Thanks Pads38,
The device is battery operated and the power supply charges the internal battery.
The device will continue to work with the power supply connected to it.
So let me see if I understand you correctly:
If an accessory or other component is an essential part of the device's ability to perform its intended use - then the accessory "inherits" the classification of the device and can be sold together with the device or separately as a spare part with reference to the system's Declaration of Conformity. Correct?
On the other end, if an accessory is not essential part of the device's ability to perform its intended use, e.g. suitcase - then it may be classified seperatly as a class I accessory although I don't see a real benefit in doing that. Correct?
My initial idea was to see to what extent it is possible to separate meaningful accessories like power supply from a higher classified device.
Any more thought out there? I know the EU regulation is ambiguous on many things but if you could provide a reference source it would be great.
Thanks,
Shimon
I see some unnecessary confusion here. The MDD has a clear definition for accessories to medical devices (I wish the FDA was as clear on that subject).
If the item in question does not
enable the device to perform its intended use, it's not an accessory to that device, per the MDD.
In my understanding, the first question to be asked is how the item is offered for sale. If it's only sold as part of a device and then maybe offered as a spare part to an existing user, the accessory question is irrelevant - it is an integral part of the device and shouldn't have an independent classification / DoC. Only if it is offered as a stand-alone add-on it might be an accessory. And then, the verdict comes down to the MDD definition.
At first impression a carry bag is not an accessory, it probably doesn't
enable the intended use.
Can your device run on non-rechargeable batteries? If not, does it come initially pre-charged, so that the charger is only first required after a while?
