EU to UK plug adapter correct testing standard
Hi all. Looking for advices.
Im trying to understand which standard/s is/are sufficient for UK compliance -> product: EU to UK plug adapter.
Standard BS 1363 - is just a specification for UK plug.
Found new BS 8546 standard for travel adapters, but not sure its correct for my case.
Also will be appreciate for information about 220 VAC cables - correct compliance tips & tricks, testing standard, marking.
mattador78
When you say an adapter is this just for temporary use? Or are you looking at providing this as an option in the box? With all of the purchase's we have which come with a European plug and an adapter we just cut it off and get our electrician to wire a UK plug on to ensure its secure in the socket.
Thanks for info. Yes it will be as an option in the box with main device. (not a good news for my colleagues responsible for that decision)
mattador78
You could always buy a load of UK plugs which are probably cheaper than the adapter and throw one of them in the box as well lol. Its done usually due to the strength/security of the plug in the socket anything with an adapter always has the potential to be knocked pulled and lose its connection.
Thanks for answers, but I need exact answer on my quesiton.
CaliperJim Double Ended Thread Plug Gauge Calibration General Measurement Device and Calibration Topics 9
R NRTL - Scope Question - Off-the-Shelf Plug In IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
C Aluminum galling on thread plug gauge Manufacturing and Related Processes 10
L Calibration of Plug Gauges - Tolerancing General Measurement Device and Calibration Topics 1
B IEC 60601 Cl. 8.4.3 - ME EQUIPMENT intended to be connected to a power source by a plug / Plug discharge IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
H Thread Plug Gauge Tolerances General Measurement Device and Calibration Topics 3
F Holes position inspection - Calculation of centre distance and plug sizes of a gauge Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
R Thread plug chip groove - Thread plugs without the chip groove General Measurement Device and Calibration Topics 0
M Calculating MTBF for plug-in PCI cards Reliability Analysis - Predictions, Testing and Standards 2
C Calibration of Master Thread Plug Gages General Measurement Device and Calibration Topics 2
C Measurements of Major Diameters of plug thread gages General Measurement Device and Calibration Topics 12
D Indysoft Calibration Software Thread Plug Template Help General Measurement Device and Calibration Topics 2
D Incomplete DHF: Re-do or plug gaps? Design and Development of Products and Processes 6
T Inspecting Full Thread Depth with a Plug Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
M How to make Plug Gauge No & NoGo Sizes Calibration and Metrology Software and Hardware 3
T How do I calibrate NPT Thread Plug Gages? General Measurement Device and Calibration Topics 9
SATHYABALARAMAN Thread Plug Gauge - NO-GO Rejection Criteria General Measurement Device and Calibration Topics 4
S Plug Discharge Test Calculations IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
G Gage Recall Analysis - Threaded Plug Gage has failed Calibration General Measurement Device and Calibration Topics 10
R Hospital Grade Mains Plug US (NEMA 5-15) and Japan IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
R Should be Hospital Grade Plug be used in Class II Medical Equipment? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
CycleMike 7.6.1 - ".....type of measurements system" and Plug Go/NoGo gages IATF 16949 - Automotive Quality Systems Standard 4
L TiN Coated Thread Plug Gauges General Measurement Device and Calibration Topics 12
T Constant for a M3x.35 Set Plug using the "Three-Wire Method" Calibration and Metrology Software and Hardware 2
F Standard regarding the wear of Thread and Plug Gages. General Measurement Device and Calibration Topics 10
D What is the difference between Pin and Plug Gages General Measurement Device and Calibration Topics 13
M Thread Plug Gage - Calibration Frequency ISO 13485:2016 - Medical Device Quality Management Systems 1
P Use of ANSI Standard for Metric Thread Plug Gage? General Measurement Device and Calibration Topics 1
L Plug Gages and Tapered Holes - Compensation for Heat Treat Distortion General Measurement Device and Calibration Topics 1
M ASME B1.13M Standard - Specification of a Plug Gage of Minor Diamateter Various Other Specifications, Standards, and related Requirements 3
L Calibration Procedure for Internal Spline Plug Gage Needed General Measurement Device and Calibration Topics 4
R Thread Measurement - Basics on Thread Plug and Ring Calibration General Measurement Device and Calibration Topics 5
L Pitch Diameter for a Thread Setting Plug 4.3750-8 ACME-2G, GO/ NO GO General Measurement Device and Calibration Topics 6
B Plug Gauge (Gage) Design Design and Development of Products and Processes 7
L UN Class 5 Tolerances - Thread Setting Plug Gage 7/8-9 UNC 5 General Measurement Device and Calibration Topics 23
M Thread Plug Gauge Design - Width of flat of crest of thread Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C Functional Gages give different results - Thread Plug Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
R What do "GO" and "NO GO" of a thread plug gauge check? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
A Plug Gauge Size shows increase after use? Criteria for acceptance of the gauges? General Measurement Device and Calibration Topics 5
mr500 Calibration Of Plug gages (G0-No Go Tri lock gages) General Measurement Device and Calibration Topics 11
P Liquid Nitrogen to shrink fit a new plug into a hole in a casting Manufacturing and Related Processes 7
C NO-Go Plug Gage Force General Measurement Device and Calibration Topics 3
S NPT Thread Calibration Method - NPT Taper Thread Plug Gages General Measurement Device and Calibration Topics 9
M Calibrating 1/2-20 UNF 2B STI Threaded Plug Gage General Measurement Device and Calibration Topics 3
Proud Liberal Using Multiple Plug Gages check a large diameter Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
B Method for Calibration of Thread Plug Gauges General Measurement Device and Calibration Topics 13
T Calibration and Control - Need help with plug, ring, and thread plug gages General Measurement Device and Calibration Topics 12
