Evaluate a process audit
Qualygirl
Hi
how do you evaluate a process audit? (9001/14001)
Do you have a measurable rating scheme?
Do you present the results graphically?
An understandable example is also welcome.
Thanks and regards
Randy
Don't overthink or over reach
"Did the audit achieve/meet desired needs/requirements?" YES or NO
Every audit has an objective or objectives, were they met?
Start trying to graph, measure, count, weigh and so on it just becomes another meaningless numbers game.
abdul42550
Process Audit is conducted based on Control Plan/Process sheet etc.
You can make a summary of finding and implement the gaps. the effectiveness can be measured by Finding vs Implemented.
Re audit the same process on interval for the effectiveness.
Hi
Thanks and regards
Do you mean “evaluate” or “perform”? Just seeking to clarify.
Rating schemes don’t work for internal audits.
Only trends in audit findings, over time
John Broomfield
Hi
Thanks and regards
Do you mean:
A. Evaluate a process?
B. Audit a process? or
C. Evaluate a process audit?
Three entirely different tasks.
John Broomfield
Thanks, to evaluate a process audit for its effectiveness you need first to understand the reason for doing the evaluation.
It could be that your boss want to see if the process audits are necessary or can be done in a more efficient way.
Knowing the reason will influence your planning, preparation, sampling and reporting of the evaluation.
So, why evaluate process audits?
Qualygirl
Danke, um ein Prozessaudit auf seine Effektivität zu bewerten, müssen Sie zuerst den Grund für die Bewertung verstehen.
Es könnte sein, dass Ihr Chef sehen möchte, ob die Prozessaudits notwendig sind oder effizienter durchgeführt werden können.
Die Kenntnis des Grundes wird Ihre Planung, Vorbereitung, Probenahme und Berichterstattung der Bewertung beeinflussen.
Warum auch Prozessaudits evaluieren?
Hi
Neben einem Systemaudit fordert die ISO auch Prozessaudits, z.B. im Einkauf.
Diese wollte ich mit Fragen wie im VDA-System darstellen und mit den Stufen 0,4,6,8,10 bewerten,
daraus einen Erfüllungsgrad % ermitteln.
Und dann auch noch grafisch darstellen und im Bereich posten.
Ist das nicht eine gute Idee?
EDIT by moderator, to add translation:
In addition to a system audit, the ISO also requires process audits, e.g. in purchasing.
I wanted to present these with questions like in the VDA system and rate them with the levels 0,4,6,8,10,
determine a degree of fulfillment % from this.
And then also display it graphically and post it in the area.
Isn't that a good idea?
Please do not post in anything but English.
John Broomfield
Qualygirl,
Relating system audits to the system standard makes sense but this approach is of less value for process audits.
Usually, the client for a process audit wants to know if the process is effective and this includes conformity with the relevant clauses in the applicable standards.
Instead of rating the degree of conformity with the standard it is better for your report to be clear on what was sampled and what was found to be outstanding and what was found to be nonconforming.
Auditees cannot do much with your proposed ratings.
John
B Chrysler PFMEA Audit Criteria Checklist to evaluate your Process FMEA FMEA and Control Plans 7
Ch00Ch00 How to evaluate a process ? Document Control Systems, Procedures, Forms and Templates 3
Ch00Ch00 Evaluate a process - Issue number Lean in Manufacturing and Service Industries 7
L How to evaluate the process capability of a data set that is non-normal (cannot be transformed and does not fit any known distribution)? Capability, Accuracy and Stability - Processes, Machines, etc. 14
M Minitab tool to evaluate PM (Preventive Maintenance) process Using Minitab Software 6
L Weighing plastic part to evaluate moulding process Design and Development of Products and Processes 2
S How to Evaluate the Effectiveness of a Work Instruction during the Approval Process? Document Control Systems, Procedures, Forms and Templates 13
J How to evaluate the effectiveness of management review? IATF 16949 - Automotive Quality Systems Standard 2
D ISO 9001 - 8.4.1 Evaluate All Suppliers? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 66
T ISO 14971-2019 doubt - Evaluate if estimated risks are acceptable ISO 14971 - Medical Device Risk Management 9
Watchcat CERs Literature Databases - Searching for data to evaluate EU Medical Device Regulations 16
M Informational US FDA final guidance – Utilizing Animal Studies to Evaluate Organ Preservation Devices Medical Device and FDA Regulations and Standards News 0
M Informational USFDA – Efforts to evaluate materials in medical devices to address potential safety questions Medical Device and FDA Regulations and Standards News 0
qualprod To Evaluate Effectiveness in All Improvements? (ISO 9001:2015) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
H Evaluate Contingency Plan for Equipment and Tools IATF 16949 - Automotive Quality Systems Standard 4
qualprod Propose Aspects to evaluate risk impact? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Q How to Evaluate Internal Resources for Training ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q Source of practice to Evaluate Risks? (ISO 9001:2015) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S How to evaluate "competency" of consultants ? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
Jen Kirley How to evaluate hazards in using bar code scanners in chemical manufacturing Occupational Health & Safety Management Standards 1
A Creating a policy to evaluate the Third Party Security IEC 27001 - Information Security Management Systems (ISMS) 4
C How to evaluate the Detection Ranking of a new Design Control FMEA and Control Plans 1
G How to Audit or Evaluate our suppliers? We are not AS 9100C certified. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
Q Format to Evaluate the Effects of New Processes and Equipment Manufacturing and Related Processes 4
K Validity of Using NCR's to evaluate Performance Nonconformance and Corrective Action 7
T Why evaluate Suppliers that are Brands we represent? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
E Using ANOVA during the PQ Validation Run to evaluate Statistical Differences Statistical Analysis Tools, Techniques and SPC 4
N The right method to Measure and Evaluate a Flatness Callout Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
S How to Evaluate a Calibration Report Certificate General Measurement Device and Calibration Topics 8
J Web based Database to Collect and Evaluate 5S Audit Results, Trends, Charts Lean in Manufacturing and Service Industries 3
S Required to Assess and Evaluate all Suppliers? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
W How you can evaluate ISO 9001 Certification Body (CB) Auditors during their visits? Registrars and Notified Bodies 19
B How do you evaluate courses - eg. Awareness Training, Concept etc. Training - Internal, External, Online and Distance Learning 3
M How to validate a Dye Test method used to evaluate Package Integrity Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 8
R Can manufacturer separately evaluate the clause 14 (PEMS) of 60601-1: 2005? IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
S Training Efficiency Assessment - Evaluate the Effectiveness (Clause 6.2.2 c) Training - Internal, External, Online and Distance Learning 3
somashekar Definition Evaluate and Select ... What are the most common understandings of these words. Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 12
B Our suppliers are retail shops - How to evaluate OTS (Off the Shelf) suppliers? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B Do I evaluate my supplier when he doesn't have delivery in that month? Supplier Quality Assurance and other Supplier Issues 10
0 Best way to evaluate the differences between 2 gauges Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B Distribution of Procedures to the copy holders (evaluate my matrix) Document Control Systems, Procedures, Forms and Templates 16
S How to evaluate the Effectiveness of Corrective and Preventive Actions Nonconformance and Corrective Action 3
B How to Evaluate Competence of an Internal Translator ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
E Board of Directors - Their duties and how can we evaluate them? Misc. Quality Assurance and Business Systems Related Topics 8
B What happens if we evaluate supplier as not approved and there are no anothers? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
J Approved Supplier List - Required to evaluate every supplier? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
S Supplier Quality Rating - What to evaluate Supplier Quality Assurance and other Supplier Issues 11
U MSA Roadmap - Is there an order in which to evaluate a measurement systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
K How to evaluate or measure the complexity of product? Manufacturing and Related Processes 8
