Every good documentation practice observation is an data integrity issue
every GDP observation is Data Integrity Issue
  • Every GDP is DI Issue
    Votes: 1 50.0%
  • Every GDP Investigation need to defend why it is not DI Issue
    Votes: 1 50.0%
  • Every GDP evaluation for 'Impact' will lead to DI scope of action.
    Votes: 0 0.0%
  • Others!
    Votes: 0 0.0%
  • Total voters
    2
v9991
v9991
ok, let me try to rephrase the question...
* How do you differentiate data integrity aspects vs documentation practices in your incident sop
* is there a checklist u follow to evaluate the incident wrt data integrity!
John Broomfield
v9991,
Information is meaningful data.
Naturally, we try to avoid collecting invalid data from our measurements and observations for which you’d have to study the applicable testing, inspecting and auditing processes.
And data analysis is meant to exclude invalid data.
But valid data does not become documented information until the data are analyzed.
So, in PACA (prevention comes first!) if we suspect the integrity (completeness, accuracy) of the data we may design and conduct a study to determine or verify the facts.
Rarely, in my experience, does a data integrity problem become a documented information control problem.
Why are you jumbling data integrity with the control of documented information?
John
v9991
v9991,
John
Thank you helping me understand and ask the question correctly,.
the question is at system and process level of implementation of incident management procedure.
consider following scenario,
a. observation on 'online documentation of a log book or ongoing process" ' is reported or it is noted during the self-audit.​
a.1couple of other observations are also noted in the past.​
a.2 for scenario of 'reported incident', there could be unnoticed instances of online documentation​
a.3 for self audit observation, that certainly does not cover all.​
'online documentation' falls under "contemporaneous documentation". hence 'data integrity';
and hence the question on differentiating the DI vs Documentation practices.
b. similarly observation on " documentation on informal sheets or personal notebooks" reported or it is noted during self-audit.
and here the it is not 'traceability' and 'attributable' and 'accurate' and have data integrity.
hence the question where and how do your differentiate the DI vs Documentation practices
John Broomfield
As in “I made the record at the end of the shift”?
Or
“I created the record just before I checked my own work”?
Yes, both of these tardy activities could result in inaccurate, false or fraudulent records.
By the way, “self audit” is a contradiction. You can check you own work but not audit it.
v9991
Or
(y)AGREE.
and my question is how/what are the Data integrity points integrated with respective observation / incident .
are there any standard references / processes defined.
is there any standard practices
(y) i meant to indicate internal-audit.
John Broomfield
v9991,
Thanks.
Contemporaneous records are widely accepted as good practice in many industries, including pharma.
At first glance ISO 9001 is silent on this until you think about this requirement specified for record keeping:
“Documented information needed to be retained by the organization for the purpose of providing evidence of result achieved (records). These include:
Documented information to the extent necessary to have confidence that the processes are being carried out as planned
From: ISO/TC 176/SC2/N1286 Guidance on the requirements for Documented Information of ISO 9001:2015
Clearly, if the records are not kept at the time then we lose confidence in them. And confidence may diminish further as time passes.
Your organization may need to specify a requirement for timely record keeping.
Meanwhile here is a presentation on the subject:
http://asq.org/audit/2017/10/auditi...-not-just-for-the-pharmaceutical-industry.pdf
By the way, if you come across tardy record keeping, ask the supervisor or the users of the records how they feel about it. You may find that they would have little or no confidence in a tardy record. You then have your evidence of a nonconformity. You may write the nonconformity a little differently if you had evidence that the supervisor had failed to require contemporaneous record keeping or had not been monitoring and correcting record keeping.
Best wishes,
John
J Readiness review documentation - Every TS requirement has to be addressed in the QM? IATF 16949 - Automotive Quality Systems Standard 15
R Not every INCIDENT report will lead to a corrective action EU Medical Device Regulations 7
T AS9100D Clause 10.2.1g Supplier Corrective Action for each and every nonconformity? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
J Can signed agreements over-ride review of every "contract" under ISO 13485:2016? ISO 13485:2016 - Medical Device Quality Management Systems 2
C ISO 13485 :2016 - CAPA - Does every CAPA need to be checked by regulations? ISO 13485:2016 - Medical Device Quality Management Systems 9
V Supplier wants to perform pre-qualifications prior to every run instead of locking in parameters. Supplier Quality Assurance and other Supplier Issues 7
M CE Mark and 510(k) -Global registration requirements for every country Other Medical Device Regulations World-Wide 3
D Are medical device companies required to document every change made to their website? Document Control Systems, Procedures, Forms and Templates 2
D Does every piece of equipment used in a laboratory need to have an IQ protocol written and executed? ISO 13485:2016 - Medical Device Quality Management Systems 5
E Does every metallic part have to be protectively earthed (class I ME)? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
R In a software development company: Is every bug reported by the customer a complaint? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
U SI 13 - Not Every Process Requires an Efficiency Measure IATF 16949 - Automotive Quality Systems Standard 1
Howard Atkins MSAs are now required on every feature of the control plan - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 13
K Is evidence of second party audits required for every supplier? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S Interpretation or Definition of ‘Once Every 5 Days’ ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Defect Rate for asking for an RMA - Company wants an RMA for every defect found Supplier Quality Assurance and other Supplier Issues 10
A Is normal for FORD EU ask for the PSW every year APQP and PPAP 5
A Identifying context for every process in an organization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 43
J Is it sufficient to send in my instruments for calibration every second year? Manufacturing and Related Processes 2
U Must every procedure be proceeded by a policy? Document Control Systems, Procedures, Forms and Templates 2
A Personal names in docs - Goes against every documenation practice I know! Document Control Systems, Procedures, Forms and Templates 30
D Anyone Practicing Approval Signatures on Every Page of a Doc? ISO 13485:2016 - Medical Device Quality Management Systems 2
S Conduct Customer Satisfaction Survey for every submitted Bid? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
I Run a batch every year to revalidate the validated condition? Qualification and Validation (including 21 CFR Part 11) 4
O Is a full Internal Audit cycle every year required? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
A Is it mandatory to revise MSDS every three years? ISO 14001:2015 Specific Discussions 3
L Does every document on a project require a document number? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
P Audit Design Process every Surveillance Audit - AS9104 Requirement? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
Ajit Basrur 10 Things Extraordinary People Say Every Day Coffee Break and Water Cooler Discussions 5
K Autoclave Log - Do we have to monitor the usage for every load? General Measurement Device and Calibration Topics 3
Y Must every Process have a Quality Objective? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
A Addressing every clause in ISO 17025 ISO 17025 related Discussions 1
N New to ISO 9001 - NCR for every defect? Nonconformance and Corrective Action 5
A Do controlled documents require a signature on every page as per 21 CFR 820.40? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
D Are signatures required on every page of a controlled document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
K Customer issues invalid SCAR and Chargeback every March Customer Complaints 6
F Is every activity required to be mentioned in BSC strategy map ? Quality Tools, Improvement and Analysis 1
C Does every procedure need to be included within a policy? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
J Does Every Staff need to read the ISO9001 Quality Manual from Cover to Cover? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
A Shall we raise SCAR/CAR for every defect as per our current procedure? Nonconformance and Corrective Action 4
Q 510K Checklist that considers every Design Change 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
V Do I need dimensionals performed for PPAP for every revision change? APQP and PPAP 2
E Every US state has Medical Device Regulations beside FDA Regulations Other US Medical Device Regulations 11
T Living Documents which change every day - Control or Uncontrolled? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
Q Drawing Review Records Required for every Drawing (Print)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A Process Objectives and Metrics - Should every documented process have objective? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T Is a Nonconformance Report required for every Customer Complaint? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
C BMU=CMC for every Calibration? ILAC Policy Clarification Measurement Uncertainty (MU) 3
K Must every CCP (Critical Control Point) have a (documented) procedure? Food Safety - ISO 22000, HACCP (21 CFR 120) 4
