EU Basic UDI-DI Trigger Points - When is a new Basic UDI-DI required
M.R.Falco
Hello everyone! I have a question about the EU Basic UDI-DI and how one determines when a new Basic UDI-DI is required. In my research I have learned that the Basic UDI-DI is essentially a higher level key for a group of similar products, but at what point do you decide to start a new Basic UDI-DI? Reviewing MDCG 2018-1, it is not clear what the requirements are and this document isn't overly helpful to us.
To give you an example, if I have a series of blood pressure devices, they might come in a variety of colors and cuff sizes. Generally devices like this would be extremely similar to one another as they all need to meet the same performance characteristics and have the same intended use, but there are differences between wall mounted devices, mobile-stand mounted devices, and hand held devices.
In this sort of situation, where do I put break points in my Basic UDI-DI? Are all the blood pressure devices one Basic UDI-DI since they are all the same risk class with the same intended use? Should I make three Basic UDI's, one for each type of mount/transportability option? Do I need to make more to account for cuff size differences? Do I need to go further and make one for each color option for each type of blood pressure device? Obviously we will continue to assign the actual UDI-DI to each and every variation, but the higher level Basic UDI-DI is a bit of a mystery.
Curious to see how others are handling this! I reviewed the GS1 guidance and it tells me how to create the Basic UDI-DI, but not how many I need to make! :)
fialor
Hello Falco,
I have not had the question as my products so far has been pretty straightforward for Basic UID-DIs.
My suggestion would be to refer to the four key areas of consideration: Intended use, Risk class, Essential design, Manufacturing characteristics, and determine the extent to which they are different. Then draw a conclusion with a strong rational and be prepared to defend that position.
Your NB will also be able to shed some light on this for you. I hope it helps.
kreid
The picture attached indicates with asterisks what data item changes provoke a change in UDI (basic or otherwise).
However, I do find this all very vague and think there are probably more guidelines to come especially with regard to Basic UDI
M.R.Falco
Thank you both for the advice/tips! I will consider these points when trying to decide the Basic-UDI break points in our database. Hopefully they clarify this further with guidance documents in the months to come.
M Basic UDI and technical documentation EU Medical Device Regulations 1
A What is the difference between Basic UDI-DI and UDI-DI? EU Medical Device Regulations 5
M Informational EU – MDCG 2018-1 v2 Guidance on basic UDI-DI and changes to UDI-DI Medical Device and FDA Regulations and Standards News 0
F MDR 2017/745 Basic UDI-DI, UDI-DI & UDI-PI EU Medical Device Regulations 0
N EU MDR Basic UDI-DI and Technical Documentation for Systems EU Medical Device Regulations 20
M Medical Device News EU – MDCG 2019-1 MDCG guiding principles for issuing entities rules on Basic UDI-DI Medical Device and FDA Regulations and Standards News 0
C NB approval - Basic question about Notified Bodies and their role EU Medical Device Regulations 10
B Seven Basic Quality Tools (January 23) [Paid] Training - Internal, External, Online and Distance Learning 1
E Three basic questions about ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
rezayatmand IEC 60601-2-18 Medical electrical equipment - Part 2-18: Particular requirements for the basic safety and essential performance of endoscopic equipmen IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
B Evaluation of Basic Safety during EMC Immunity or Climate Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
J How to measure a Critical Characteristic that is a Basic Dimension Misc. Quality Assurance and Business Systems Related Topics 6
L Unacceptable risk for basic safety prior to or after mitigation? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
E Basic Risk based thinking questions Risk Management Principles and Generic Guidelines 5
S Question about a basic additive variance/tolerance example Quality Tools, Improvement and Analysis 2
Marc Basic - How to Start a New Discussion Thread Elsmar Xenforo Forum Software Instructions and Help 1
S Basic Dimension W/O using FCF Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
V Carbon Black (Master Batch) - Basic Requirements Manufacturing and Related Processes 5
G Setting Up a Basic Quality Lab for a small manufacturing company General Measurement Device and Calibration Topics 2
P Basic Minitab Help - It's about Linear Regression Using Minitab Software 1
L Lean Book for Basic Knowledge Lean in Manufacturing and Service Industries 0
L Seeking help in Basic Maintenance Knowledge Manufacturing and Related Processes 4
M "Basic Safety" versus "Essential Performance" IEC 60601 - Medical Electrical Equipment Safety Standards Series 12
M Use of Excel and VBA (visual basic for applications) in quality systems Excel .xls Spreadsheet Templates and Tools 3
P Basic questions about earning TSOA (Technical Standard Order Authorization) and PMA Federal Aviation Administration (FAA) Standards and Requirements 2
J Excel spreadsheet to use Basic and Mini MOST for Line Balancing Document Control Systems, Procedures, Forms and Templates 1
T How to report Basic Dimensions on a Dimensional Report (ISIR) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
A Basic ISO 13485 Training Material ISO 13485:2016 - Medical Device Quality Management Systems 5
M Basic Dimensions on Machining Prints Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M Basic International Standards required for a Manufacturing Industry (Optical Media) Other ISO and International Standards and European Regulations 4
L How to set up a basic electronic test equipment calibration laboratory General Measurement Device and Calibration Topics 3
R Rejecting a Part when Dimension Feature is Basic Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
O Metrology Devices to Measure the Basic Dimensions of Plastic Specimens General Measurement Device and Calibration Topics 6
F ISO 9001:2008 Fundamentals: Basic Questions - Controlled Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
E How can I measure three true positions? GD&T basic question General Measurement Device and Calibration Topics 5
M SPC, Moving Range Chart and Weighted Graph Basic Questions Statistical Analysis Tools, Techniques and SPC 1
T Basic Document Control Database (Excel/Access) Document Control Systems, Procedures, Forms and Templates 3
V The Purpose of Basic Dimensions on Prints APQP and PPAP 6
N Basic requirements and steps involved to get NADCAP Certification AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 4
D Profile of a Line of a radius of 25mm basic dimension - Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
C Basic Internal Calibration Procedure to check the Accuracy of a Balance Calibration Frequency (Interval) 6
P Basic Food Hygiene Presentation Training - Internal, External, Online and Distance Learning 6
M Training Toolbox for Basic Food Hygiene - Food Safety Food Safety - ISO 22000, HACCP (21 CFR 120) 2
Q Basic questions about AS9100C Quality Standard Requirements AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
D Basic Educational Film - What Quality is all about ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Basic Internal Auditor Training Powerpoint File Internal Auditing 26
S Basic Environmental Aspects Register template wanted Document Control Systems, Procedures, Forms and Templates 1
S PPAP - How to calculate tolerance on basic dimension APQP and PPAP 5
G Very Basic PFMEA (Process FMEA) Guidelines FMEA and Control Plans 17
C Basic Statistics Template .xls Document Control Systems, Procedures, Forms and Templates 0
