ETO Sterilizer Validation (ISO 11135:2007)
Aqeel Abbas
#21
Thanks a lot for the detailed list. I appreciate if you can expand the following in some more details:
URS, VP/VMP,Validation Status Summary.
Can you also mention which tests are covered in IQ, OQ and PQ?
:thanks:
medwise
#22
URS: User Requirement Specification. This is a document in which you request your supplier or vendor about what you require for your sterilization process. For example that you require them to calibrate their temperature probes caliberated annually, that their PLC is validated etc.
VMP: This document is a document which contains the validation plan i.e what you validate, when you validate (validation schedule) and who validates it (personnel responsibilities).
We have done full cycle EtO validation in 2007 and since then we do half cycle validation every year to make sure our cycle is validated. You will only do full validation when there is a major change such as device material change, packaging change or introduction of a new device which can be worst than your worst case device or the weight/volume of the load has changed.
If your supplier is ISO 13485:2003 certified thast does not mean you won't validate them. According to clause 7.4 you are require to perform supplier qualification, avaluation and monitoring and also at the end of the day you are the manufacturer and releasing the product for sale so it is your responsibility to validate the process.
Hope this helps!
The Specialist
#23
:thanks:
URS: Identifies requirements for equipment based on process requirements;
Capacity
Operating Parameters/Requirements (specifications)
Regulatory Requirements
Documentation Requirements
Testing Requirements
Environmental Requirements
Power/Utility Requirements and/or Limits
Automation requirements
Monitoring/Alarm Requirements
SOP Requirements
Maintenance Requirements/Service & Support Requirements
(Not exhaustive – dependant on equipment and installation)
VP (Validation Plan): Laying down the requirements of validation and testing methods/documentation turn-over package, in accordance with risk and impact assessment (either included in VP or as separate document);
cGMP risk/Impact assessment
Identification of validation requirement
‘Matrix’ to show where critical elements shall be tested (e.g. IQ/OQ/PQ)
IQ (installation Qualification): Detail of equipment (in this instance) to determine suitability of equipment against pre-determined specifications (derived from URS) with regard its installation;
Equipment detail, description, model no and serial no.
Unique identifier (if given one)
Drawings Record and critical (controlled drawings check – against physical installation)
Connected services and utilities (incl. conformation of suitability and validity)
Device and instrument list and identification of ‘critical’ (to determine calibration requirements)
Instrument calibration and certification records
Hardware/Software Installation and version numbers, version control/service agreement/power fail restart recovery procedure, software back-up storage and procedure, 21 CFR pt 11 compliance assessment.
Supplier manual listing/reference planned maintenance listing and spare parts list.
Operational SOPs (pre-requisite to operation of equipment)
OQ (Operational Qualification): Operational testing of all equipment functions/operating parameters, alarms and interlocks (etc) identified as ‘critical’ in VP (e.g. – ranges of operation – temperature, fans, airflow etc…). Operational testing of both manual and automated functionality and software (critical) – set-points, ramp-up time etc…
PQ (performance qualification): Testing the ‘output’ against pre-determined requirements/specifications using pre-determined operational set-points/controls etc.
Determination of reproducibility of process (system/equipment) – these tests are carried out for each differing ‘process’ and are usually carried out min. 3 times against defined batch documentation/job cards/work instructions.
VR (validation report) reports on validated status of the equipment and/or process as defined in your Validation Plan and URS.
(See previous post for detail) and summarises all validation activity and documentation aoutput.
Validation reports that are written as part of a revalidation plan/ validation review process:
Concentrate only on validation activities/change controls/deviations/CAPAs etc… since the original validation. This report will assess and close out any identified ‘gaps’ since last qualification and report on current validated status.
Hope this is extensive enough for starters.
romanfa
#24
Hello !
I am validation engineer in medical device factory.
A new ETO sterilizer is planned and installation completed.
Now it is my part to perform IQ and OQ for the ETO sterilizer.
I read the relevant ISO (11135-1-2007) And (11135-2-2008), but I still have essential misunderstand.
According to ISO I have to perform temperature and RH mapping in empty chamber without ETO.
In PQ 3 batch of product will be tested after incubation.
The question : Where I supposed to test the complete operation of ETO sterilizer with ETO gas inside- Alarms and etc.
Thank all
I Guidelines that specify the frequency of ETO Sterilizer Re-Validation ISO 13485:2016 - Medical Device Quality Management Systems 5
chris1price EtO Sterilisation Consultant Wanted Job Openings, Consulting and Employment Opportunities 0
C ETO Sterilised Class II Medical Device - Required Temperature Storage ISO 13485:2016 - Medical Device Quality Management Systems 1
A Is Aeration Process in ETO Sterilization Validation Required? Manufacturing and Related Processes 7
N ETO Sterilisation Validation - EO Residual Minimum Sample Requirement ISO 13485:2016 - Medical Device Quality Management Systems 2
N Converting ETO Residual Limits from PPM to mg ISO 13485:2016 - Medical Device Quality Management Systems 6
N ISO 11135 Monitoring Routine ETO Sterilisation Parameters Other Medical Device Related Standards 3
M Is it essential to do the Fractional Test for ETO Revalidation? ISO 13485:2016 - Medical Device Quality Management Systems 1
K Re-validation of EtO sterilization after change of tape Other Medical Device and Orthopedic Related Topics 1
N Decision to file a new 510(k) - ETO (Ethylene Oxide) Sterilization Other US Medical Device Regulations 4
C ETO (Ethylene Oxide) Sterilization Audit Question Other Medical Device Related Standards 9
A How to overcome brown stains after ETO sterilization process ? Other Medical Device Related Standards 2
B Number of Biological Indicators for Routine Monitoring of ETO Sterilization Cycle Other Medical Device Regulations World-Wide 8
S Fractional cycle fail in Eto sterilization validation ISO 13485:2016 - Medical Device Quality Management Systems 3
R Eto Sterilization Product Adoption SOP ISO 13485:2016 - Medical Device Quality Management Systems 4
M EtO compatible or recommended materials Other Medical Device Regulations World-Wide 1
X EtO Steriliser Software (PACS) Update Validation Requirements Qualification and Validation (including 21 CFR Part 11) 5
S IV Catheter Biological Evaluation - EtO Residuals - Permanent Contact Definition Qualification and Validation (including 21 CFR Part 11) 2
S ETO ISO 11135-1 & ISO 17665-2 - Purity and Quality of Steam (Humidity) Qualification and Validation (including 21 CFR Part 11) 3
A Eto Sterilisation Re-Validation Requirements Other Medical Device Related Standards 4
Q Sterilisation ISO 11135 EtO-in-a-Bag (Novel Non-Traditional EtO Sterilization) Other Medical Device Related Standards 12
A Aeration Room Requirements for EtO Sterilization Other US Medical Device Regulations 3
T ETO Sterilization through luer caps Manufacturing and Related Processes 5
F Implementing ISO 11135 - Facilities Conditions - Adding ETO Sterilization Other Medical Device Related Standards 4
N EtO Sterilization Process Waste Treatment System Other Medical Device Related Standards 1
G "Intrinsically Safe" requirement - EtO sterilization of device with Battery Other Medical Device Related Standards 9
D Will just Heat and Humidity be Adequate to Simulate EtO Sterilization? Design and Development of Products and Processes 2
K Sterilization for Hypodermic Needle - EtO or Gamma? ISO 13485:2016 - Medical Device Quality Management Systems 1
D ETO Sterility Requirements for FIM Clinical Study in Europe Other Medical Device Regulations World-Wide 3
Mikilk ETO Sterilization - Annual Report of all Sterilization Validations to send the NB EU Medical Device Regulations 3
L ETO vs. Gamma Irradiation Sterilization of DBM (Demineralized Bone Matrix) Other Medical Device and Orthopedic Related Topics 3
M Effect of double ETO (Ethylene Oxide) Sterilization ISO 13485:2016 - Medical Device Quality Management Systems 13
S AAMI TIR28:2009 Product adoption & process equivalency for ETO sterilization Other US Medical Device Regulations 2
P ETO Sterilisation of Single Use Part supplied in Non-Sterile State EU Medical Device Regulations 12
M Eto Certificate of Sterilization (vs. gamma irradiation) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
K EN550 (ISO 11135-1:2007) - ETO (Ethylene Oxide) Validation Qualification and Validation (including 21 CFR Part 11) 5
B ISO 11135:2007 (EtO Sterilization) ISO 13485:2016 - Medical Device Quality Management Systems 5
T ETO Sterilization - Process monitoring and out-inspection ISO 13485:2016 - Medical Device Quality Management Systems 3
M Japanese rule on EtO residuals in sterilized medical devices? Various Other Specifications, Standards, and related Requirements 16
G EtO Sterilization - DIN/EN 550 - ISO 11135 Other US Medical Device Regulations 20
Ajit Basrur Audit Checklist for Contract Gamma and ETO Sterilization needed ISO 13485:2016 - Medical Device Quality Management Systems 3
V EMS for Medical Device Facility with Ethylene Oxide (ETO) Sterilization process. Miscellaneous Environmental Standards and EMS Related Discussions 4
T ETO Product Sterilisation Testing Standard Requirements ISO 13485:2016 - Medical Device Quality Management Systems 4
V ETO Sterilization of Urological Catheter ISO 13485:2016 - Medical Device Quality Management Systems 5
Q EtO vs. Gamma Sterilization - Stainless Steel and Titanium Orthopaedic Implants ISO 13485:2016 - Medical Device Quality Management Systems 7
C How to verify the SAL (sterilie acceptable level) is 10-6 for ETO Sterilization ISO 13485:2016 - Medical Device Quality Management Systems 6
G Supplier audit of ETO Sterilization Lab - Need a checklist or advice Supplier Quality Assurance and other Supplier Issues 3
P ETO Sterilization Validation Process and an NCR - ISO 13485:2003 CMDCAS audit ISO 13485:2016 - Medical Device Quality Management Systems 1
G UVC sterilizer CE Mark CE Marking (Conformité Européene) / CB Scheme 5
K Our local sterilizer is closing - Record Retention Question 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
