Evaluation of Medical Device Suppliers - Categories when Initially Evaluated
P
Phil Fields
#11
We categorize our suppliers by the following:
• Key Suppliers: Suppliers that are Sole suppliers or are key due to $$$ volume
• Tier 1: Critical components as defined by Engineering, components that are critical to the safety and efficacy of the product/user/patient.
• Tier 2: Custom design material suppliers (machine shops)
• Tier 3: Commodity (nuts, bolts, material packaging etc)
• Others: Services
#12
• Others: Services
Hi Phil:
I guess I should say here that we already have our suppliers "classified". We currently do not have anything "formal" such as you've outlined above - although we base our categorization on a similar criteria.
Where I was heading to above was a means, through Risk Management, to document our qualifications process and show a reasonable means of justification as to why a given supplier is critical. I'm not picking on you, but you defined "Tier 1:" as "Critical components as defined by Engineer,..." I'm looking for a subjective way to document those engineering decisions by a defined set of criteria. "Because Engineering told me" is an acceptible reason - because I know they know what they're doing.:cool: I just want a tool to "prove them right on paper" so to speak...:agree1:
P
Phil Fields
#13
Hi Phil:
When you come up with the subjective way to classify please share. We have hit the same road block here with engineering. We have had to push back to define why some of the items are critical.
Phil
V
victoriab65
#14
On any supplier evaluation forms, I refer back to the FMEA(s) for the relevant product(s) where the supplied part or service is used. The FMEA, if done well, indicates the degree of control needed for the supplier. As noted above, this completes the loop of controlling the risk identified in FMEA (or whatever risk assessment tool you use).
G
Gert Sorensen
#15
Simple and efficient :) I like that!
Mrs Moloney
#16
Hi Steve,
Did you manage to develop the risk based supplier assessment. I was thinking of developing a standard assessment and using this together with catagorisation in order to give the supplier a rating. I wonder could you just use FMEA? Or maybe a correlation and matrix table like Quality Function Deployment could be employed?
#17
Hi Steve,
Hi Mrs. Moloney:
The short answer to your question is no. I was heading down the path of a risk-based supplier assessment, but in the end I abandoned the idea. It seemed to cumbersome. We've taken our current supplier classifications and sub-divided our "Critical" Suppliers into "Critical" and "Select" (our supplier classifications are based on a three-letter acronym - that's where "select" came from :notme:).
...anyway, the "Critical" Suppliers will be the ones that have the "Quarterly Supplier Assessment" due primarily based on dollars spent. "Select" suppliers will require all of the up-front evaluation and approval, but will be monitored primarily through our incoming inspection and our NC (non-conformance) system. Both categories supply critical parts and materials, but for the "select" suppliers - since they only supply parts/materials once or twice a Quarter - they will be monitored by a less time consuming part of our Quality System.
Just for information sake, the rest of our suppliers are categorized as "Approved" (i.e. everyone else we buy stuff from such as tape, non-critical supplies and services, etc.), "New" (suppliers we've had to put into our MRP System to generate a PO but have not completed the approval gauntlet), "Probationary" (those who just ain't cuttin' the mustard at the present time) and finally "Rejected" (...as the name implies). We decided to track rejected suppliers so that we don't go down this road again unless absolutely necessary - plus we'll have the history documented as to why we no longer deal with them and will document why we want to begin again.
I'm sure this doesn't help your endeavor, but I thought I'd give you a quick glance as to where we ended up from the "loft goal" I originally set.:cool:
FMEA's, to me, have always been a personal pet-peeve of mine. They are useful, but can be easily skewed since they are typically "subjective" instead of "Objective". As far as QFD - I really don't know much about that area so I don't know if it would be useful or not.
...More than you wanted to know, but that's my story...
-Steve
Mrs Moloney
#18
Hi Steve,
Thanks very much for your reply. I too was thinking of classifying the suppliers into critical and non-critical. There would have to be defined criteria in order to determine if the supplier is critical or not. Thats where I was thinking a risk assessment could play a part espically where it may not be obvious how to classify the supplier. I like your idea of critical and select, that makes sense. I dont get the acronym thing though.
I have the added problem in supplier control of being tied to corporate SOP's that do not really apply in some cases as its a distribution center and not a manufacturing site so the product is delivery.Incoming inspection and lot acceptance cannot be used to rate the suppliers.
regards
Mrs Moloney
#19
...I dont get the acronym thing though.
Sorry about that - I/We've defined our Supplier Classifications by a 3-letter acronym so that we can put this "tag" into their record in our MRP system. It makes it easier to search for a supplier and/or print out a list of suppliers that fit a certain category. So for our supplier lists, we have "CSL", "SSL", "ASL", "NSL", "PSL" and "RSL". I wanted to keep them all to three letters so there was less chance of input errors, consistency, etc.
Guess it's just a personal "quirk"... :rolleyes:
Just a "by the way" - for our suppliers who fall into the Distribution Center category, they are "ASL". But, our SOP is written that way - maybe once you come up with your classification scheme, it's time to revise the SOP?
-Steve
G
Gerry Quinn
#20
Steve,
I've attached a matrix that I have been playing with for a couple of years.
It's an attempt to provide risk based guidance to evaluating a supplier based on his current performance conditions and the risk associated with the specific product or service.
The supplier does not get a permanent classification because his performance may change and the risk associated with the product or service may change from project to project.
I took the risk categories from Mil-std-105E as a starting point.
I made up the supplier performance status categories.
T Clinical evaluation of a new medical device EU Medical Device Regulations 0
A Medical device CER (clinical evaluation report) training/seminar services EU Medical Device Regulations 2
S Medical device CER (clinical evaluation report) according to MDR EU Medical Device Regulations 24
S Clinical evaluation for a class IIa medical device - EU MDR Requirements EU Medical Device Regulations 3
S Medical Device Clinical Evaluation Standard Operating Procedure / SOP Document Control Systems, Procedures, Forms and Templates 11
S Medical Device Clinical Evaluation Standard Operating Procedure / SOP Imported Legacy Blogs 1
R FDA's guidance - Evaluation of Sex-Specific Data in Medical Device Clinical Studies Other US Medical Device Regulations 3
E Medical Device Class 2a CE Mark Clinical Evaluation Report CE Marking (Conformité Européene) / CB Scheme 3
K Medical Device Design Validation vs Clinical Evaluation ISO 13485:2016 - Medical Device Quality Management Systems 5
P Brazilian - Medical Device Performance Evaluation Only - Registration Requirements Other Medical Device Regulations World-Wide 6
J Biological Evaluation requirements per ISO 10993 - Medical Device Testing ISO 13485:2016 - Medical Device Quality Management Systems 2
V Product Evaluation Checklist for Class-II Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 4
A Applicability of Photobiological Safety Evaluation for LED used in medical devices Reliability Analysis - Predictions, Testing and Standards 1
M NICE Medical Technology Evaluation Programme - Recommendations Service Industry Specific Topics 0
P SOUP anomaly evaluation for MMA (Mobile Medical Application) IEC 62304 clause 7.1.3 IEC 62304 - Medical Device Software Life Cycle Processes 6
M Informational How to perform a clinical evaluation of medical devices – Part 2 – Level of clinical evidence and what sufficient clinical evidence means Medical Device and FDA Regulations and Standards News 9
M Informational How to perform a clinical evaluation of medical devices – Part 1 – Overview and sample of activities Medical Device and FDA Regulations and Standards News 0
Rincewind Clinical Evaluation of very low risk medical devices EU Medical Device Regulations 3
shimonv CFDA Technical Guidelines for Clinical Evaluation on Medical Devices (English) China Medical Device Regulations 8
E Clinical Evaluation of IVD Medical Devices CE Marking (Conformité Européene) / CB Scheme 8
S Clinical evaluation standard operating procedure / SOP for medical devices Document Control Systems, Procedures, Forms and Templates 1
M Clinical Evidence - Clinical Evaluation Report for Class I medical devices EU Medical Device Regulations 1
W ISO 10993 (Biological Evaluation of Medical Devices) for Suppliers Other ISO and International Standards and European Regulations 8
A Medical Whiteroom Environmental Controls and Evaluation of Contact Plate Findings Miscellaneous Environmental Standards and EMS Related Discussions 9
F Clinical Evaluation for Class I Medical Devices , needed? EU Medical Device Regulations 11
D Clinical Evaluation - Required Qualification - Class IIa Medical Devices EU Medical Device Regulations 16
amjadrana Customer Returns Evaluation Ownership - Medical devices Customer Complaints 5
S CE Marking - Medical Devices - Clinical Evaluation to 2007/47/EC EU Medical Device Regulations 6
shimonv Clinical evaluation report for class I device EU Medical Device Regulations 2
P GSPRs / Clinical Evaluation EU Medical Device Regulations 3
silentmonkey Overall Benefit/Risk Analysis - Risk Management VS Clinical Evaluation ISO 14971 - Medical Device Risk Management 3
Q Summative Usability Evaluation Testing: prior or during Clinical Investigation? Human Factors and Ergonomics in Engineering 6
S Regular updates of clinical evaluation report EU Medical Device Regulations 6
K Surface finish (Evaluation Length) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
M Clinical Evaluation Benchmark vs. Equivalent EU Medical Device Regulations 2
M IVDR and Performance Evaluation Plan CE Marking (Conformité Européene) / CB Scheme 2
S User evaluation for self monitoring blood glucose test systems US Food and Drug Administration (FDA) 4
S Australia TGA Clinical Evaluation Report (CER) Other Medical Device Regulations World-Wide 0
S API Spec. Q1 clause 5.6.1.2 On site evaluation Oil and Gas Industry Standards and Regulations 10
B Biological evaluation plan and report Other Medical Device Related Standards 5
F Biocompatibility evaluation for Hardware/Interface Components? Other Medical Device Related Standards 12
B Clinical Evaluation Expert Panels - MDR EU Medical Device Regulations 1
dgrainger Informational MDCG 2020:13 - Clinical evaluation assessment report template EU Medical Device Regulations 0
S A clinical performance evaluation study with an IVD product as Investagional Use product - Clinical Monitor requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
B AS9100 8.4.1 Supplier Selection/Evaluation criteria and reevaluations AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
R Clinical evaluation without clinical data - MDR Article 61(10) EU Medical Device Regulations 8
M Clinical Evaluation Plan vs. PMCF Plan EU Medical Device Regulations 24
K Biocompatibility evaluation of gas pathways Medical Device and FDA Regulations and Standards News 5
T HF testing / Summative evaluation for MDDS class I necessary? Human Factors and Ergonomics in Engineering 2
N Evaluation of service providers Supplier Quality Assurance and other Supplier Issues 2
