Excel formula for Ppk needed
jrubio
#11
Short term Vs Long Term
In my oppinion it exist two possibility to meassure the capability (Long Vs Short term).
Preliminary Study (100 parts)
1) 5 parts -> Pp1, Ppk1 (Normal Distribution)
2) 5 parts -> Pp2, Ppk2 (Normal Distribution)
3) 5 parts -> Pp3, Ppk3 (Normal Distribution)
20) 5 parts -> Pp4, Ppk4 (Normal Distribution)
you have 20 pp, ppk therefore you can map a potential preliminary curve haw well is improving your process. the curve tend to be exponential
pp
- - -1-2-3-4-5-6-7-8-9-10-11-12-13-14-14-16----20 (Size)
At this stage the short term ppk, pp is ppk20,pp20 but if you want a long term indez which take into acount all the 100 points as the curve is noraml by the Limit theorema you can add normal distribution and you will have other normal distribution therefore you can calcaulate the pp,ppk with all the 100 part to calculate the pp,ppk aggregated index.
You see that the curve tend to a well pp, ppk (Lets say 3) now you can start with Cp, Cpk
1) 5 parts -> cp1, cpk1 (Normal Distribution)
2) 5 parts -> cp2, cpk2 (Normal Distribution)
3) 5 parts -> cp3, cpk3 (Normal Distribution)
20) 5 parts -> cp4, cpk4 (Normal Distribution)
Tim Folkerts
#12
How much detail do you need?
Basically:
1) enter the all the data
2) calculate the AVERAGE and STDEV for the data
3) Check which is smaller: (USL-AVERAGE)/(3*STDEV) or (AVERAGE-LSL)/(3*STDEV)
Is there something more specific you need help with? The actual use of Excel? The equations for Ppk?
Tim F
jrubio
#13
Basically:
Tim F
Yes it is plus Histogram
#15
Customer requirements aside, histograms can be useful when there are very large amounts of data, but when the number of individuals is relatively small, and you have the basic statistics at hand, a histogram isn't of much practical use.
jrubio
#16
Yes but all this Formulas have no sense if the Distribution is not normal. 100 points is not a low number of points is enough, Ford recomend minimum 3 to 5to obtain the sigma and average and therefore the Histogram.
The Histogram according to my criteria is mandatory.
#17
I don't know whether you're referring to Ford's requirements or your own personal requirements. You'll note that I said, "Customer requirements aside..." meaning that if you have a customer requirement for histograms, then you give them histograms, whether it makes sense or not.
If, on the other hand, you are referring in bold red letters to some personal requirement, I can only say that given 100 data points and the basic statistics, I don't need for someone to draw me a picture. If you do, that's fine. BTW, if you actually do need to see a chart, wouldn't an individuals chart be more useful, especially with regard to time?
jrubio
#18
why cp and not ppm?
Because at the end...
Isn´t it the purpose to obtain ppms. If you not have the Gauss how are you going to calculate?
To be honest I do not understand why Customer ask for Cp, Cpk, Pp, PPk instead of directly in ppm, which must be the useful data for them.
and ppm not depend of the curve, it is always the same ppm.
If someone know please the explanation must be much appreciated.
jrubio
#19
Great. I agree.
Great and logical exposition.
#20
Re: why cp and not ppm?
Statistics such as Cpk are used as tools for prediction. PPM allegedly tells you how many things would be bad if you were to make a million of them, but it really has no predictive value, and makes no sense at all unless you are going to make a million of something. So Cpk and PPM are not directly comparable.
And this thread is straying :topic: .
A Excel OOT (Out of Tolerance) Formula Excel .xls Spreadsheet Templates and Tools 3
S used excel formula calculated the ARL's with Rule1&Rule2 for Shewhart control chart Statistical Analysis Tools, Techniques and SPC 0
P IF formula - Excel 2003 Excel .xls Spreadsheet Templates and Tools 4
F How to Calculate the unbiased Standard Deviation in Excel using Minitab Formula Capability, Accuracy and Stability - Processes, Machines, etc. 6
F Excel I want to use the count I get in another formula Excel .xls Spreadsheet Templates and Tools 13
M Formula for Bell Shape in Excel Using Minitab Software 1
N Is there a formula to link words in Excel sheet to a graph? Excel .xls Spreadsheet Templates and Tools 5
F SPC Newbie looking for Excel Spreadsheet formula for a sample size of 40 components Capability, Accuracy and Stability - Processes, Machines, etc. 8
A Bias Linearity Stability MSA Excel File with Formula Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
I AQL Formula in Excel - Calculating Sample Size based on an AQL Chart AQL - Acceptable Quality Level 8
X Microsoft Excel 2003 Formula Restrictions Excel .xls Spreadsheet Templates and Tools 9
S Stability calculation with formula in excel sheet & acceptance criteria Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
D Need some help with a formula in Excel Please! Excel .xls Spreadsheet Templates and Tools 11
V Weibull formula in Excel needs to be verified. Excel .xls Spreadsheet Templates and Tools 46
J CMM Accuracy - Formula for Excel or a spreadsheet Excel .xls Spreadsheet Templates and Tools 20
Manix Excel Formula for Ebay shop fees - Help needed Excel .xls Spreadsheet Templates and Tools 8
S RPN Ranking - Put a formula in an access database or Excel .xls spreadsheet Excel .xls Spreadsheet Templates and Tools 12
A Cpk Formula: Am I using it correctly? Excel .xls Spreadsheet form Excel .xls Spreadsheet Templates and Tools 14
L What is the Formula for Cpk in Excel? Excel .xls Spreadsheet Templates and Tools 41
J Incoming Inspection Records using Excel File ISO 13485:2016 - Medical Device Quality Management Systems 2
S 95% UCL - Attaching an excel for recovery study Statistical Analysis Tools, Techniques and SPC 0
T EXCEL - How do I make the cell stay blank until a date is entered in N7? Excel .xls Spreadsheet Templates and Tools 6
Ed Panek Validating Excel (XLS) formulas 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
C Template for Excel Validation Reliability Analysis - Predictions, Testing and Standards 6
R Gage R&R Excel templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S Issuing of CoC to Customer in a Word or Excel format ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Ajit Basrur Track audit findings on Excel tracker Excel .xls Spreadsheet Templates and Tools 9
J Does anyone have an excel IATF 16949 Internal Audit checklist I could use? IATF 16949 - Automotive Quality Systems Standard 7
S Anyone Familiar with "SPC for Excel" add-in? Lean in Manufacturing and Service Industries 4
P Commercial excel templates that calculate overhead, hourly rates, fee proposal Excel .xls Spreadsheet Templates and Tools 0
I Cannot Export multiple sections from Excel to PDF without losing pagination Excel .xls Spreadsheet Templates and Tools 23
M Matching two matrices in Excel Excel .xls Spreadsheet Templates and Tools 5
J Level 3 KPI Excel Template Manufacturing and Related Processes 1
bobdoering Informational New AIAG PFMEA Process - Excel Template Attached FMEA and Control Plans 23
GreatNate Excel PPAP Tracking templates or tool wanted APQP and PPAP 1
E Part 11 Compliance, Excel living documents (i.e. document master list, equipment list, approved supplier list) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
J ISO 9001:2015 Excel Gap Analysis wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
B AS9110 Audit Check Sheet wanted Excel or Word Document AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
G Excel report with pictures Excel .xls Spreadsheet Templates and Tools 5
A Query regarding MS Excel usage Excel .xls Spreadsheet Templates and Tools 2
D Asterix when pasting a column of values from Excel into Minitab (V17) Using Minitab Software 5
Y Excel Automation - Printing Word Documents from within Excel Excel .xls Spreadsheet Templates and Tools 0
S Help me build an Excel Spreadsheet for tracking training Training - Internal, External, Online and Distance Learning 14
P Template or example Excel list of ISO certificates issued to clients ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M Medical Device Process validation, Validation of excel spreadsheets used for process Other Medical Device and Orthopedic Related Topics 4
C Excel date format from Denmark to USA Excel .xls Spreadsheet Templates and Tools 6
G ISO 9001:2015 - Is control possible with Excel adaptable measurement sheets? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
N Where I can find an Excel sample/template for recording Delivery Time and Cost Excel .xls Spreadsheet Templates and Tools 2
D How do I go about creating document logs and registers with the MS Excel Excel .xls Spreadsheet Templates and Tools 2
D Microsoft Excel database to Stand-alone software Calibration and Metrology Software and Hardware 3
