Example of a P-Diagram for Process FMEA - Uncontrollable noises
By definition all noise is uncontrollable. You might be able to control it for a short period of time, but it is ultimately not feasible or too expensive to control long term.
Noise may be categorized into the following:
  • Piece to piece variation (design tolerances, manufacturing variation, operator variation, process stream variation, tooling/cavity variation, etc.)
  • Changes over life variation (machine/tooling wear, shrinkage/expansion, compression set, etc.)
  • Internal environment variation (manufacturing/storage conditions, system interactions, component clearances)
  • Customer usage variation (application, misuse)
  • External environment variation (application conditions: temperature, humidity, shock & vibe, etc.)
By noise do you mean sounds? or random variation in the data? or perhaps conditions that effect your product that you might think are uncontrollable?
I think by referring to a p-diagram the OP intended uncontrollable factors that cause random variation in the output. Noise is a category used in p-diagrams.
I looked at the site Miner referenced. The paragraph that addresses 'noise' is quite interesting:
"Noise Factors are things that can influence the design but are not under the direct control of the engineer, such as piece-to-piece variation, normal degradation of materials or equipment over time, intended and unintended customer usage, foreseeable environmental conditions and system interactions. These noise factors, if not protected against, can make the design ineffective; in other words, the design should be robust against the expected noise factors."
With this context I can understand why Miner said the noise factors can't be controlled.
I've always disliked the term 'noise' when used as a descriptor of factors as it is too vague and easy to misinterpret it and it often different meanings in different contexts...meh.
Jimmy123
Thanks, this is what I know from a Ford training, too. Now, the new AIAG Handbook shows a P- Diagram for PFMEA too. But in the example, they show the 4M, what are Process elements and not noise factors in my understanding. Therefore I ask, if someone have tried to use the P-Diagram for a Process. I think this could be done, but only with the same systematic like above. Is PTP Variation, the Variation of machining? It would be great if someone can show an example.
The 4P can work as well, but I think it is less focused than the 5 noise categories. In addition 4P applies to the inputs and control factors as well. It is a step in the wrong direction.
Yes, part 2 part variation would include variation due to machining. Few people will be willing to share this as it will be viewed as proprietary information. Have you tried searching for "parameter diagram images"? There are numerous examples online.
Jimmy123
I think, we are on the same path:). Yes, I have tried to find one, but not successfully for a process.
Jimmy123
Dear Miner, could you please explain me, what 4P stand for?
O Example of Turtle Diagram with Risk/Opportunities General Auditing Discussions 1
C IT Internal Audit Turtle Diagram example wanted Internal Auditing 3
B Example Turtle diagram needed Process Maps, Process Mapping and Turtle Diagrams 3
Anerol C Corrective Preventive Action Turtle Diagram example needed Process Maps, Process Mapping and Turtle Diagrams 6
Anerol C In Charge of Safety - New- Safety program Example Occupational Health & Safety Management Standards 6
Eva lee Which is the range for the validated batch size(for example ±5%, 10%) is acceptable? Manufacturing and Related Processes 6
A Control plan for IATF - example? FMEA and Control Plans 1
J Drawing Example Request: Inspection Section Plane of Aluminum Casting Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
A Attribute , for example C chart Statistical Analysis Tools, Techniques and SPC 16
J Example of a defined procedure for carrying out Material Review Board (MRB) Manufacturing and Related Processes 0
S IATF 16949 Internal Audit Example IATF 16949 - Automotive Quality Systems Standard 18
optomist1 Paynter Chart Example APQP and PPAP 1
M Data Protection and Privacy Policy - looking for a template/example EU Medical Device Regulations 1
A Verification protocol example Design and Development of Products and Processes 2
Q Example Process orientation to the process leadership, management, goals (tasks of the top management) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Q Example of the Risk Template Document Control Systems, Procedures, Forms and Templates 1
D Test summary report example for design validation wanted - ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 1
M Risk managment report of Surgical Mask Example ISO 14971 - Medical Device Risk Management 14
M Example of statement for procedure pack MDR Article 22? Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 0
A 5 x 5 Risk Matrix - Looking for a good example Manufacturing and Related Processes 2
N Post Market Surveillance Package Example Wanted ISO 13485:2016 - Medical Device Quality Management Systems 1
D Calibration Process Flow Map Example Wanted General Measurement Device and Calibration Topics 3
D Redacted 510(k)s - Example wanted Document Control Systems, Procedures, Forms and Templates 17
F Hi friends, can anyone show me an example of a procedure for ISO 13485 6.4.1 Work Environment? ISO 13485:2016 - Medical Device Quality Management Systems 2
DuncanGibbons Looking for example aerospace part CAD files to be used for a case study Career and Occupation Discussions 2
M An example of risk analysis of class I MD ISO 14971 - Medical Device Risk Management 36
D Monitoring and measuring resources - Example of how section ISO 9001 7.1.5 would apply to a manufacture of software ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
D Validation of existing equipment - Risk based approach example ISO 13485:2016 - Medical Device Quality Management Systems 3
A ISO/TS 22163 Item 5.2.4 Safety policy - Example wanted Other ISO and International Standards and European Regulations 2
F Internal Audit - Procedure example Internal Auditing 5
I Functional Safety Analysis/Report Example IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
H Man Hour Plan 145.A.30 example needed EASA and JAA Aviation Standards and Requirements 0
R Real Example of a currently marketed Procedure Pack CE Marking (Conformité Européene) / CB Scheme 1
D Example for Accessories of "Annex XVI non-medical devices" and how to classify it now with respect ot EU MDR Other Medical Device Regulations World-Wide 1
MichaelDRoach Oganization's Self Declaration of Conformance to ISO 28000 wording example wanted Supply Chain Security Management Systems 1
A Australia TGA Medical Device Sponsor Agreement - Example or Template Other Medical Device Regulations World-Wide 21
J ISO 13485 8.4 Analysis of Data - Procedure example ISO 13485:2016 - Medical Device Quality Management Systems 1
S Question about a basic additive variance/tolerance example Quality Tools, Improvement and Analysis 2
N ISO 9001: 2015 - Example standards policies, procedures, acknowledgements and checklists ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M AS9100d (section 7.1.3) example of compliance in machine shop environment. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
supadrai How does the FDA count violations of, for example, misbranding? (Medical Devices) Other US Medical Device Regulations 1
E Labware cleaning validation protocol example Qualification and Validation (including 21 CFR Part 11) 1
D Laboratory Manual ISO/IEC 17025 Example wanted ISO 17025 related Discussions 2
P Template or example Excel list of ISO certificates issued to clients ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
T Example wanted - Template for internal audit IATF 16949 IATF 16949 - Automotive Quality Systems Standard 1
M Example ISO 14971 policy and risk criteria ISO 14971 - Medical Device Risk Management 0
D System Level FMEA example wanted FMEA and Control Plans 2
E Example of 9001:2015 audit report with non-conformances ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A IATF 16949 Cl. 8.4.1.2 Supplier Selection Process - assessment example IATF 16949 - Automotive Quality Systems Standard 11
