Examples of inherent safety by design
Marcelo Antunes
Addicted to standards
Inherent safety by design is related to the option in which the device itself controls the risk (not depending on action by a third party. It was kwon, in some literature, as "unconditional safety".
This include things such as a enclosure to control the risk of electrical shock, a change in device material to remove a toxicological hazard, and a self-destroying device in the case of a single use device.
Marcelo Antunes
Nope, protective measures (as the second option for risk control) depends on action from a third party (such as the operator - that why it was originally known as conditional safety), and the ones I gave, don't.
Roland chung
If I am reading you correctly, protective measures mean reaction.
Does any ISO document try to explain the inherent design and protective measures?
Marcelo Antunes
The best (and most cited) example for a protective measure is an alarm, in which the device tells the user that something is wrong, and the action (or inaction) of the user will control the risk.
There's some conflicting definitions in ISO and IEC documents about protective measures and inherent safe design, so I would take care with them. Anyway, you can find a lot of examples in the risk management literature (please remember that standards usually do not create nothing new, they just standardize good practices from a specific field).
Marcelo Antunes
For example, ISO/IEC guide 51 has definitions for both:
3.5
inherently safe design
measures taken to eliminate hazards (3.2) and/or to reduce risks (3.9) by changing the design or
operating characteristics of the product or system
risk reduction measure
protective measure
action or means to eliminate hazards (3.2) or reduce risks (3.9)
EXAMPLE Inherently safe design (3.5); protective devices; personal protective equipment; information for
use and installation; organization of work; training; application of equipment; supervision.
But the definition of protective measure is really what ISO 14971 calls risk control measure.
Roland chung
In IEC, the protective system is defined to protect the patient against safety hazards which may arise.
Could you please share a typical RM literature?
Marcelo Antunes
I think we are confusing things here, what I mentioned was what is in
ISO 14971 6.2 b) protective measures in the medical device itself
See attached for one example of what I mentioned.
You can also look at classical documents such as mil-std-882, UK HSE documents Reducing risks, protecting people HSE’s decision-making process and Research Report Improving inherent safety and , the FAA system safety handbook, the NASA System Safety handbook, and several others. There's simply too many literature to cite (safety engineering has some 50-70 years of literature on risk management, as it is, and ISO 14971 tries - and not always achieves - to condense those in ONE set of good practices).
