Evolving Quality Levels - Expectations for Lowered Defect Levels
Golfman25
#11
99.8% has been the required quality target for our biggest customer for years. Below that, you get lots of “help” from the customer and less new business. It is darn hard to meet, and it has taken lots of different tools for us to get there.
Part of the answer is forming good relationships with the customer’s QE’s that I have to deal with. With targets like this, every little bit helps, and if you are able to form a good relationship and are proven to be an honest and trustworthy person, sometimes you get the benefit of the doubt when the cause is in that grey area between “their fault” or “our fault” or “purge stock” or “no need”.
Also, just like your sampling plan, the customer will usually not detect every nonconforming part. If it is something minor like the flange on a part is .003” OOT but it still fits when the mechanic grabs the part to bolt it on, no one knows. Does that mean you can or should “slip in” those bad parts and try to sneek them past your customer? No! But in reality, no matter what way you measure quality, you are not likely catching every defect, and neither are the customers. What you measure is best-case.
And of course it takes good old fashioned, best-effort based on what you can afford to do and still stay in business, QA and QC practices. Take PA and CA seriously. Hire good people. Treat them well. Walk the talk.
If it is .003 OOT but stil works is it a defect? To me the biggest thing is over dimensioned parts.
#12
An alternative perspective is that this is a 'fit' interaction. A part might be slightly out of spec on the large side and still fit IF the mating part is on the accomodating side of it's tolerance...
Of course, it could be a specification that is too tight
And I've seen specifications set too generously. I actually encounter this condition more frequently the other two above. The part causes failures in the end system, but is completely in tolerance.
Ninja
Looking for Reality
#13
<snip>.... The part causes failures in the end system, but is completely in tolerance.
I work in the multilayer electronics industry.
If a single plant going from raw ceramic powder, through forming, punching, shaping, printing metallization, stacking, lamination, singulation, firing, reduction, deburring, termination, buffing, testing, lead attach or pre-plating, to the end product...it is simply not possible to spec 100% output.
It is totally possible to have all steps "in tolerance" and have 0% yield.
The process, by nature, relies on one off-mean step to be balanced by a subsequent process off-mean the other way.
The best quality increase IMO was the automation of high speed 100% test.
It some days amazes me that product is ever made in spec....but it is, and a whole lot of it. The deeper you look into each of the process dependencies, the more awed (or terrified) you can become.
Zero defect without high speed 100% test is simply a ridiculous concept in this industry. (though folks still ask for it)
:2cents:
P
PaulJSmith
#14
Up until recently, I've worked nearly my entire career in electronics, Ninja. So, I completely understand the "awe" of things that probably shouldn't work ... yet they do ... somehow.
Zero defects is everyone's goal, of course. However, there are many situations where it's simply not reasonable to expect it 100% of the time.
Golfman25
#16
By the ISO definitions, no. But it IS nonconforming. Nonconforming product doesn't meet specifications. Defective product doesn't work as intended.
Fair enough. So if we are looking for zero defects = as long as it works?
Problem is many rejections are for non-conforming product not defective. Seems like a waste of resources to chase non-conformances for product which otherwise works fine. IDK?
howste
Thaumaturge
#17
That's why when your car has a problem you take it in for repair and not rework. All you care about is if it works. Rework is often more expensive.
ISO 9000:2015 said:
repair
action on a nonconforming product or service to make it acceptable for the intended use
ISO 9000:2015 said:
rework
action on a nonconforming product or service to make it conform to the requirements
If a design-responsible organization is proactive about saving money they should look at rejects and relax specifications where a part is just as functional with wider tolerances. However, there may be cases where a nonconforming part is functional, but with a reduced level of performance, so watch out...
normzone
#18
:2cents:
We're the folks that put your products in assemblies, and we do 100% burn-in and test, via combined manual and automated, and we still have component failures at this stage. Fortunately, assembly return rate for in warranty component failures runs under 0.5% for us.
#19
Yes if the specifications are truly too tight, they should be changed rather than simply rejecting good parts.
However, in the case of mating parts the interaction of the part dimensions is what counts. the match up is typically random such that an out of tolerance part might fit fine with one part but not with another part...this is the dilemma of tolerancing mating parts.
Also as Howste alluded to, mating parts have an additional requirement regarding wear. they may fit today, but will wear and break tomorrow. this was the exact point of the famous ford-mazda transmission study and the original purpose of Cpk. (not the current abomination that tries to equate continuous data distributions to number of out of tolerance parts.
As miner said (in another post thread?) this line of discussion points out the real need to have better designs and more collaborative robust causal analysis when failures inevitably occur.
normzone
#20
Yes if the specifications are truly too tight, they should be changed rather than simply rejecting good parts. ... this line of discussion points out the real need to have better designs and more collaborative robust causal analysis when failures inevitably occur.
I wish everybody I worked with thought this way ...
:bonk:
V Evolving QA from 'Compliance-based' to 'Science/Risk-based' approach US Food and Drug Administration (FDA) 2
M Tracking Materials and Tooling - Evolving to Real Life Misc. Quality Assurance and Business Systems Related Topics 8
RoxaneB How is your BMS (Business Management System) evolving? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
N Guidance - Cost of Good Quality Misc. Quality Assurance and Business Systems Related Topics 2
D Quality plan for moving locations ISO 13485:2016 - Medical Device Quality Management Systems 3
was named killer Job Opportunity-Quality Engineer-Tampa Florida Job Openings, Consulting and Employment Opportunities 0
Marc Job Opportunity – Quality Assurance Specialist - Suspense 7 April 2021 Job Openings, Consulting and Employment Opportunities 0
J Quality Objective for QMS prior to Certification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
J Quality Objectives and resources ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
M PSA Suppliers - CSR matrix and need the quality manual of PSA APQP and PPAP 2
A Quality Control Datasheets Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
T Quality auditor legal right to see Board meeting minutes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
D Any recommendations on where to find experienced quality hires in Chicago area? Job Openings, Consulting and Employment Opportunities 3
C Budgetary cost to obtain ASME NQA-1 Quality Program Certification Quality Management System (QMS) Manuals 0
O Soft and technical skills for a VP of Quality Career and Occupation Discussions 1
P MedWatch Report from a hospital due to a quality issue US Food and Drug Administration (FDA) 5
Sidney Vianna Release of ISO 10013:2021, Quality management systems – Guidance for documented information Other ISO and International Standards and European Regulations 0
M Unique Quality Management System for 2 sites ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
G Application to Chartered Quality Institute - MCQI ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 2
K Quality Agreement MDR - The manufacturer is outside of EU Other Medical Device Related Standards 4
Sidney Vianna Informational APQP4Wind - Advanced Product Quality Planning for the Wind Power Supply Chain APQP and PPAP 3
T 21 CFR 820.20 - Quality Planning Requirements? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S Supplier protocol for the Quality Supplier Quality Assurance and other Supplier Issues 6
bruceian Software Quality Metrics Software Quality Assurance 11
R Quality System Functional Safety Checklist / Guidance IATF 16949 - Automotive Quality Systems Standard 0
Bev D Essential References for Practical Quality Engineering Misc. Quality Assurance and Business Systems Related Topics 0
optomist1 Automotive News The Cost of Inspecting In Quality IATF 16949 - Automotive Quality Systems Standard 7
O Any info on release date of FDA “Computer Software Assurance for Manufacturing and Quality System Software” document? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
M Quality Manual - Where does Revision History Section go? Document Control Systems, Procedures, Forms and Templates 8
John Broomfield CIOB - Code of Quality Management Misc. Quality Assurance and Business Systems Related Topics 1
S Quality Audit Training Activities Quality Manager and Management Related Issues 2
D Are Supplier Quality Agreements Quality Records ? Other Medical Device Regulations World-Wide 9
D Big companies suffer from quality management system? ISO 13485:2016 - Medical Device Quality Management Systems 1
K Looking for a job as Quality Engineer Career and Occupation Discussions 2
B Two excellent examples of process capability analysis from Quality Magazine Capability, Accuracy and Stability - Processes, Machines, etc. 5
Pau Calvo Quality Management process is mandatory in ISO9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
NDesouza No Quality Professional vs Having a Quality Professional Benchmarking 24
F Does anyone have an ESD quality/cooler talk to share? Training - Internal, External, Online and Distance Learning 4
R Monitor production quality - Internal KPIs Manufacturing and Related Processes 5
U Examples of Quality Objectives for a Medtech start up ISO 13485:2016 - Medical Device Quality Management Systems 4
M SemaTech SSQA Standardized Supplier Quality Assessment - my favorite tool ever Manufacturing and Related Processes 1
D Supplier Quality level category help - high level ISO 13485:2016 - Medical Device Quality Management Systems 6
R How would you work without a quality management system? IATF 16949 - Automotive Quality Systems Standard 3
P Conformity assessment based on a quality management system or production quality assurance EU Medical Device Regulations 3
H Updating Quality Manual to API Q1 Service Industry Specific Topics 6
R Electrical contractor Project Quality Management Plan Quality Manager and Management Related Issues 1
D Supplier Quality - How to classify a supplier level Medical Device and FDA Regulations and Standards News 10
R China Quality Certification Various Other Specifications, Standards, and related Requirements 1
