Exceeding the DC Leakage Current Limit
Jaydub
We have a device that includes an enclosure at the end of a 10 foot cable. The earth impedance, with the 10 foot cable is less than .1 ohm and the enclosure is protectively earthed. An important customer is now requesting a 30 ft cable. The 30 foot cable increases the earth impedance above .1 ohms. Clause 8.6.4b allows impedance above .1 ohms, if allowable leakage currents are not exceeded when the relevant insulation is shorted. When I do this, I get a DC leakage current of 118 uA, exceeding the limit of 50 uA. Annex A indicates that the low limit is because prolonged current could cause tissue necrosis. In this case the patient would not be in contact with the device for more than 10 minutes if everything was working. In this SFC, the device will not function and patient would not likely remain in contact for even that long. I can't imagine that this is dangerous. Do you think I could justify through risk analysis that the DC leakage current is not hazardous?
Peter Selvey
There appears to be something wrong with the set up. Shorting the insulation in question should have blown the fuse. Also a dc value, even small, indicates a problem.
Anyway, if it is a non-detachable cord (hard wired at the equipment side), the limit is actually 0.2 ohms. The limit for 0.1 ohms was never intended to include the power supply cord, it is intended for internal earthing (e.g. from the equipment PE terminal to the frame).
Jaydub
Peter,
Thank you for the reply. Apparently I didn't explain the situation very well. What we have is a remote, DC powered module, connected by a cable to a main unit which is mains powered. The cable between the main unit and the remote module is what the customer wants to be 30 feet. The remote module is powered by 15 VDC, through the cable. The 15 Volt supply is fused and if it is shorted, by 0 ohms, to the enclosure the fuse will blow. I assumed that the worst case would be if a fault developed that would cause the maximum current that might not blow the fuse. For the test, I shorted the 15 Volt supply at the remote module and replaced the fuse with a resistor to draw 2.1 times the fuse rating. The DC leakage current, form the remote module to the protective earth terminal (at the appliance inlet) in the main unit is then >50uA.
Peter Selvey
I guess the controller is used by the patient?
The 50uA limit is strictly for applied parts, which means the part the must contact the patient for the function (not parts that could touch, must touch).
If it is an applied part then a higher limit could be justified in risk management. The 50uA limit assumes a small contact area (1mm2), there is a lot of literature including modified limits in other standards which indicates that higher values are OK with a large contact area expected from a controller.
Jaydub
Thank you Peter. I will look into the literature and other standards you mentioned. In an internet search the only thing I found, on the risk from exposure to low value DC currents, was a study on what happens if a battery is swallowed and becomes lodged in the digestive tract.
Peter Selvey
One reference is the appendix of the standard, also noting they refer to long term application (presumably, the controller is not held continuously).
Another reference is IEC 60601-2-10, which allows very high dc levels for use in stimulation partly due to the low current density (gel electrodes, typically around 500mm2 in area, so the current is spread), and partly due to a warning to move the treatment site in long application.
A Calibration Requirements after Exceeding the Calibration Due Date General Measurement Device and Calibration Topics 8
P Is this a Nonconformance - Incubation Period exceeding that in our Procedure. General Measurement Device and Calibration Topics 7
R BMC (Best Measurement Capability) exceeding Tolerance! Measurement Uncertainty (MU) 8
L Thickness not exceeding 2?0.3 mm - Value1 < value2?Value3 Various Other Specifications, Standards, and related Requirements 18
N 60601-2-2 Ed 6 Clause 201.8.8.3.102 - HF instrument leakage IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
M ECG lead leakage currents - How to specify ECG leads during electrical safety testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
W Regarding Requirement for Hi pot & Leakage Current test Station Set-up IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
A Earth leakage current test for Permanently installed Large scale MEE IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
A Touch current in single fault conditions test and earth leakage current in normal conditions test, are they really different tests? IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
T Tests IEC 60601-1 - Grounding Resistance, Leakage Current and Dielectric Rigidity in an automated way IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
S Calibration - Isolated current meter - Measuring patient auxiliary leakage current Calibration and Metrology Software and Hardware 4
S Leakage Current test and Dielectric strength for Battery operated ECG device? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
M Leakage current measurement with non-frequency-weighted device IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
E IEC 60335-1 leakage current measurement Other ISO and International Standards and European Regulations 3
J Measuring Leakage Currents with IEC 60601 defined Measurement Device (MD) IEC 60601 - Medical Electrical Equipment Safety Standards Series 15
P Humidity Pre-Conditioning before leakage current and dielectric strength tests IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
W How can I test the Patient Leakage Current of an Infusion Pump? IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
A Accuracy Calculation of Leakage Current for an Electrical Safety Analyzer General Measurement Device and Calibration Topics 5
M ISO 13485 - Are Earth Leakage Tests Required? ISO 13485:2016 - Medical Device Quality Management Systems 2
L Building your own Leakage Current Tester IEC60990 Other US Medical Device Regulations 4
M Leakage Current Measuring Instrument - IEC 60601-1 Requirement IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
D Patient Leakage ISO 7176-14 vs. IEC 60601-1:2005 Reporting Requirements Other US Medical Device Regulations 1
M IEC60601-1 Battery Powered Body Worn Device Leakage Currents IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
R IEC 60601-2-49 - Touch Current (Enclosure Leakage Current) requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
B Defining Expected Oxygen Leakage for Safety Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A Medical Device Leakage Current Measurement with External Power Supply IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
M Understanding DC Patient Leakage Failure from 0.3VDC IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
R Why DC limits more stringent than AC limits for Leakage Current Test IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
S Whether some paths exist for leakage to get outside the LCD? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
C USB, Clearances and Earth Leakage - Medical Devices IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
J Pre-Conditioning Leakage Current IEC 60601 - Medical Electrical Equipment Safety Standards Series 12
M Operator/Patient Leakage Current IEC 60601 - Battery Charger IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
P Leakage Currents and Patient Auxiliary Current under IEC 60601 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A Leakage current from battery - IEC 60601-1 Medical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 12
K Calibration method for Torque Wrench & AC gas leakage Tester General Measurement Device and Calibration Topics 4
W FMEA - Current control and occurrence rating FMEA and Control Plans 3
S Forced ServiceNow validation - No change in our current user and functional requirements IT (Information Technology) Service Management 4
W Need for current design or process control FMEA and Control Plans 2
E Best way to keep up with pharmaceutical quality knowledge and current affairs Service Industry Specific Topics 1
T Iec 60601 Impedance and current-carrying capability IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
M Informational TGA – Current status of breast implant products in Australia Medical Device and FDA Regulations and Standards News 0
F Proficiency Testing for ISO 17025: AC Current Ranges ISO 17025 related Discussions 1
Q Raising A CAPA on Current CAPA system US Food and Drug Administration (FDA) 3
A SPC for Eddy Current Testing Statistical Analysis Tools, Techniques and SPC 28
A Adding Remote Site to Current IATF 16949 Certification IATF 16949 - Automotive Quality Systems Standard 2
A QMS - Medical Device - New company under a current one ISO 13485:2016 - Medical Device Quality Management Systems 3
K Questions on Technical File to show it is current EU Medical Device Regulations 5
H IS there any database for list of CE marked Medical devices and there current status EU Medical Device Regulations 8
B Mains fuses and OVER-CURRENT RELEASES IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
P Adding an additional distributor to a current Mexico Medical Device Registration Other Medical Device Regulations World-Wide 0
