijn
#38
:confused: I feel you answer your own question here.
As said in my previous post you can also write findings following from customer agreements, legislation, ISO 9001:2000 standard, policy & goals, etc. That's why for example auditor must now have sound knowledge of the ISO9001:2000, because if there's no procedure, you can still audit against the standard.
RoxaneB
#39
No worries...my questions were directed to Rajeeva and how his organization conducts internal audits.
Rajeeva
#40
I have seen your query and as well as Martin's reply. I agree that the audits should cover processes, inputs and outputs..... all you mentioned)
Well, when we say internal auditor we mean certified auditors (either internal or lead) which means they are aware of the ISO 9001:2000 requirements.
The main intention of carrying out internal quidts is to ensure that the planned arrangements (documented procedures/ processes) are implemented and maintained, and how effective is the arrangement. So, if any process/ procedure is not documented, and if you see it is implemented, then you must ask who approved the process and how they have communicated. Documented process/ procedure need not necessarily in paper; may be in electronic form.
You can not audit a process/ procedure which is not documented. How do you audit it for compliance or non-compliance. At least you need a documented flow-chart.
Suppose if you feel some of the requirements of ISO 9001:2000 are not implemented, definitely the auditor must bring it to the Management's notice.
Your comments are welcome
Rajeev
A Help establishing regulatory requirements - Plastic dental cartridge syringe US Food and Drug Administration (FDA) 0
K ISO 13485 section 5.3 Quality Policy - No framework for establishing and reviewing quality objectives ISO 13485:2016 - Medical Device Quality Management Systems 2
N Use part of high risk device for establishing low risk device EU Medical Device Regulations 0
J ISO 13485:2016 Section 6.2 - Documenting the process for establishing competence ISO 13485:2016 - Medical Device Quality Management Systems 6
M Establishing a FTQ (First Time Quality) process for an engine assembly line Quality Tools, Improvement and Analysis 1
R Establishing the quality policy for ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
N Establishing a monthly scrap cost target Lean in Manufacturing and Service Industries 11
T Establishing -F- datum - need advice Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
S Establishing a Gage R&R Studies Program in a Testing Laboratory Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M Establishing traceability from calibrated glassware to non calibrated ones General Measurement Device and Calibration Topics 5
O Establishing SPC for small batches of 10-15 units Statistical Analysis Tools, Techniques and SPC 10
M Establishing Metrics - Where do you document metrics? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
alonFAI Establishing a Receiving Inspection Procedure Document Control Systems, Procedures, Forms and Templates 5
optomist1 Establishing Sigma or Capabilty Indices for Automotive Safety Quality Tools, Improvement and Analysis 1
S Establishing an MSA Plan and Justification Suggestions wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M Establishing a QMS - What Daily/Weekly/Monthly activities in Auto Industry IATF 16949 - Automotive Quality Systems Standard 4
T Help establishing a good Customer Complaints Procedure? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
V Process Validation Guidance establishing the Integration with QbD - April 2012 Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
M Establishing Ranges for Weights for Calibration Verification of a Micro-Balance Calibration Frequency (Interval) 1
D Preparing for ISO 29001/API Q1- Establishing Control Features Oil and Gas Industry Standards and Regulations 3
D Establishing Key Process Characteristics (KPC's) Quality Tools, Improvement and Analysis 6
C New Quality Manager - Establishing Teams in different Business Units Quality Manager and Management Related Issues 4
H Noob Frequency Distribution and establishing achievable goals Using Minitab Software 2
K How to apply IEC 62366 and what shall be changed in establishing a Technical File ISO 13485:2016 - Medical Device Quality Management Systems 2
M Establishing monthly production targets with varying number of employees Lean in Manufacturing and Service Industries 6
A Why do I need batch size in establishing control plan to certain AQL?? AQL - Acceptable Quality Level 4
E Need help establishing a DMR (Device Master Record) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
K Basis for Establishing Gage Tolerancing - "Gage Maker's Tolerances" General Measurement Device and Calibration Topics 4
K Establishing the Environmental Aspects and Impacts for a Septic Tank Miscellaneous Environmental Standards and EMS Related Discussions 5
M Establishing simple procedure and work instruction using chart or photo or video Document Control Systems, Procedures, Forms and Templates 2
L Criteria for Establishing Control Plan Sample Size and Inspection Frequency FMEA and Control Plans 7
K Inventory Management - Establishing a procedure for Inventory Management Document Control Systems, Procedures, Forms and Templates 2
K Establishing Item Codes for Production Raw Materials Misc. Quality Assurance and Business Systems Related Topics 2
O Establishing the current value of KPI's (Key Performance Indicators) Manufacturing and Related Processes 1
Y Establishing and Measuring Individual Performance to Product Quality Standards Misc. Quality Assurance and Business Systems Related Topics 5
C Establishing alert and action limits for clean room bioburden Other Medical Device and Orthopedic Related Topics 9
E Establishing a biocompability test lab for testing EN 10993 series EU Medical Device Regulations 1
D Establishing and controlling process capability - Meaning of Phrases Capability, Accuracy and Stability - Processes, Machines, etc. 2
P Establishing Thickness Specifications from Measured Data Capability, Accuracy and Stability - Processes, Machines, etc. 11
A Initial condition for establishing significant environmental aspects Miscellaneous Environmental Standards and EMS Related Discussions 1
S Establishing Control of Regulations that concern my company Quality Manager and Management Related Issues 12
D Establishing New Training Procedure - Past Training of Existing Employees Training - Internal, External, Online and Distance Learning 6
J Establishing Proposal Metrics in a Factory Construction Company Quality Tools, Improvement and Analysis 6
A How to do Equipment Validation - Establishing our ISO 13485 QMS procedures Qualification and Validation (including 21 CFR Part 11) 28
B True Position without tertiary datum? Establishing a proper rotation Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
Coury Ferguson Interpretation of IAF Guide 62 - Establishing the Competence of the Auditors Registrars and Notified Bodies 11
H Establishing Employee Competencies and Training - Future Training Plan ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
P China - Establishing Quality Systems for Chinese Suppliers Supplier Quality Assurance and other Supplier Issues 8
Q Feedback System (8.2.1) - Requirements for "..establishing a documented procedure..." ISO 13485:2016 - Medical Device Quality Management Systems 5
Douglas E. Purdy Transition to ISO 9001:2000 - RFI - 009, RFI-003, & Establishing a QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
