Etalon Dial Caliper Gage Information Needed
apestate
Hello forum
I am looking for information about an old Etalon 6" dial caliper gage pictured here:
I'm a new user so I can't post url. it is ebay item # 310044387914
I've already purchased the instrument and spoken with the seller, and it appears that he has more of these older, higher quality instruments. I might purchase more of them if I knew more about them.
It appears that it is authentic new packaging from Etalon, and that an instrument with an old logo was packaged in a case with a new logo near the time their trademark was changed.
Does anyone know when Etalon changed their logo from the old style badge to the new monochromatic horse?
Stijloor
Re: Etalon dial caliper age
Hello forum
Hello apestate,
Welcome to The Cove Forums! :bigwave: :bigwave:
Etalon is a (super high quality) brand from TESA in Switzerland.
Look at this catalog. You can send also an email to TESA to find out.
TESA USA
Brown & Sharpe Manufacturing & Co.
Measuring instruments and systems
250, Circuit Drive
North Kingstown,
RI 02852 USA
Tel. +1 401-886-2000 - Fax +1 401-886-2553
tesausa(at)us.bnsmc.com
Stijloor.
apestate
Re: Etalon dial caliper gage
Thanks for your reply Stijloor
I used to have one of these instruments that I purchased new from J&L. It had the modern Etalon big black horse logo on it.
The shop was undergoing some quality improvements and we sought to replace many cheap calipers that were in poor condition, so we bought and tried at least a dozen different brand calipers.
We settled with the Mitutoyo 505's made in Brazil for around $70 a piece. At first the accuracy of these Brazilian 505's was sub-par, but complete disassembly and careful reassembly yielded a highly accurate instrument. The new Brazilian 505's are very accurate. Mitutoyo's are easy to re-assemble if you know how.
However, we took apart the Etalon 6" dial caliper for comparison and had a wicked time of re-assembling the instrument. Actually, I took it apart and ended up with a basket case. I challenged my co-worker to re-assemble it and gifted it to him as a reward. He is an order of magnitude more meticulous and tireless than I.
The Etalon had a press fit assembly and much larger gears. It is fully rubied and of heavier construction. Very difficult to work on.
Of course this is getting a little esoteric, since a Mitutoyo 505 or Brown & Sharpe dial caliper is already as accurate as a caliper should ever need to be.
However, as an illustration, imagine you had to sort a bunch of class ZZ gage pins that someone left out of the index. These gage pins are sized by .001". A high quality dial caliper like the Brown & Sharpe or Mitutoyo could possibly give you an error up to .001", especially at different angles of rotation on the dial. I would see this commonly while using my calibration procedures.
The Etalon 6" dial caliper did not exhibit this inaccuracy. In fact, the Etalon would often indicate whether a gage pin was + or - tolerance class! This is superior to brand new Brown & Sharpe dial calipers, although I have seen brand new and custom-refitted Mitutoyo 505's that would allow you to sort gage pins by .001" without easily making an error.
Maybe I'll get my post count up to 5 so I can post my calibration procedure and repair procedures for discussion!
C Etalon gage block uncertainty General Measurement Device and Calibration Topics 8
G Uncertainty Budget Examples for Caliper, Micrometer and Dial Gauge Measurement Uncertainty (MU) 3
N Digital vs Dial Caliper Comparison Measurement Uncertainty (MU) 17
C ISO 9001:2008 Audit Major Finding - Dial Calipers not set to zero ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
N Procedure/calculation for determining the foot pressure of dial thickness gauge General Measurement Device and Calibration Topics 11
E How to perform Discrimination check for Dial Indicator? General Measurement Device and Calibration Topics 2
N Calibration Method of Dial Thermometer Gauges General Measurement Device and Calibration Topics 7
R Pressure Test Dial Gage Selection Quality Tools, Improvement and Analysis 1
S Interpreting the Calibration Report for my Dial Indicator General Measurement Device and Calibration Topics 3
D Calibration of a Dial Indicator only used to indicate 0 General Measurement Device and Calibration Topics 7
W Measuring the Dial Torque of Plastic Insulin Pen devices Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
F What are the Advantages of a Digital Caliper Compared with a Dial Caliper? General Measurement Device and Calibration Topics 8
G Dial Indicator Calibration Frequency - ASME/ANSI B89.1.10M-1987 Calibration Frequency (Interval) 4
J I'm looking for a Thin Drop Dial Indicator Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
U Dial Gages of all types in company flood - How to recover them General Measurement Device and Calibration Topics 6
M Looking for a copy or template of a In House Calibration Report for a Dial Indicator General Measurement Device and Calibration Topics 1
Q Mitutoyo USB Cables for Variables Data Collection using a Dial Snap Gage Statistical Analysis Tools, Techniques and SPC 2
A Dial Test Indicator Repair Procedure General Measurement Device and Calibration Topics 3
A Magnification for One Stage Dial Gauge Mechanism General Measurement Device and Calibration Topics 1
C Dial Bore Gage Contact Points leaving witness/burnish marks General Measurement Device and Calibration Topics 10
J Performing Internal Calibrations - Dial gauges, micrometers, height gauges, calipers General Measurement Device and Calibration Topics 8
1 Acceptance criteria and related standard for 1 micron Lever Type dial Indicator General Measurement Device and Calibration Topics 5
L Calibration of Dial Thickness Gauge - What reference standard need I follow? General Measurement Device and Calibration Topics 5
Z Dial Test Indicator Flaw General Measurement Device and Calibration Topics 7
A Dial Test Indicator Design & Operation when Approach Angle is Different General Measurement Device and Calibration Topics 5
S Digital Dial Indicator Recommendation General Measurement Device and Calibration Topics 4
N Basic MSA - A simple way to complete an MSA study on Dial Calipers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
Q Dial Indicator Verification Procedure - ANSI/ASME B89.1.10M-2001 General Measurement Device and Calibration Topics 13
D Calibration vs. Verification - Can we calibrate dial indicators in-house? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Validation of A Procedure for Calibrating Dial Calipers using Traceable Gauge Blocks General Measurement Device and Calibration Topics 6
C Verification vs. Calibration of Dial Weight Dynamometer General Measurement Device and Calibration Topics 4
L Best Caliper for Shop Use? Digital vs. Dial Caliper vs. Vernier-type General Measurement Device and Calibration Topics 53
J How to Calibrate a Digimatic Dial Indicator? General Measurement Device and Calibration Topics 5
D ANSI B89.1.10, AGD and Mil A-A-2348 Dial Indicator Standards Various Other Specifications, Standards, and related Requirements 2
T How to calibrate dial indicators, gauges and scales General Measurement Device and Calibration Topics 22
J Dial Caliper or Digital Caliper - Which is the best? General Measurement Device and Calibration Topics 27
I What is Gauge Capability? Dial Thickness Gage and Digital Vernier Calipers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 17
C Struggling to teach a co-worker how to read dial calipers, any advice? General Measurement Device and Calibration Topics 13
J Caliper repair procedure - I need a caliper repair procedure for dial calipers General Measurement Device and Calibration Topics 2
C What is the proper method for cleaning dial calipers? General Measurement Device and Calibration Topics 4
M Lever type dial gauge - Usage of a dimensional 'test indicator' for measurement General Measurement Device and Calibration Topics 10
apestate Calibrating .001" resolution Dial Calipers - Calibration and safeguarding procedure General Measurement Device and Calibration Topics 6
E What is the smallest graduation (resolution) available for a Dial Test Indicator? General Measurement Device and Calibration Topics 2
Q Calibration Wording for a Dial Indicator WI General Measurement Device and Calibration Topics 1
B How to Calibrate a Dial Indicator General Measurement Device and Calibration Topics 13
J Dial Calipers vs. Digital Calipers - Has anyone replaced all their dial indicators? General Measurement Device and Calibration Topics 5
P Dial Gauge (gage) Calibration Software Calibration and Metrology Software and Hardware 2
D Dial Indicator (Analogue) Calibration Work Instructions General Measurement Device and Calibration Topics 3
O Mitutoyo Digital Caliper to PC USB question General Measurement Device and Calibration Topics 2
