Ethernet port connections to meet 60601-1 and 60601-1-2
royal77
Hello everybody,
We are developing a medical product (biopsy equipment).
Can you please help me out in the following requirement.
We have a standard ethernet port which have integrated magnetics and integrated LEDs.
In order to meet the safety requirements (60601-1) and EMC requirements, where should we connect the ground pins of the ethernet connector? To signal ground or protective earth? If they should be connected to protective earth, how to manage creepage and clearance distances? We have connected the signal ground to protective earth through Y1 capacitor.
The power supply (24V DC) for the board would be obtained from a isolated DC-DC converter which have SELV outputs.
The connector we have used is Molex 48025-0002.
Any suggestion would be greatly appreciated.Thanks
JustinP
Hello Royal again :)
The same like the USB issue: There are network isolation devices available, that have been tested and certified according to DIN EN 60601-1 and DIN EN 60601-1-2. These devices have been certified by a notified body and they completely isolate the signal AND the protective ground from the rest of the network within the required creeping and air distances. I am not allowed to post any links because i am new in this forum, but i can send the source to you directly if you like.
Justin
Added by Ajit - the link provided by Justin is http: // www .baaske .net/ netzwerkisolation.html?&L=1 - LONG DEAD LINK
E Isolation requirements for USB/Ethernet IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
F SIP/SOP - Mains Power and Medical Device Ethernet Ports IEC 60601 - Medical Electrical Equipment Safety Standards Series 12
C Grounding of Ethernet Cable Shield IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
E Ethernet Isolation Transformer for Medical Grade PCB IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
P Ethernet switch with powerstrip for conference table After Work and Weekend Discussion Topics 0
A 60601-1-2 : Integrated Dry Electrodes = PATIENT COUPLED PORT? IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
E SIP/SOP requirements for USB port used for charging IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
P ISO 80369 and endoscope port/lumen Other ISO and International Standards and European Regulations 4
T Question: Do we consider 60601-1-2 (4th ed) EMC testing a mode for a diagnostic port? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
A Automated calibration of Digital Multimeter without communication port Calibration and Metrology Software and Hardware 2
somashekar Port city Visakhapatnam (Vizag) devastated in the cyclone Hudhud (INDIA) World News 6
M Diesel Generator Stack - Sample port guidelines required Miscellaneous Environmental Standards and EMS Related Discussions 2
F Heat and Moisture Oxygen Port Changes Classification 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
R Separation of Network Port from other Circuits including Patient Circuit IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
T Access to a particular Medical Device Electronic Communication Test Port IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
M What is a Quality Assurance Plan? Help with Content for a Sea Port QA Plan Misc. Quality Assurance and Business Systems Related Topics 8
Ajit Basrur CDSCO Guidelines for Port Officers on Imp and Export of Drugs & Cosmetics Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
A USB Port Isolation as per IEC60601-1 - Medical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
R USB Port (Signal I/O) Isolation as per IEC60601-1 - Medical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 40
Jen Kirley Have you tried recording vinyl to MP3s and or CDs? Turntable with USB port? After Work and Weekend Discussion Topics 22
R Portocal II S/W needs some kind of "terminator" to parallel port General Measurement Device and Calibration Topics 3
V Designing an integrated ISO 9000 - ISO 14000 System in a Big Marine Port Design and Development of Products and Processes 3
A 60601-1 : Integrated Dry ECG Electrodes = 2 Patient connections inside 1 applied part? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
O Cleaning API Rotary Shoulder Connections Working Mates exposed to Outside Weather General Measurement Device and Calibration Topics 1
A PFMEA and Control Plan Connections - TS 16949 Clause 7.3.3.2 FMEA and Control Plans 24
L Fitted Splined Connections following DIN 5480 - Inspection Problems Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
C Input and Output Connections on the back of my potential TV After Work and Weekend Discussion Topics 9
M Connections between PFMEA (Process FMEA) and the Control Plan. FMEA and Control Plans 20
Marc What are the current connections / protocols for HDTV connections? After Work and Weekend Discussion Topics 5
Ajit Basrur Internet connections snapped - The Taiwan earthquake Coffee Break and Water Cooler Discussions 5
RoxaneB Sarbanes-Oxley : Details requested on environmental connections Miscellaneous Environmental Standards and EMS Related Discussions 2
