I'm not in the medical device industry but, being a software engineer, always struggle to understand special processes, so I try to learn by contributing ...
"The Global Harmonization Task Force published Process Validation Guidance in 2004."
Just to be clear, this report says in its introduction:
This process validation guidance is intended to assist manufacturers in understanding quality management system requirements concerning process validation and has general applicability to manufacturing (including servicing and installation) processes for medical devices.
The list in the report is a list of examples, not exhaustive. It does not say there is no need to validate welding processes.
FDA guidance
http://www.fda.gov/MedicalDevices/D...dicalDeviceQualitySystemsManual/ucm122439.htm
says
"For example, visual inspections usually are not capable of detecting defects in structural welds. Such defects may be detectable only by using destructive testing, expensive test equipment, or very slow test methods."
I've never understood why, if a weld has to be of a certain strength, testing that it is indeed strong enough isn't enough. Does the test itself weaken the weld so that, even if it was initially strong enough, it's now more likely to fail in the field?
Is it the case that while pipelines and buildings have to withstand huge forces that can break weak welds, medical devices generally don't get subjected to mechanical forces anything near the breaking point of even a substandard weld? This might explain why the FDA guidance mentions welds yet the GHTF list does not.
Just my 2c, ignore if completely off-base
Pat
