Excel spreadsheet shows weird CPK outcome
s14realm3
something weird with CPK results on my spreadsheet that I was given.
nomial value- 20.729
tolerance - .50
max spec- 20.66
min spec- 20.16
avg- 20.72
Std Dev- .04
CpK- 4.01
Cp- 4.1
21 pc data sample-
20.751 20.710 20.751 20.694 20.711 20.736 20.729 20.741 20.790 20.730 20.766 20.692 20.753 20.677 20.705 20.759 20.702 20.632 20.654 20.658 20.747
Is the CpK really correct at 4.01?
seems really high. I thought maybe since our tolerance is big (plastic injection) BUT a 4+ CpK? :confused:
Johnny
David DeLong
Re: excel spreadsheet weird CPK outcome
Please note that your average is outside the upper spec limit so your program just didn't know how to calculate the Cpk which would be a negative number. Disregard the Cpk or Ppk value.
The Cp (or Pp) could be valid though since that calculation does not take into consideration the average of the process.
s14realm3
thanks for your reply David:
here is another example BUT all the data falls UNDER the lower spec. and I have a CpK of 33.24???
nomial value- 2.37
tolerance - .50
max spec- 2.82
min spec- 2.57
avg- 2.37
Std Dev- .005
CpK- 33.24
Cp- 33.49
2.370 2.370 2.380 2.370 2.370 2.380 2.370 2.380 2.380 2.370 2.380 2.370 2.380 2.370 2.370 2.380 2.370 2.370 2.370 2.370 2.380
is this another case of where my average is outside of the spec. limits so CpK does not count? Is the Cp numbers correct?
thx
Stijloor
tolerance - .50
max spec- 20.66
min spec- 20.16
avg- 20.72
Std Dev- .04
CpK- 4.01
Cp- 4.1
21 pc data sample-
Johnny
First of all...Is your process in control? Otherwise, any number for Cp, Cpk or whatever will be highly suspicious.........:mg:
Stijloor.
bobdoering
Stop X-bar/R Madness!!
Your Cp is close, but your Cpk is wrong, it should be negative. If your program looks at the absolute value, it is wrong. See attached. I rushed it in there, so I may be off a little, but the Cpk is negative, for sure...and that is not a good thing.
Of course, you have no idea what your distribution is, as there is no resolution in your data. In fact, with the tolerance you specify, your resolution is way low. But, that is not your biggest problem today...
Tim Folkerts
tolerance - .50
max spec- 20.66
min spec- 20.16
avg- 20.72
Std Dev- .04
CpK- 4.01
Cp- 4.1
I'm confused by your specs (and I suspect your spreadsheet is confused too).
With a nominal value of 20.729 and a tolerance of 0.5, it might be reasonable to assume that USL = 20.729 + 0.25 and LSL = 20.729 - 0.25. If you use these values, then the Cpk values do seem to agree agree with the numbers given above.
However, these USL & LSL do not agree with your quotes min and max. I suspect the software is using (Nominal +/- Tolerance/2) to get USL & LSL, rather than using the Min and Max you have listed.
(The same reasoning seems to apply to your second example as well.)
Tim F
that was my first thought as well. The math for the specs doesn't add up...
if the OP can post the spreadsheet we can provide better advice on the original question.
...of course I'm sure we will all continue to rail against the many drawbacks of Cp/Cpk regardless of the actual original request....
jerry_Malaysia
I agree with Stijloor - A process needs to be stable before Cp or Cpk be calculated.
As stated in Juran Quality Handbook "Measuring the inherent or potential process capability requires that the process be stable. Stability is evaluated by a control chart.
bobdoering
Some of that comes from the incorrect belief that a process has to exhibit normal (random, independent variation centered about a mean value) variation to be a stable process (false), and then you can calculate capability because the statistics are based on an assumption of normality (true).
Conceptually, capability is a snapshot anyway, and of far less value to describe process variation than people place on it. But, control charts are equally as bad, if prepared and executed incorrectly.
ralphsulser
I agree. Additionally one may want to quantify "how stable is it" and how frequent.
If the mean is not considered then the cp can tell you what to expect as an example to definine tolerence expectations for a process of mating parts. I once used this method to determine Corvette hood flushness when Chevy changed the bonding process specs of the inner to outer skin. I went to a meeting with their chief engineer with my data and it was accepted and revised on the drawing. This was approx. 1978.
S Help me build an Excel Spreadsheet for tracking training Training - Internal, External, Online and Distance Learning 14
M Preventive Maintenance Spreadsheet in Excel Quality Assurance and Compliance Software Tools and Solutions 2
T Calculating LCL, UCL, Cp, and Cpk in an Excel Spreadsheet Statistical Analysis Tools, Techniques and SPC 3
R Is there any Excel .xls Spreadsheet available for DOE with 3 factors? Six Sigma 1
kedarg6500 Excel spreadsheet for Unilateral Tolerance Study wanted Excel .xls Spreadsheet Templates and Tools 2
kedarg6500 Excel Spreadsheet for AIAG Example wanted Excel .xls Spreadsheet Templates and Tools 3
A Tracking Calibration and Qualification in an MS Excel Spreadsheet Calibration and Metrology Software and Hardware 6
S Form and Form/Record Numbering in an Excel Spreadsheet Excel .xls Spreadsheet Templates and Tools 2
J Excel spreadsheet to use Basic and Mini MOST for Line Balancing Document Control Systems, Procedures, Forms and Templates 1
B How to validate Microsoft Excel Spreadsheet Calculations for the Cpk value Capability, Accuracy and Stability - Processes, Machines, etc. 9
T Controlling an Excel Spreadsheet (Database) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Ajit Basrur How do I create two different columns in Excel spreadsheet ? Excel .xls Spreadsheet Templates and Tools 5
L Auditing Tool (Excel spreadsheet) for VDA 6.3 to Audit a Service Provider VDA Standards - Germany's Automotive Standards 4
J Excel spreadsheet for Gage R&R study with 9 appraisers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Taguchi L4 Orthogonal Array Design of Experiments (DOE) in an Excel spreadsheet Excel .xls Spreadsheet Templates and Tools 3
F SPC Data Analysis - Excel Spreadsheet I can use for Diameters and Perpendicularity Capability, Accuracy and Stability - Processes, Machines, etc. 6
F SPC Newbie looking for Excel Spreadsheet formula for a sample size of 40 components Capability, Accuracy and Stability - Processes, Machines, etc. 8
V Excel Spreadsheet to Calculate Temperature Compensation of Gage Blocks wanted General Measurement Device and Calibration Topics 3
S Strange PT Ratio on an Excel spreadsheet for variable GRR ANOVA Method Excel .xls Spreadsheet Templates and Tools 2
A Excel Spreadsheet Validation - Customer Audit Finding Other US Medical Device Regulations 2
V Calculation of PPM & Sigma Level in an Excel Spreadsheet Statistical Analysis Tools, Techniques and SPC 3
automoto Excel (xlsx) spreadsheet for conducting Type 1 MSA Analysis. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 23
J ROI (Return on Investment) Excel Spreadsheet example Excel .xls Spreadsheet Templates and Tools 1
R Medical Device Inspection Sheets - Excel Spreadsheet Validation US Food and Drug Administration (FDA) 2
T Controlled Documents - Can a word document and excel spreadsheet be controlled? Document Control Systems, Procedures, Forms and Templates 5
K Excel Spreadsheet Template to calculate Cmk (Machine Capability) wanted Capability, Accuracy and Stability - Processes, Machines, etc. 2
R Cpk & Ppk and Differences between Minitab and an Excel Spreadsheet Results Statistical Analysis Tools, Techniques and SPC 4
S Excel Spreadsheet Conditional Formatting help needed Excel .xls Spreadsheet Templates and Tools 12
J Excel Spreadsheet Validation for Calculating Data coming from our Instruments (LIMS) General Measurement Device and Calibration Topics 3
1 Defect Tracking Excel Spreadsheet Template Excel .xls Spreadsheet Templates and Tools 2
R Export some dates from an excel spreadsheet - EXCEL Question Excel .xls Spreadsheet Templates and Tools 3
A Gantt Chart or Excel Spreadsheet for ISO 9001 Implementation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
T Do I need to validate a basic Excel spreadsheet Quality Assurance and Compliance Software Tools and Solutions 10
R Supplier Quality Rating Scorecard Template (excel spreadsheet) Supplier Quality Assurance and other Supplier Issues 4
Q Can someone share an Excel spreadsheet to measure Cpk or Cp values. Excel .xls Spreadsheet Templates and Tools 15
A Validation of an Excel Spreadsheet used for Recording Test Results Qualification and Validation (including 21 CFR Part 11) 14
kedarg6500 Process Capability for Attribute Data - Excel .xls spreadsheet wanted Capability, Accuracy and Stability - Processes, Machines, etc. 5
Frank T. ASTM F104 Callout Interpretation - .xls Excel Spreadsheet Various Other Specifications, Standards, and related Requirements 0
T Double-sided (USL, LSL) Variables sampling plan Z1.9 - Use in Excel spreadsheet? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J Attribute Measurement System Analysis Excel spreadsheet Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
J CMM Accuracy - Formula for Excel or a spreadsheet Excel .xls Spreadsheet Templates and Tools 20
M Capacity Analysis or Calculations - Excel Spreadsheet needed Excel .xls Spreadsheet Templates and Tools 3
U Excel .xls spreadsheet for Line Balancing (Time and Motion Study) needed Excel .xls Spreadsheet Templates and Tools 1
Kales Veggie Report Writer for Excel spreadsheet or CSV (Comma-Separated Values) Format Excel .xls Spreadsheet Templates and Tools 8
Stijloor APQP Process Assessment Tool - Excel .xls Spreadsheet Excel .xls Spreadsheet Templates and Tools 1
P Small Business Spreadsheet Factory - a good site for excel, word ... Excel .xls Spreadsheet Templates and Tools 4
C Gage R&R Studies Excel .xls spreadsheet Excel .xls Spreadsheet Templates and Tools 7
A GR&R (Gage R&R) Calculation Excel .xls Spreadsheet Excel .xls Spreadsheet Templates and Tools 6
C Excel spreadsheet containing Gage R&R with Anova Method wanted Excel .xls Spreadsheet Templates and Tools 22
M Gage R&R Excel .xls Spreadsheet Problem Excel .xls Spreadsheet Templates and Tools 5
