Example ISO 17025 Quality Manual wanted
Al Dyer
#11
Lynn,
Call some registrars and discuss the situation and see if they will give you a copy of what they "particularly" will look for in a desk audit.
This might help you define the levels of documentation that you want to proceed with.
You are the customer, and as such I am sure you are already looking at Registrars. Tell them you will not consider them until you get a copy of their expectations!
MHO!
ASD...
Al Dyer
#13
Originally posted by lily:
Hi!
Can manufacturer's inserts be used instead of documenting the test method ?
Sure they can, but think of the following:
- The situation will need to be addressed in your document control procedure.
- What would be the methodology to ensure current revision levels and updates to the document?
- How much time would it take to just transcribe the instructions into your own (Word) document and control it under the current method?
Just a couple of items to consider.
ASD...
Ryan Wilde
#14
ASD...
I'll throw in a strong reason for using manufacturer's procedures under a 17025 system. Two words - Method Validation. The manufacturer (should) know how to properly test the device. But, in the instance that you have only a few procedures to deal with (<100) I would write my own and document that the method is from the manufacturer, as Al stated.
Document control of manufacturer procedures is a nightmare in most cases, as most manufacturers do not tell you when the procedure has been updated, and most often you must pay for the new procedure. My company uses literally thousands of procedures, and to pay $40 each every few years would be financial suicide.
Another problem with manufacturer's procedures is the equipment that it calls out for use. No lab has everything that every mfr procedure calls out, and substitution on the fly requires quite a time investment in researching what you have, what its uncertainty is, possibly several items to perform the function of one, and so on. The ability to make proper, informed decisions on this substitution is quite often out of the realm of the standard technician, and again, the substitution must be validated. You would save time in the long run by importing the document and tailoring it to your exact capabilities.
In other words - What Al said.
Ryan
Marc
#15
I have to agree with Ryan. In addition to everything else, I don't see this as a revision sensitive issue. Or, when so, extremely rarely. They're generally relatively streight forward and 'aimed' at teches who do such work.
As far as addressing it in one's procedures, I would include the explaination as a simple statement.
This should be looked at in the context of how you're handling control of equipment manuals (manufacturing, M&TE, whatever). A lot of companies do Preventive Maintenance according to the manufacturers manual(s) as opposed to originating an in-house maintenance procedure.
Don't over document. Never repeat that which is already written elsewhere.
Marc
#16
Hi!
The comments on this have been good, but this is really off the original topic,
-> I am currently preparing to organize a quality manual
me thinks. Remember folks - it's easy to start a New Topic! ;)
sunilgaidhani
#17
Re: Seeking a copy of a quality manual geared towards ISO 17025
Really good one to list down all the policies and procedures, I m also the beginer and will try this.
Lynn,
Here is a tip that really helped me out (and I've been through a few of these). Make a copy of 17025 that you would not mind writing all over (mark it as "Reference", "Uncontrolled") and read each clause. With a highlighter, highlight EVERY "shall have procedures" and every "shall have policies". Then go through and index them.
Example:
Clause----Requires-----------Description---------Accomplished
4.10.1----Policy/Procedure---Corrective Action---[checkbox]
From this index of the entire standard(it will be fairly long) you will know what you need to write and to what level.
Unless your assessor is very different than those I've encountered, if it says to have a procedure, you had better have a separate procedure for it. If it says to have a policy, it had better be written as a policy. Many of the clauses only require addressing, probably only at the quality manual level, and I've found it best to keep those very short and simple.
Just my opinion...
Ryan
Marc
#18
Example manuals here: There are only a couple, they can serve as beginning examples to give you ideas.
The manual does not have to be organized along the structure of the standard.
Does anyone here have an example manual they can share to add to the collection?
Example ISO 17025 Manuals
Also see these related existing discussion threads: ISO 17025 Manuals
D Laboratory Manual ISO/IEC 17025 Example wanted ISO 17025 related Discussions 2
C Example of Management Review Meeting Minutes - ISO 17025 ISO 17025 related Discussions 9
R Example of ISO/IEC 17025 Implementation Project Plan ISO 17025 related Discussions 8
R ISO 17025 .pdf Example Quality Manual Attached ISO 17025 related Discussions 3
T ISO 17025 Validation Procedure - Need Example ISO 17025 related Discussions 11
L ISO 17025 - Seeking Example Quality Manual ISO 17025 related Discussions 6
D Test summary report example for design validation wanted - ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 1
F Hi friends, can anyone show me an example of a procedure for ISO 13485 6.4.1 Work Environment? ISO 13485:2016 - Medical Device Quality Management Systems 2
D Monitoring and measuring resources - Example of how section ISO 9001 7.1.5 would apply to a manufacture of software ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A ISO/TS 22163 Item 5.2.4 Safety policy - Example wanted Other ISO and International Standards and European Regulations 2
MichaelDRoach Oganization's Self Declaration of Conformance to ISO 28000 wording example wanted Supply Chain Security Management Systems 1
J ISO 13485 8.4 Analysis of Data - Procedure example ISO 13485:2016 - Medical Device Quality Management Systems 1
N ISO 9001: 2015 - Example standards policies, procedures, acknowledgements and checklists ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
P Template or example Excel list of ISO certificates issued to clients ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M Example ISO 14971 policy and risk criteria ISO 14971 - Medical Device Risk Management 0
D Where I can find an ISO 13485:2016 Audit Schedule example? ISO 13485:2016 - Medical Device Quality Management Systems 4
T Process Matrix for ISO 9001 - SRI requests R.20 44KO Sample/Example ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Looking for ISO Class 8 Cleanroom Cleaning Procedure example ISO 13485:2016 - Medical Device Quality Management Systems 1
J ISO 13485 Training Documentation example wanted Training - Internal, External, Online and Distance Learning 15
S ISO 9001:2015 Transition Project Plan example wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
K Example of ISO 10007 - Configuration Management Plan AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
J Does anyone have an example of Risk-Benefit Analysis per ISO 14971? Other ISO and International Standards and European Regulations 2
Z ISO 17020:2012(E) Quality Manual Example for a Asbestos Consultancy Quality Manager and Management Related Issues 2
I Interior Design Company Design Procedure Example wanted (ISO 9001:2008) Design and Development of Products and Processes 3
0 ISO 5725 Project Plan example wanted General Measurement Device and Calibration Topics 8
Q Provide Example(s) for ISO 9001 7.2.1 (b) and 7.2.1(d) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
SATHYABALARAMAN ISO Systems Annual Report to Top Management example wanted IATF 16949 - Automotive Quality Systems Standard 10
L ISO 13485 Internal Audit Schedule example needed Internal Auditing 9
A Information Technology Process Mapping per ISO 13485 - example wanted Process Maps, Process Mapping and Turtle Diagrams 1
A Human Resources (ISO 13485 Clause 6.2) example of SOP ISO 13485:2016 - Medical Device Quality Management Systems 1
T New to ISO 14001 - Need example of Environmental Aspect/Impact for a HVAC Contractor ISO 14001:2015 Specific Discussions 3
S Lead Auditor ISO 22000:2005 Example Exam Questions Food Safety - ISO 22000, HACCP (21 CFR 120) 3
D ISO TS 29001 (Petroleum Petrochemical Natural Gas) - Internal Audit Checklist example Other ISO and International Standards and European Regulations 3
P ISO 20072 Requirements - Example or template of a DFP (device functionality profile) Other Medical Device Related Standards 2
C Does anyone have an example of an ISO 14001 Internal Audit Schedule ISO 14001:2015 Specific Discussions 2
S Purchasing Process Map for ISO 9001 and ISO 13485 - Example wanted Process Maps, Process Mapping and Turtle Diagrams 5
E Implementing ISO 9001 and an Example of a Quality Manual anyone? Document Control Systems, Procedures, Forms and Templates 6
V ISO 27001 Sample Scope Statement example wanted IEC 27001 - Information Security Management Systems (ISMS) 4
A Purchasing Procedure example as per ISO 9001:2008 wanted Document Control Systems, Procedures, Forms and Templates 2
A ISO 14001 3rd party Audit Plan example wanted ISO 14001:2015 Specific Discussions 5
P ISO/TS 16949:2002 - Internal Laboratory Scope - Post good example please! IATF 16949 - Automotive Quality Systems Standard 5
P Example ISO 13485 Quality Manuals/Systems Quality Management System (QMS) Manuals 6
Sidney Vianna What about the Social Responsibility of ISO and TC176? Failure to show by example? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 12
P EMS (Environmental Management System) ISO 14001 Audit example wanted ISO 14001:2015 Specific Discussions 16
B Example of an ISO 9000-2000 QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
F Example or Definition of Engineering Specifications - ISO/TS 16949 - 4.2.3.1 IATF 16949 - Automotive Quality Systems Standard 3
E ISO / TS16949 Quality Manual example needed Quality Management System (QMS) Manuals 2
I Statement of Applicability per ISO 27001:2005 Information Security - Seeking Example Other ISO and International Standards and European Regulations 5
Ajit Basrur Quality Plan for ISO 9001 and ISO 13485 - Template or Example Needed Document Control Systems, Procedures, Forms and Templates 29
J Rockwell (Honeywell) example manual of ISO 9001 and ISO 14001 combined Quality Management System (QMS) Manuals 5
