European Technical File for registration in Australia
My company wants to register a CE marked product in Australia.
We have a technical file and a declaration of conformity written according to the European regulation (MDR 2017/745).
Can we use this technical file or do we need a technical file according to the Australian regulation?
Thank you in advance.
Ed Panek
QA RA Small Med Dev Company
Is your product being used for COV-19?
We just submitted our DoC for MDD but we had an in country distributor assist us.
I suggest the easiest is an in country partner.
Hello Ed,
Our product is not used for Covid. It is a kit composed of several devices used in the dental field.
We have a sponsor in Australia who will do the registration for us on the TGA website.
For the information to be provided, it is indicated that it is necessary to have a technical file. And we don't know if we can submit the European technical file or if we have to prepare a technical file according to the Australian regulations.
mboynton
Hi there,
In general, I do not think it is usually necessary to create a parallel technical file only for Australia. I would suggest incorporating a few Australia-specific elements in the same EU technical file, to be sure that the unique elements are covered for Australia:
1) Classification of your device according to the Australian rules
2) Conformity to the Australian Essential Principles (heavily borrowing from your evidence for conformity to the Essential Requirements in EU)
3) Link to the Australian Declaration of Conformity (see the templates on the Australian website)
4) Identification of the local sponsor
However, in your case, the situation could be somewhat different, based on the device being a kit, since procedure packs require an abbreviated set of documentation for EU, whereas it is treated as a single device for registration in the Australian ARTG (although since you note that the device is CE-marked, presumably you do not consider it as a procedure pack in EU?). If that could cause confusion, separate documents may be easier, but I am not aware of any regulatory restrictions on that - it would be up to your preference.
Based on the description of your product, I'd suggest reading over the TGA requirements on procedure packs, if you've not already taken a look:
[<https:// www .tga.gov.au/ update-medical-device-definitions-and-requirements-system-or-procedure-packs>]
and here:
[<https:// www .tga.gov.au/ sites/default/files/devices-argmd-01.pdf>]
Cheers,
Hi there,
and here:
Cheers,
Thank you very much for this information.
I used the term kit (my mistake), but the product is considered as a single device in Europe.
We don't want to incorporate the Australian specific elements (classification, Essential principles checklist...) in the EU technical file.
Can we just have them in addition to the EU technical file, or do we have to create a specific technical file for Australia?
Thank you for your help.
Mikilk
you are right about wanting to separate it as for EU you must keep a "clean" file with the MDD / MDR requirements for the review of the notified body / competent authority (depend on the class) review where requested.
you can keep additional records, but you will need to submit the file to TGA so you are recommended to keep a separate file to Australia in order to trace the submitted documents and versions.
as mentioned above, for some documents (such as the Declaration of Conformity) you will need to use the local template , the EU one is not fully fit
D Translation Procedure (to other European languages) for Class IIa in Technical File CE Marking (Conformité Européene) / CB Scheme 16
S Medical Device Registration & Technical Format/Template - European Union CE Marking (Conformité Européene) / CB Scheme 8
P EASA DOA and ETSO (European Technical Standard Order) EASA and JAA Aviation Standards and Requirements 4
P European Medical Device Nomenclature (EMDN) and CND EU Medical Device Regulations 8
B European Harmonized vs IEC standard IEC 62366 - Medical Device Usability Engineering 2
P Requirements for being an European Representative EU Medical Device Regulations 3
P Best european location to set up for a virtual medical device manufacturer? EU Medical Device Regulations 4
A European UDI-DI CE Marking (Conformité Européene) / CB Scheme 2
F How to register class I device to all European Competent Autorities(CA) when we are European manufacturer EU Medical Device Regulations 4
dgrainger Medical Device News MDR postponed - link to Official Journal of the European Union (24-4-2020) EU Medical Device Regulations 2
P European versions of standards - ISO 10993-1 and ISO 11607-1 EU Medical Device Regulations 6
shimonv Recall - Is there a European regulation for recalls of products EU Medical Device Regulations 4
atitheya Need of conducting medical trials in European Union EU Medical Device Regulations 2
P ISO 10993-1:2018 - When will the European equivalent become a Harmonized Standard? Other Medical Device Related Standards 13
M Informational TGA – European implementation of Medical Device and IVD Regulations – Implications for Australia Medical Device and FDA Regulations and Standards News 0
M Informational EU – Guidance document Implant Card relating to the application of Article 18 Regulation (EU) 2017/745 of the European Parliament and of the Council o Medical Device and FDA Regulations and Standards News 2
M Informational European Commission expert panels on medical devices and in vitro diagnostic devices Medical Device and FDA Regulations and Standards News 0
Marc European universities dismal at reporting results of clinical trials - 2019 Other Medical Device Regulations World-Wide 0
M Informational Medtech Europe – Open letter to the European Commission on the implementation and readiness status of the new Medical Device Regulation (MDR) Medical Device and FDA Regulations and Standards News 0
M Informational Technology and innovation of human implants | Panel for the Future of Science and Technology (STOA) | European Parliament Medical Device and FDA Regulations and Standards News 0
M Informational EU – Draft Functional specifications for the European Database on Medical Devices (Eudamed) – First release (High(1)) to be audited Medical Device and FDA Regulations and Standards News 0
moounir Medical Device Nomenclature - Free of Charge? (European Union MDR MDR 2017/745) EU Medical Device Regulations 7
M Informational EU – Questions And Answers Related To The United Kingdom’s Withdrawal From The European Union With Regard To Industrial Products Medical Device and FDA Regulations and Standards News 0
N European Authorised Representative (also called Authorized Representative) - Cost competitive recommendation EU Medical Device Regulations 1
Marc Regulation (EU) 2017/745 of the European Parliament EU Medical Device Regulations 13
J Medical Device Registration in Argentina - Client asks us to provide “European FSC” Other Medical Device Regulations World-Wide 4
S CE ETA (A2) Audit - CE mark for the european construction market CE Marking (Conformité Européene) / CB Scheme 0
N Will an FDA UDI be compatible with a European MDR UDI? EU Medical Device Regulations 7
M Medical Device News MedTech Europe - European Parliament further clarifies Commission proposal on HTA for medical technologies EU Medical Device Regulations 0
W Sale medical device to European Hospitals Hospitals, Clinics & other Health Care Providers 1
R Brexit - European Commission - The impact of the Brexit per March 29, 2019 EU Medical Device Regulations 3
E European Weld Callouts - Confused with the "/C" and the "a2" portions Various Other Specifications, Standards, and related Requirements 7
H European Pharmacopoeia First Identification Requirements Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
Q IVD vs EMC OJ (Official Journal of the European Union) Harmonised Standard Conflicts EU Medical Device Regulations 1
L ISO 13485 and European GMP ISO 13485:2016 - Medical Device Quality Management Systems 3
E European Regulations defining the terms Repair and Refurbish EU Medical Device Regulations 5
Marc Definition PEPPOL - Pan-European Public Procurement Online Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
J Label translation requirements for EU (European Union) EU Medical Device Regulations 3
U What if UK leaves EU? What will happen to European Authorized representative in UK? EU Medical Device Regulations 22
rob73 New MDD (European Medical Device Regulations) next steps - 2016 EU Medical Device Regulations 1
E I'm looking for old publications of European Quality in pdf Book, Video, Blog and Web Site Reviews and Recommendations 2
F What is the European UDI implementation timeline? EU Medical Device Regulations 3
K May 16 2014 Official Journal of the European Union Publication - 60601-2-33 EU Medical Device Regulations 3
M Overview of European Regulations of Medical Device Other ISO and International Standards and European Regulations 12
Ajit Basrur Is there an European equivalent of FDA Debarment List? EU Medical Device Regulations 2
P Is the European directive, 2011/65/EU applicable for Engineering Samples? RoHS, REACH, ELV, IMDS and Restricted Substances 5
Stijloor The European Union Explained Coffee Break and Water Cooler Discussions 4
E Current MRI Labeling requirement for European Union CE Marking (Conformité Européene) / CB Scheme 2
J0anne US Working Permit Requirements for European Consultants Career and Occupation Discussions 2
N Confusion within CE Mark and European Regulations CE Marking (Conformité Européene) / CB Scheme 5
