Establishing SPC for small batches of 10-15 units
O
oleg_volf
Hello
I need sum suggestions to establishing SPC for small batches 10-15 units or start SPC for new part in the production?
For every part I have critical dimensions from engineering/
Oleg Volfson
CQE,CQM
Surehawk
Not sure I completely understand the question. Since making a SPC chart for a batch of 10-15 units seams unececesary.
There is a very argued method called pre-control that unlike SPC is supposed to work directly and not need 10-15 units, is it something like that you need?
http://www.symphonytech.com/articles/pdfs/precontrol.pdf
Anyway, if you are able to explain a little more what you need the SPC chart for I am sure there will be plenty of help.
O
oleg_volf
Thank you for your reply
I my previous post I offered to use a pre-control for the period of gathering enough data to build an imr or xbar charts/
After a reading a little more a understood that pre control is not very good control way/
because of that I asked if there is a similar chart for new process to prepare gathering data and perform spc on the critical dimensions/
Stevenli
I think this is a great topic, as Surehawk mentioned, you may use Pre-control chart, other than that there are some other chart you may use, e.g. Difference or Deviation from Nominal (DNOM) Xbar-R chart or Standardized Xbar-R chart or even Standardized Attributes Control Charts etc.
You can search "Short Run" under this SPC forum.
Hope it works
oleg_volf: patience friend. As the banner notice says this is a holiday weekend in the US and many are 'away' to celebrate.
In the meantime, if you have a process that will eventually yield many subgroups, a simle run chart against the spec limits may suffice for you.
I recommend reading some of Donald Wheeler's papers on SPC. they are free and he deals with many topics that you may encounter.
I would also recommend posting your data for a characteristic or two here and a description of the process, characteristic and measurement system so we can provide better advice. The best advice is usually specific to each example.
O
oleg_volf
Hello and thank you
I have a new part in production.
We made till know only 9 units and measured critical dimension.
See the data:
GazBock ?17.3-0.04
1) 17.284
2) 17.293
3) 17.296
4) 17.3
5) 17.3
6) 17.3
7) 17.287
8) 17.295
9) 17.279
I started to use pre control (attached)
In order to maintain the parts from been out of spec while I collecting the date for building the control limits for imr chart/
DNOM chart is not good for me because I paste hard copy on the machine and the worker marks each unit and monitors the trend and spec of the dimension/
I started to question myself after reading an article that pre control should not be used and because of this started this thread/'
bobdoering
Stop X-bar/R Madness!!
Before rubber stamping any SPC technique,you need to understand the type of variation you are expecting. What is the process you are trying to control, and what is the characteristic? Have you determined the characteristic you are trying to control is correct? If, for example, you are machining the dimension, none of the previously mentioned charts are likely to be correct.
O
oleg_volf
Hello
Yes The dimensions are machined.
How should I proceed if you say that all before are not correct
A Help establishing regulatory requirements - Plastic dental cartridge syringe US Food and Drug Administration (FDA) 0
K ISO 13485 section 5.3 Quality Policy - No framework for establishing and reviewing quality objectives ISO 13485:2016 - Medical Device Quality Management Systems 2
N Use part of high risk device for establishing low risk device EU Medical Device Regulations 0
J ISO 13485:2016 Section 6.2 - Documenting the process for establishing competence ISO 13485:2016 - Medical Device Quality Management Systems 6
M Establishing a FTQ (First Time Quality) process for an engine assembly line Quality Tools, Improvement and Analysis 1
R Establishing the quality policy for ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
N Establishing a monthly scrap cost target Lean in Manufacturing and Service Industries 11
T Establishing -F- datum - need advice Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
S Establishing a Gage R&R Studies Program in a Testing Laboratory Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M Establishing traceability from calibrated glassware to non calibrated ones General Measurement Device and Calibration Topics 5
M Establishing Metrics - Where do you document metrics? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
alonFAI Establishing a Receiving Inspection Procedure Document Control Systems, Procedures, Forms and Templates 5
optomist1 Establishing Sigma or Capabilty Indices for Automotive Safety Quality Tools, Improvement and Analysis 1
S Establishing an MSA Plan and Justification Suggestions wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M Establishing a QMS - What Daily/Weekly/Monthly activities in Auto Industry IATF 16949 - Automotive Quality Systems Standard 4
T Help establishing a good Customer Complaints Procedure? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
V Process Validation Guidance establishing the Integration with QbD - April 2012 Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
M Establishing Ranges for Weights for Calibration Verification of a Micro-Balance Calibration Frequency (Interval) 1
D Preparing for ISO 29001/API Q1- Establishing Control Features Oil and Gas Industry Standards and Regulations 3
D Establishing Key Process Characteristics (KPC's) Quality Tools, Improvement and Analysis 6
C New Quality Manager - Establishing Teams in different Business Units Quality Manager and Management Related Issues 4
H Noob Frequency Distribution and establishing achievable goals Using Minitab Software 2
K How to apply IEC 62366 and what shall be changed in establishing a Technical File ISO 13485:2016 - Medical Device Quality Management Systems 2
M Establishing monthly production targets with varying number of employees Lean in Manufacturing and Service Industries 6
A Why do I need batch size in establishing control plan to certain AQL?? AQL - Acceptable Quality Level 4
E Need help establishing a DMR (Device Master Record) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
K Basis for Establishing Gage Tolerancing - "Gage Maker's Tolerances" General Measurement Device and Calibration Topics 4
K Establishing the Environmental Aspects and Impacts for a Septic Tank Miscellaneous Environmental Standards and EMS Related Discussions 5
M Establishing simple procedure and work instruction using chart or photo or video Document Control Systems, Procedures, Forms and Templates 2
L Criteria for Establishing Control Plan Sample Size and Inspection Frequency FMEA and Control Plans 7
K Inventory Management - Establishing a procedure for Inventory Management Document Control Systems, Procedures, Forms and Templates 2
K Establishing Item Codes for Production Raw Materials Misc. Quality Assurance and Business Systems Related Topics 2
O Establishing the current value of KPI's (Key Performance Indicators) Manufacturing and Related Processes 1
Y Establishing and Measuring Individual Performance to Product Quality Standards Misc. Quality Assurance and Business Systems Related Topics 5
C Establishing alert and action limits for clean room bioburden Other Medical Device and Orthopedic Related Topics 9
E Establishing a biocompability test lab for testing EN 10993 series EU Medical Device Regulations 1
D Establishing and controlling process capability - Meaning of Phrases Capability, Accuracy and Stability - Processes, Machines, etc. 2
P Establishing Thickness Specifications from Measured Data Capability, Accuracy and Stability - Processes, Machines, etc. 11
A Initial condition for establishing significant environmental aspects Miscellaneous Environmental Standards and EMS Related Discussions 1
S Establishing Control of Regulations that concern my company Quality Manager and Management Related Issues 12
D Establishing New Training Procedure - Past Training of Existing Employees Training - Internal, External, Online and Distance Learning 6
J Establishing Proposal Metrics in a Factory Construction Company Quality Tools, Improvement and Analysis 6
A How to do Equipment Validation - Establishing our ISO 13485 QMS procedures Qualification and Validation (including 21 CFR Part 11) 28
B True Position without tertiary datum? Establishing a proper rotation Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
Coury Ferguson Interpretation of IAF Guide 62 - Establishing the Competence of the Auditors Registrars and Notified Bodies 11
S Establishing Internal Audit Nonconformity Level Criteria - Major vs. Minor? Internal Auditing 46
H Establishing Employee Competencies and Training - Future Training Plan ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
P China - Establishing Quality Systems for Chinese Suppliers Supplier Quality Assurance and other Supplier Issues 8
Q Feedback System (8.2.1) - Requirements for "..establishing a documented procedure..." ISO 13485:2016 - Medical Device Quality Management Systems 5
Douglas E. Purdy Transition to ISO 9001:2000 - RFI - 009, RFI-003, & Establishing a QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
