Informational Expanded Gage R&R Analysis using Minitab
Bill_jvrsshurricane
Hello everyone. I am brand new to using quality tools such as Minitab. I can do some things in Excel but never used the data analysis tools. I have a lot to learn and am hoping someone can help me out with Minitab. I am trying to do an Expanded Gage R&R analysis. I chose expanded because it is an unbalanced sheet. When I click ok, I get the report shown below. It is also missing the r chart as well. I am aiming for a chart that was previously done but I don't know what was input into the fileds to create the charts in the file titled 1016test. Eventually, I will have to add more CMM's and operators, etc. as the R&R study progresses. But I don't know if my data is format correctly for Minitab, etc. I also don't know how to fully setup the dialog box. I greatly appreciate your help.
You are using run order to designate your parts. In your analysis, this means that each part was only measured one time. Is this actually the case?
Your options are pretty limited then. You can create a Gage Run Chart. If you have a master measurement of the part, you could perform a Type 1 Study, which evaluates the repeatability and bias. You can use General Linear Model ANOVA to manually estimate the Repeatability and Reproducibility, but you will have to manually create all of the graphs and manually calculate metrics such as percent tolerance. You will not be able to evaluate the operator*part interaction or metrics such as ndc or percent study variation.
Bill_jvrsshurricane
Ok thanks. This is tough learning this but will make a great learning exercise for me since this is the first time I have used this software. Thanks for your help. :)
N
ncwalker
I agree with Miner. If in your study you have just taken one part and measured it over and over, you have severely limited the knowledge you will gain from the study.
Imagine you are designing all weather tires. And you decide to test your new tire for traction on an asphalt road. You run a short course and take a few curves and call it a success. That's your study right now.
How does it perform on a wet road? A dirt road? A gravel road? Icy road?
Does the weight inside the car change things? How much?
Does the speed of the car change things? How much?
Of all these categories, which ones affect traction the most? Which factors affect traction so insignificantly they can be ignored?
That's a full study. More than one part, more than one operator, measured more than one time.
Bill_jvrsshurricane
Ok got it. I will request that we test at least 3 parts. We initially measured only 1 part a total of 33 times by 3 different operators. They were then going to send me the part and do the same thing and then the part would go through another round by a 3rd party location.
K MINITAB 16 - Attribute gage study (Analytic method) and Gage R&R Study (Expanded) Using Minitab Software 2
M Informational US FDA – Expanded Access for Medical Devices - Investigational medical devices Medical Device and FDA Regulations and Standards News 1
A Expanded GR&R Study questions Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
A Unit of Expanded Uncertainty in Percentage General Measurement Device and Calibration Topics 4
P Testing Zinc Coating on Expanded Metal Manufacturing and Related Processes 7
D Do I need to test "as built" for an expanded ISO Class 8 Clean Room ? Other Medical Device Related Standards 2
D Necessity of Expanded GR&R for Multiple Test Systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R Does C = 0 have a expanded twist for problem vendors (suppliers)? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
W Expanded Uncertainty vs. Accuracy Requirement (including concept of guardbanding) Measurement Uncertainty (MU) 4
S TUR (test uncertainty ratio) based on Standard or Expanded Measurement Uncertainty? Measurement Uncertainty (MU) 2
S Comparing measurement results for a part from two ring gage General Measurement Device and Calibration Topics 3
M Quick Gage R&R Question Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
PQ Systems Best Practices In Gage Management Using GAGEpack Software 0
PQ Systems Gage R&R - 3 Part Series Using GAGEpack Software 0
I Excel based Gage R&R VS Minitab calculation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
R Repeatability Type 1 Gage and Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
W Proper gage to use for receiving inspection General Measurement Device and Calibration Topics 9
A GAGE R&R Binomial with master list (for method validation) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
Q Gage calibration / tracking software General Measurement Device and Calibration Topics 5
A R chart from ANOVA gage R&R test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
M Type 1 Gage r study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S MSA for attribute relation gage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
S Type 1 Gage R&R or something else? Reliability Analysis - Predictions, Testing and Standards 6
R Gage R&R Excel templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Gage R&R with more than 3 appraisers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Definitive answer on Type 1 vs Type 2 vs Type 3 Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
V Gage Management and Gage R&R Software General Measurement Device and Calibration Topics 1
D Gage R&R Study on Load Cells - Large chemical blending tanks IATF 16949 - Automotive Quality Systems Standard 1
S Gage R&R on alloy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
8 Need Help - Runout - Function Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
