Existing Device + Existing Device = OK ? New 510(k) required?
TJG954 - 2009
Here's the scenario...
Existing x-ray device with older technology receptor is 510k approved.
Existing newer technology receptor is 510k approved.
The x-ray device is upgraded by replacing the older technology with the newer improved receptor.
Other than improving the image and viewing options, nothing else has changed.
Question: Is it necessary to file for a new 510k approval? :confused:
I need opinions from experts from the Cove.
MIREGMGR
Re: Existing Device + Existing Device = OK ?
Definitely you must file a new PMN for the system using the new detector. The only question is whether the format should be a Special or a Traditional.
A Special must not have any change to Intended Use (none intended in this case) and must not have any change to the fundamental technology. This latter requirement seems to suggest that a Traditional would be required; however, there are certain exceptions when the new technology itself is already 510(k)ed.
Because this instance is close to that boundary, I suggest you officially inquire with CDRH or DSMICA as to which format to use.
Coury Ferguson
Moderator here to help
I have moved this post to this forum. Since it is more related to FDA.
Andrea.Ruth
I would disagree that this is definitely a 510(k). I think it could be, it is not a slam dunk either way. I have seen companies with different product families replace old technology with new technology, without changing the regulatory profile of the device, and do it with internal documentation.
You definitely have to ask yourself whether indications for and intended use are changing, whether the new technology add new or different risks to the device, whether the safety and effectiveness profile of the device is changing.
The guidance on the FDA website is a good resource, as is DSMICA (Call them).
celia4237
Then what about this scenario?
The original device named KD-5961 have already get 510(k) cleared.
Only the appearance of KD-5961 is changed, nothing else changed, which forms a new device, KD-5962.
We all know that the modification of appearance is a very slight change, can we use the K number of KD-5961 for KD-5962 without a 510(k) submission to FDA?
Al Rosen
What did you change? The color. Then I think you can handle it in your internal procedures. A new paint? Maybe not. Look at the http://www.fda.gov/cdrh/ode/510kmod.htmlflowchart.
celia4237
The modification of appearance brings the change of PCB and the shape of the device.
The question is, if we meet the requirement of the flow chart, but our change has formed a new device, can the new device use the original K number together with the old device?
MIREGMGR
I hope you recognize that the issues you present, i.e. continued legal marketability of an existing product after changes to that product have been made, should have been addressed when you made those changes... at least if that product is still on the market.
In any case, the bottom line is that you must address the questions in the decision flowchart that Al Rosen linked above.
If the changes to your existing device were "documentation only", then you did not "form a new device". Instead you just created a variant of your already-existing device, and the existing 510(k) would continue to apply.
celia4237
Oh ,I must have mixed "new device" with "variants of the device".
Thank you and i really learn a lot here.
K Relabeling an existing medical device in the field? Other US Medical Device Regulations 6
P Adding "new" medical device to existing CER - under MDD CE Marking (Conformité Européene) / CB Scheme 1
F Device Standards - Managing Changes to existing standards that apply to our devices Other Medical Device Related Standards 1
H Classification of a device that uses an existing battery IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
K 510k "Premarket" Submission for Existing Class II Software Medical Device US Food and Drug Administration (FDA) 3
N Is a new 510K required for change of manufacturing location for an existing device? US Food and Drug Administration (FDA) 1
M Use of a "Priority existing chemical" in medical device in Australia Other Medical Device Regulations World-Wide 1
G New model for existing Class I Device Listing (510K exempt) US Food and Drug Administration (FDA) 8
R Regulation Process for Add on Accessory to an Existing Medical Device Other US Medical Device Regulations 1
M QSR - Design Control on Existing Device not Designed following QSR 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
H Medical Device Design Control Requirements (820.30) on Existing Products 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
shimonv Deciding When to Submit a 510(k) for a Change to an Existing Device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 17
sagai New Draft Guidance - When to Submit a 510(k) for a Change to an Existing Device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
L Changes to existing Medical Device marketed under different name 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
S Correlation Study between a new Measurement Device and an existing Device Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
D Design Verification for special 510(k) - Size modification to an existing medical device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
S Requirements to market/sell existing medical device in EU, Canada ISO 13485:2016 - Medical Device Quality Management Systems 3
A Submit a 510(k) to an existing device vs. Just Documenting a Change ISO 13485:2016 - Medical Device Quality Management Systems 2
hockeyhead Existing process never included in AS9100 scope of certification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
J Design file for pre-existing products - Inputs and Outputs ISO 13485:2016 - Medical Device Quality Management Systems 5
M Do we need to create a new CER or can we just update the existing CER EU Medical Device Regulations 3
N New (Upgraded Technology) vs Existing Equipment - Measurements Shift Design and Development of Products and Processes 4
D Validation of existing equipment - Risk based approach example ISO 13485:2016 - Medical Device Quality Management Systems 3
D Validation of existing equipment - I have been asked to write a quality assessment for equipment ISO 13485:2016 - Medical Device Quality Management Systems 13
D How to create IQ, OQ, PQ protocol for existing equipment Other Medical Device Related Standards 2
shimonv Creating a new commercial product based on a modification to an existing product Other US Medical Device Regulations 4
K Change of Existing Medical Devices and 510(k) US Food and Drug Administration (FDA) 9
J Implementing EN 62304:2006 on existing and proven medical devices IEC 62304 - Medical Device Software Life Cycle Processes 6
C ISO 14001 vs Existing Quality System - How to keep them separate? ISO 14001:2015 Specific Discussions 3
K Addition of a test reader to existing CE marked product. Other ISO and International Standards and European Regulations 2
D Introducing an existing product into automotive context - DFMEA needed? IATF 16949 - Automotive Quality Systems Standard 8
B NEED HSE-MS Gap Analysis between 2 existing Management Systems Occupational Health & Safety Management Standards 0
D How to add AS9145 requirements to my existing AS9100 QMS? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
A How do we implement a Process Approach ISO 13485:2016 - Existing GMP QMS Other ISO and International Standards and European Regulations 2
K APQP requirement when a new print or spec is received from a customer - Existing Part APQP and PPAP 3
V Procedure to change the Company name in existing TS16949-2009 certificate ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
B Existing reports and altering such reports AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
A How best to start revising an existing ISO 9001:2008 system in a company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
I Is it acceptable it is to list new products under an existing 510(k)? Other US Medical Device Regulations 14
S Evaluation of our existing Suppliers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S Digitising Existing Documents to ensure regulatory compliance Document Control Systems, Procedures, Forms and Templates 6
S Already Existing Customer Open-PO (Purchase Order) Review ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
S Temporary Facility Used For Production - Use of existing Third Party Logos ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
alonFAI Update an existing QMS manual or write a new one for AS9100C Certification? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M Anyone added I-m to an existing I-s CE Certificate? EU Medical Device Regulations 1
Q Combining existing 510(k)s into a new 510(k) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
K Integrating acquired existing product into Quality Management System Records ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D AS9100C - New requirements to existing standard? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
X Existing Toolroom Process Validation - Need to identify clauses addressed. Manufacturing and Related Processes 7
A Understanding adoption of a product to an existing Sterilization Cycle Other US Medical Device Regulations 1
