EU Vigilance (updated MEDDEV rev.5) - Internal Forms
jampot
I am currently updating our controlled forms relating to Vigilance in accordance with the updated MEDDEV (rev 5). I have access to the standard form for Manufacturers to Report an Incident to the National Competent Authority (section 10.3 of the MEDDEV). However I wondered if anyone had forms they could share detailing
1. Initial Incident reporting that can be completed by the hospital or completed internally if an event is telephoned/faxed/emailed through - this would detail relevant facts about the incident.
2. An Adverse Incident checklist
Many thanks
Q
QA-Man
Re: EU Vigilance - Internal Forms
We incorporate adverse event reporting into our customer complaint process. Each time we receive a complaint, we evaluate it to see if it is a reportable event.
I would define what type of event is reportable in your customer complaint process. You may require several definitions if you have more than one power to answer to (for example, you sel products in Europe & the US).
Each time you think you have a reportable event, I would review the applicable regulations to ensure I have the most up to date information.
jampot
Thats interesting - thanks. Our current procedure titled 'Customer Complaints' covers Vigilance but I'd been advised to take it down and make it a separate procedure.
However, it would make things easier if I maintained the current procedure (updated for the latest MEDDEV) and used our Customer Complaint form to get data from the site.
How about a checklist? Would a form running through what constitutes a reportable event suffice?
Q
QA-Man
We don't use a checklist, we just have definitions based upon region. Check out the attached document. Its a comparison of the Device Adverse Reporting Systems in USA, Europe, Canada, Australia & Japan. It might help you come up with a general checklist.
What's reportable in one country may not be reportable in one country. For example, if your product is CE marked you may have to report an adverse event even if it didn't happen in Europe.
CBAL08
Re: EU Vigilance / MDR (US)/Mandatory problem reporting for (CANADA)
Can someone help me to find the three adverse incident reporting combined into one process or give me an idea how to generate a document having all the requirement for reporting MDRs in the three different places. I am trying my best but because of all the different definitions I am getting confused.
Mandatory Problem reporting
Adverse Incident reporting'
Vigilance system reporting
Medical device reporting
Canadian Medcial device reporting
Adverse reaction reporting and so on......
Please Help.
If someone has a template then could they share it here.....
CBAL08
Was hoping to find some response here..seems that I cannot....
bio_subbu
Please Help.
You can have a single integrated procedure for medical device Reporting and vigilance. But you have to make clear definitions such as MDR- Reportable Event, serious injury, Vigilance system, incident, near incident, competent authorities, and notified body to avoid confusion between different regulatory terminologies.
Under the single topic “Procedure for Medical device reporting and vigilance", you need to make clear procedure for each regulatory requirements.
For better understanding prepare a table, in that explain time lines for reporting FDA, EU and Canadian regulatory bodies.
Also, please mention the current and relevant regulatory guidelines information in to the reference material or associated material section.
Regards
S. Subramaniam
CBAL08
Hi CBAL08,
See if the attached are any help.
Steve
Thank you for the forms Provided Steve. I also mjst thank you for posting other documents in Elsmar as they seem to be very sueful for people like me who are new in the field of Quality.
However was trying to write the Adverse incidence reporting for US, EU and Canada in One and that is what is making me go crazy.....trying to tabulate but is not helping much at the moment. Will try to read through the regulations and guidelines for all quitely first in the weekend and then will try to write up a combined procedure.
Thank you for your support.
:thanx:
CBAL08
Regards
S. Subramaniam
Thank you for the guidance. I am trying my best. AND FOR PROCESSING the reports further I have placed the links to to form and am trying to explain for each regulatory bodies separately.
As suggested have the definitions clearly outlined in the definitions section of the SOP.
Have tabulated the terms and the time scale and applicability in the table.
Need to sit quitely and see if the whole document makes sense or not?
Thank you once again.:thanks:
M Vigilance - incident found in an article EU Medical Device Regulations 3
R Vigilance reporting to the country of the EU authorised representative EU Medical Device Regulations 2
A Medical Device Vigilance decision tree for Japan for class 2 devices. Japan Medical Device Regulations 1
L Global distributor vigilance responsibility Medical Device and FDA Regulations and Standards News 14
M Informational DSVG 04 – Breast Implants – Guidance on the vigilance system for CE-marked medical devices Medical Device and FDA Regulations and Standards News 0
M Informational EU – DSVG 03 – Cardiac Implantable Electronic Devices (CIED) – Guidance on the vigilance system for CE-marked medical devices Medical Device and FDA Regulations and Standards News 0
M Saudi Arabia (KSA) - Medical Device Vigilance according to 93/42/CEE Other Medical Device Regulations World-Wide 0
K Vigilance process flow chart EU Medical Device Regulations 1
dgrainger Informational Additional Guidance Regarding the Vigilance System as outlined in MEDDEV 2.12-1 rev. 8 EU Medical Device Regulations 1
M Informational MHRA update – Medical devices: guidance for manufacturers on vigilance - June 2019 Medical Device and FDA Regulations and Standards News 0
W SOP for Vigilance reporting covering multiple requirements Document Control Systems, Procedures, Forms and Templates 3
F Vigilance Reporting - Requirements for manufacturer Field Corrective Actions (FCAs) Other Medical Device Regulations World-Wide 5
J Medical Device Vigilance decision tree FORM - Please share yours EU Medical Device Regulations 15
M Definition Vigilance - What is the definition of "Vigilance"? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 5
S Understanding PMS (Post Market Surveillance) and PMCF (Vigilance and PMCF) Quality Manager and Management Related Issues 1
S Help with EU Medical Device Vigilance Reporting Requirements EU Medical Device Regulations 0
J Can I combine Recalls, Advisory notices, and Vigilance systems into one procedure? ISO 13485:2016 - Medical Device Quality Management Systems 2
A Japan Medical Devices Vigilance Regulations or Guidelines Japan Medical Device Regulations 4
S Revised MEDDEV 2.12-1 rev 8 Vigilance System - Released EU Medical Device Regulations 3
D Vigilance Trend reporting requirements of Meddev 2.12/ver 7 in the EU Document Control Systems, Procedures, Forms and Templates 1
A Flowchart to explain the Medical Device Vigilance Reporting Process wanted EU Medical Device Regulations 4
bio_subbu EU publishes revised guidance on Medical Devices Vigilance system MEDDEV 2.12-1 Rev7 EU Medical Device Regulations 8
T EU Medical Device Vigilance Reporting Requirements EU Medical Device Regulations 3
K Vigilance, MDR, Recall, Complaint Procedures - Can this all be one single procedure ISO 13485:2016 - Medical Device Quality Management Systems 3
P Good Vigilance Practice (GVP) - Japan - English translation and explanation of Japan Medical Device Regulations 8
I Vigilance SOP that covers Australia, Taiwan, Japan or Brazil wanted Other Medical Device Regulations World-Wide 1
P Medical Device Vigilance - MDR or MDD? EU Medical Device Regulations 9
T Vigilance System MEDDEV 2009 changes - MEDDEV 2.12-1 rev 6 for Vigilance System EU Medical Device Regulations 1
B Medical Device Vigilance Reporting Multi Markets Other ISO and International Standards and European Regulations 2
V Evidence for Preventive Action & Early Warning Vigilance procedure Preventive Action and Continuous Improvement 4
bio_subbu MHRA - Draft guidance on specific device vigilance reporting EU Medical Device Regulations 0
D Vigilance - Public database of Vigilance reports (similar to FDA MAUDE database)? Other Medical Device and Orthopedic Related Topics 1
J Vigilance Report Required for Incidents Outside the EU? EU Medical Device Regulations 2
E How to practically organize the 'Vigilance' function? ISO 13485:2016 - Medical Device Quality Management Systems 7
J Distributor Requirements - Vigilance and Traceability ISO 13485:2016 - Medical Device Quality Management Systems 7
R Medical Device Vigilance System Requirements - CE Mark Products EU Medical Device Regulations 4
D Official Government Regulatory Body Vigilance Contacts to use for China and for India ISO 13485:2016 - Medical Device Quality Management Systems 4
C Audit NonConformance - Evidence of Post Market Vigilance and Product Recall. ISO 13485:2016 - Medical Device Quality Management Systems 6
Z MEDDEV 2.12-1 Rev 5 Reportability Decision Tree? Vigilance Reporting Procedure EU Medical Device Regulations 18
O Medical Device (MedDev) Vigilance Guidelines for Importers into the UE EU Medical Device Regulations 5
J Medical Devices Vigilance Procedure Example needed Document Control Systems, Procedures, Forms and Templates 12
U Regulatory Contacts in every country for Medical Device Vigilance purposes ISO 13485:2016 - Medical Device Quality Management Systems 3
A Who is in charge of Vigilance reporting in your company? ISO 13485:2016 - Medical Device Quality Management Systems 1
O Vigilance System - Seeking example Procedure and Implementation Advice ISO 13485:2016 - Medical Device Quality Management Systems 4
B Updated IATF 16949 - Will IATF 16949 get revised when ISO 9001:202X is released? IATF 16949 - Automotive Quality Systems Standard 4
K Updated MSA with the Annual PPAP validations APQP and PPAP 8
Ed Panek Compliance with Standards? When a standard is updated/revised CE Marking (Conformité Européene) / CB Scheme 3
R Shall a new UDI-DI be required when stand-alone software device's version is updated? EU Medical Device Regulations 1
P Cenelec updated standard information CE Marking (Conformité Européene) / CB Scheme 1
