EtO vs. Gamma Sterilization - Stainless Steel and Titanium Orthopaedic Implants
Q
qaman - 2006
Dear All,
I am working for orthopaedic implants manufacturing company, our products are made of Stainless Steel and titanium. I know that the big names manufacturers are sterilizing using Gamma, is there any special reaon for not using the ETO?
I am inclined to use EtO since it is logistically more suitable, i am checking for any technical reason for not using the ETO (if any)??
G
Gert Sorensen
Re: EtO vis. Gamma Sterilization
Being implants and ETO being kind of aggressive I think you would be wise to establish that there is no residue after the ETO-process. I don't know of any reasons not to use ETO, as it is being used for all sorts of medical devices.
Statistical Steven
Statistician
Mr
qaman said:
Dear All,
I believe it is costs. Have no checked recently, but the total cost of gamma is less than EtO. I believe that gamma is also faster turnaround time. Just my two cents.
TNHunter
Re: EtO vs. Gamma Sterilization
There are also health hazards with ETO an by the way, it is explosive. It ties up a lot of space for aeration and testing for residuals. From my experience it is much harder to acheive parametric release with ETO that Gamma. Just my .02 cents.
Q
qaman - 2006
Dear All,
Thank you for your help. I am trying to answer whether the ETO is not suitable for the orthopaedic implants for any reasons related to the material wearing or no?? I hope that you will be able to help.
G
Gert Sorensen
If it is simply a question of wear and tear, there should not be an issue. Just make sure that there is no residue on the products.
W
wrodnigg
For EtO sterilisation you need suitable packaging materials...
It is often easier (and cheaper) to achieve a validated process with gamma irradiation.
And there are some regulatory concerns regarding the quantity of EtO residuals after EtO sterilisation. EtO is listed as a human genotoxic carcinogen.
~ghw
X
X.Liu
Our company is making vascular grafts. We use EtO for sterilisation. I understand the concerns raised in above replays in general.
Our product is for permanent implantation, never heard anyone's life adversely affected by EtO residual after implantation. ISO 10993-7 tells you what you have to compile.
It is dangerous gas, but you can control it. In my opinion, the safety system is simple but effective. We all carry a nice-looking personal alarm in the site.:)
You need aeration time and space but we do not do residual test every day. As long as we control the process according to relevent standard, we only need to do biological indicator monitoring for every run and re-validation the system/process every year.
If you have large volumn everyday (as we have), you can build a big chamber and drive your lorry into it (just joke!).
I think, for metalic product, you can design the process in a quite short process time in conbination of optimised humidity. This should reduce the cost, aeration/residual issue to accept level.
K Sterilization for Hypodermic Needle - EtO or Gamma? ISO 13485:2016 - Medical Device Quality Management Systems 1
L ETO vs. Gamma Irradiation Sterilization of DBM (Demineralized Bone Matrix) Other Medical Device and Orthopedic Related Topics 3
M Eto Certificate of Sterilization (vs. gamma irradiation) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
Ajit Basrur Audit Checklist for Contract Gamma and ETO Sterilization needed ISO 13485:2016 - Medical Device Quality Management Systems 3
chris1price EtO Sterilisation Consultant Wanted Job Openings, Consulting and Employment Opportunities 0
C ETO Sterilised Class II Medical Device - Required Temperature Storage ISO 13485:2016 - Medical Device Quality Management Systems 1
A Is Aeration Process in ETO Sterilization Validation Required? Manufacturing and Related Processes 7
N ETO Sterilisation Validation - EO Residual Minimum Sample Requirement ISO 13485:2016 - Medical Device Quality Management Systems 2
N Converting ETO Residual Limits from PPM to mg ISO 13485:2016 - Medical Device Quality Management Systems 6
N ISO 11135 Monitoring Routine ETO Sterilisation Parameters Other Medical Device Related Standards 3
M Is it essential to do the Fractional Test for ETO Revalidation? ISO 13485:2016 - Medical Device Quality Management Systems 1
K Re-validation of EtO sterilization after change of tape Other Medical Device and Orthopedic Related Topics 1
N Decision to file a new 510(k) - ETO (Ethylene Oxide) Sterilization Other US Medical Device Regulations 4
C ETO (Ethylene Oxide) Sterilization Audit Question Other Medical Device Related Standards 9
A How to overcome brown stains after ETO sterilization process ? Other Medical Device Related Standards 2
B Number of Biological Indicators for Routine Monitoring of ETO Sterilization Cycle Other Medical Device Regulations World-Wide 8
S Fractional cycle fail in Eto sterilization validation ISO 13485:2016 - Medical Device Quality Management Systems 3
R Eto Sterilization Product Adoption SOP ISO 13485:2016 - Medical Device Quality Management Systems 4
M EtO compatible or recommended materials Other Medical Device Regulations World-Wide 1
X EtO Steriliser Software (PACS) Update Validation Requirements Qualification and Validation (including 21 CFR Part 11) 5
S IV Catheter Biological Evaluation - EtO Residuals - Permanent Contact Definition Qualification and Validation (including 21 CFR Part 11) 2
S ETO ISO 11135-1 & ISO 17665-2 - Purity and Quality of Steam (Humidity) Qualification and Validation (including 21 CFR Part 11) 3
A Eto Sterilisation Re-Validation Requirements Other Medical Device Related Standards 4
Q Sterilisation ISO 11135 EtO-in-a-Bag (Novel Non-Traditional EtO Sterilization) Other Medical Device Related Standards 12
A Aeration Room Requirements for EtO Sterilization Other US Medical Device Regulations 3
T ETO Sterilization through luer caps Manufacturing and Related Processes 5
F Implementing ISO 11135 - Facilities Conditions - Adding ETO Sterilization Other Medical Device Related Standards 4
N EtO Sterilization Process Waste Treatment System Other Medical Device Related Standards 1
G "Intrinsically Safe" requirement - EtO sterilization of device with Battery Other Medical Device Related Standards 9
D Will just Heat and Humidity be Adequate to Simulate EtO Sterilization? Design and Development of Products and Processes 2
D ETO Sterility Requirements for FIM Clinical Study in Europe Other Medical Device Regulations World-Wide 3
Mikilk ETO Sterilization - Annual Report of all Sterilization Validations to send the NB EU Medical Device Regulations 3
M Effect of double ETO (Ethylene Oxide) Sterilization ISO 13485:2016 - Medical Device Quality Management Systems 13
S AAMI TIR28:2009 Product adoption & process equivalency for ETO sterilization Other US Medical Device Regulations 2
P ETO Sterilisation of Single Use Part supplied in Non-Sterile State EU Medical Device Regulations 12
I ETO Sterilizer Validation (ISO 11135:2007) Other Medical Device Related Standards 23
K EN550 (ISO 11135-1:2007) - ETO (Ethylene Oxide) Validation Qualification and Validation (including 21 CFR Part 11) 5
B ISO 11135:2007 (EtO Sterilization) ISO 13485:2016 - Medical Device Quality Management Systems 5
I Guidelines that specify the frequency of ETO Sterilizer Re-Validation ISO 13485:2016 - Medical Device Quality Management Systems 5
T ETO Sterilization - Process monitoring and out-inspection ISO 13485:2016 - Medical Device Quality Management Systems 3
M Japanese rule on EtO residuals in sterilized medical devices? Various Other Specifications, Standards, and related Requirements 16
G EtO Sterilization - DIN/EN 550 - ISO 11135 Other US Medical Device Regulations 20
V EMS for Medical Device Facility with Ethylene Oxide (ETO) Sterilization process. Miscellaneous Environmental Standards and EMS Related Discussions 4
T ETO Product Sterilisation Testing Standard Requirements ISO 13485:2016 - Medical Device Quality Management Systems 4
V ETO Sterilization of Urological Catheter ISO 13485:2016 - Medical Device Quality Management Systems 5
C How to verify the SAL (sterilie acceptable level) is 10-6 for ETO Sterilization ISO 13485:2016 - Medical Device Quality Management Systems 6
G Supplier audit of ETO Sterilization Lab - Need a checklist or advice Supplier Quality Assurance and other Supplier Issues 3
P ETO Sterilization Validation Process and an NCR - ISO 13485:2003 CMDCAS audit ISO 13485:2016 - Medical Device Quality Management Systems 1
N Looking for Gamma sterilization facility in China ISO 13485:2016 - Medical Device Quality Management Systems 4
E Gamma Sterilization Product Update Manufacturing and Related Processes 2
