Expanded Uncertainty vs. Accuracy Requirement (including concept of guardbanding)
W
w6553
Hi
A testing Standard requires the equipment accuracy to be 3%. The calibation certifcate shows the expanded uncertainty of the equipment is 3.4%. Is this means that the equipment is not comply with the Standard?
Wayne
P
Polly Pure Bread
Re: Expanded Uncertainty vs. Accuracy Requirement
Hi
Wayne
Hi Wayne,
What’s the source of uncertainty?
W
w6553
HI dQAppentice,
The calibartion equipemnt used to calibrate my equipment has expanded uncertainty 2%. Does accuracy of my equipment depend on the sources of calibration uncertainty?
Hershal
Metrologist-Auditor
In this case the uncertainty is higher than th accuracy, so it means that your measurement using this device will have a larger uncertainty. That in turn means that the true value of the measurement, expressed at 95% confidence will be the indicated value, plus or minus the uncertainty. Now, the instrument may truly be accurate in its measurements, but when the uncertainty is considered, then all contributions together mean the true value of th measurement may or may not be the indicated value.
I would address this by guardbanding to reduce the effect of the uncertainty on the pass/fail decision.
A Unit of Expanded Uncertainty in Percentage General Measurement Device and Calibration Topics 4
S TUR (test uncertainty ratio) based on Standard or Expanded Measurement Uncertainty? Measurement Uncertainty (MU) 2
M Informational US FDA – Expanded Access for Medical Devices - Investigational medical devices Medical Device and FDA Regulations and Standards News 1
B Informational Expanded Gage R&R Analysis using Minitab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
A Expanded GR&R Study questions Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P Testing Zinc Coating on Expanded Metal Manufacturing and Related Processes 7
D Do I need to test "as built" for an expanded ISO Class 8 Clean Room ? Other Medical Device Related Standards 2
K MINITAB 16 - Attribute gage study (Analytic method) and Gage R&R Study (Expanded) Using Minitab Software 2
D Necessity of Expanded GR&R for Multiple Test Systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R Does C = 0 have a expanded twist for problem vendors (suppliers)? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
L Uncertainty calculation for an average Measurement Uncertainty (MU) 1
F Missing value of Uncertainty B Measurement Uncertainty (MU) 10
F Issues in Uncertainty Estimation Measurement Uncertainty (MU) 5
F Operator Manual and Type B Uncertainty Measurement Uncertainty (MU) 3
F Learning Uncertainty Budget for Novice - Fluke 5520A Measurement Uncertainty (MU) 1
S Uncertainty Budgets - Phase Noise (SSB), Harmonics Measurement Uncertainty (MU) 2
M Informational US FDA Final Guidance – Consideration of Uncertainty in Making Benefit-Risk Determinations in Medical Device Premarket Approvals, De Novo Classificati Medical Device and FDA Regulations and Standards News 0
A Uncertainty Budget - Externally produced sensor module Measurement Uncertainty (MU) 1
E Discussion between co-worker on tolerance and uncertainty and how to apply it. Thoughts? 17025 ISO 17025 related Discussions 1
G 3 Operator Std. Dev. and uncertainty calculation Measurement Uncertainty (MU) 2
L Gage R&R for test precision or uncertainty prediction? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
G Uncertainty of staging a short line scale standard on longer measuring machine? Measurement Uncertainty (MU) 4
G NIST SOP 29 - Assignment of Uncertainty - Question General Measurement Device and Calibration Topics 0
M Medical Device News FDA news - 05-09-18 - Draft - Uncertainty in Benefit-Risk Determinations Other US Medical Device Regulations 0
G How to include machine error in uncertainty calculations? Measurement Uncertainty (MU) 5
M Calibration certificates avowing accuracy beyond the uncertainty limits? Measurement Uncertainty (MU) 7
G ANAB ISO 17025 Accreditation - Uncertainty and systematic error? ISO 17025 related Discussions 6
G How many Uncertainty Measurements for Micrometers and Calipers? Measurement Uncertainty (MU) 3
G What degrees of freedom means in uncertainty budget and how do I set the value Measurement Uncertainty (MU) 2
G Uncertainty Experts - ISO 17025 - If the Distribution is Rectangular Measurement Uncertainty (MU) 2
G Uncertainty Budget Examples for Caliper, Micrometer and Dial Gauge Measurement Uncertainty (MU) 3
P Uncertainty and Significantly Different Means - Buffer Solutions Measurement Uncertainty (MU) 4
S Pressure Gauge Calibration Uncertainty Calibration and Metrology Software and Hardware 5
E Uncertainty of Mean - Test rig that measures water temperatures Measurement Uncertainty (MU) 3
J Internal Laboratory Scope and Measurement Uncertainty (MU) IATF 16949 - Automotive Quality Systems Standard 1
G Manual Procedure with Uncertainty Budgeting for either a Caliper or Micrometer General Measurement Device and Calibration Topics 6
C MU (Measurement Uncertainty) in an Internal Calibration Laboratory Measurement Uncertainty (MU) 1
N How to Convert Micro Volts into Temperature Uncertainty Measurement Uncertainty (MU) 1
N Include homogeneity uncertainty into budget table for thermocouples Measurement Uncertainty (MU) 1
