Experience with De Novo applications
Dobby1979
Hi All.
Does anyone have much experience with De Novo applications? Do you have any learning points or pearls of wisdom that could be shared?
Did you engage with any consultants to verify your application / guide you along the way? Would you recommend this?
Ronen E
Problem Solver
Moderator
As a consultant, I strongly recommend you engage one... :lol:
I have limited experience with the current De-Novo process. My recommendations are quite generic - make sure to learn the current issued FDA guidance and consider using the pre-sub provisions.
Watchcat
Since FDA published the draft guidance in August 2014, it has granted a little over 100 "direct" De novos that were submitted after the guidance was issued, and only a few dozen since the final guidance was in October 2017. The process is still not finalized. FDA posted a Proposed Rule for comments earlier this year.
So, not much experience to be found out there, possibly none here on Elsmar Cove. Moreover, it's not clear how much past experience will apply to future De novos, or how much experience with any given De novo will translate to another, since they are...well, De novo. To the extent they are truly novel devices (and this remains to be seen), you need to figure things out for yourself, with no predicate to guide you. The existing experience with truly novel devices is with original PMAs, rather than with 510(k)s, and this experience is also not that common within the industry.
I have been following the De novo process since before the draft guidance was issued. Early on, I spoke with several FDAers about the process and also to a number of RA professionals who had done a De novo. Those who had worked on PMAs thought the De novo was a walk in the park. Those who had worked only with 510(k) devices had mixed experiences.
I am currently working on some high-level analyses of the De novos that had made it though FDA as of December 31, 2018. It is very slow going, because the FDA's databases are pretty clunky. In addition, the sample size is still too small to make it useful for anything but a high-level analysis at this point. When I get an analysis completed, I will post it to Elsmar Cove. I have split out ODE and IVDR De novos, and should have some very basic statistics on the ODE De novos available in the next 2-3 weeks.
I have not taken a De novo through FDA yet. Getting old, and at the rate they are going, might never. I have developed a few regulatory plans and one pre-submission packet, mostly for startups, which is to say, mostly for devices that will probably not make it from initial plan to market, sigh.
Tips:
1. It's all about the risk. (So much so, that by now I have a song in my head set to Meghan Trainor's "It's All About That Base," which finishes, "...no benefits.") This was the first early wisdom to emerge, probably based more on a reading of the guidance than experience. As it turned out, per FDA, it was the actual classification that was the most common stumbling point encountered with early experience. Not surprising, since (no matter what they tell you) neither FDA nor industry has much experience with classification. (510(k) devices are essentially "pre-classified," based on the predicate.) This has probably improved lately, especially on FDA's side.
2. Do a pre-sub meeting. Absolutely, positively.
3. Get an experienced consultant. Really. It's hard enough for a device startup to make it without one. A consultant with De novo experience might be great, but experience in the therapeutic area, and maybe with the technology (e.g. imaging, software, IVD) can be as important. What you need most, IMO, is substantive premarket experience with FDA, beyond that which you will get by filing some bench tests to show equivalence to a "me too" predicate. Experience with 510(k)s that require clinical trials, De novos, or PMAs.
Ronen E
Problem Solver
Moderator
Hmmm... Yourself?...
Watchcat
RonenE, it could happen. As I'm sure you know, lot of things factor into a choice of consultants, as well as the decision to use one. Money can sometimes be a strong determinant. ;)
mihzago
I have a De Novo for two products under my belt and worked with a few companies preparing for one (assisting with pre-subs and putting together the documentation). I don't think a direct experience with De Novo process is as important as extensive experience in the clinical/technical area, and also experience with complex 510(k) submissions. What I mean by that is a 510(k) with clinical data, adding new indications or pushing the intended use boundary.
FDA will review every claim in excruciating detail and ask for extensive data supporting these claims. Imagine a bunch of Ph.Ds doing their dissertation.
Watchcat
Reassuring to see that mihzago and I are consistent in our perspective on the types of experience that are likely to be a good fit. The other problem you are likely to face is that so much FDA device RA work involves "non-clinical" 510(k)s, the fact that you don't need to limit yourself to someone with prior De novo experience still doesn't give you a huge pool of consultants to choose from, and those who have this background are not likely to be sitting around with nothing to do. So you will want to plan well ahead. IMO, if you have your risk analysis and your user requirements and no RA consultant, you are now officially running behind on RA consulting. But, as an RA consultant, I would think that.
A lot of my clients these days are novice (academic researchers or practicing clinicians with a bright idea). If they find me early, and they have a truly novel technology, I like the idea of an informational meeting even before a pre-sub, to introduce FDA to the technology and, equally important, the novices to FDA. But these are low priority meetings for FDA, so it can take awhile to get one. Otherwise, if timeframes allow, I'm inclined to focus on the pre-sub, and not worry so much about the submission. Of course, if the startup didn't start looking until they thought they were ready to submit, and think that they just need someone to "compile" the submission...well, I would say it is too late for the pre-sub, but sadly, it is often too late to have found an RA consultant. Then they have to back up to the pre-sub, which is where they learn they weren't ready to submit after all. :(
M Experience and advice with certifications categories Training - Internal, External, Online and Distance Learning 3
O ASQ CQE Exam Experience, Home versus Exam Center ASQ - American Society for Quality 0
N Does anyone have experience of GB/T 34986-2017? China Medical Device Regulations 1
Z Does anyone have experience with EN ISO 17664 ? IEC 62366 - Medical Device Usability Engineering 9
E Consultant with Office 365 experience Consultants and Consulting 2
N Any experience with Registrars that deny Certification to a Registrant? Registrars and Notified Bodies 4
BeaBea Registrars with VAR (Value Added Reseller) experience Registrars and Notified Bodies 8
Q Experience with Adobe Sign Document Control Systems, Procedures, Forms and Templates 3
S Experience working with TUV SUD or Rheinland, and/or BSI Registrars and Notified Bodies 5
C Experience with Agile PLM (Product Lifecycle Management Software) software from Oracle? Document Control Systems, Procedures, Forms and Templates 3
Gamula Product-Lifecycle-Management Experience Medical Information Technology, Medical Software and Health Informatics 9
M Honda Audits - Does anyone have any experience with the QAV audit? General Auditing Discussions 3
Q Does anyone have experience implementing a QMS without ISO certification? Quality Manager and Management Related Issues 2
T Training and experience - How do I document my experience and training Career and Occupation Discussions 5
D AEA (Aerospace Experience Auditor) Challenges - Finding availability of AEA for witness AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
QIE Anyone have experience with BPA Quality (QMS system based on Office365/Sharepoint) Quality Assurance and Compliance Software Tools and Solutions 1
Rameshwar25 Min working experience for IATF 16949 third party auditor IATF 16949 - Automotive Quality Systems Standard 5
W Does anyone have any experience with the Easy Metric System? General Measurement Device and Calibration Topics 2
1 ISO Registrar with waste water treatment experience Registrars and Notified Bodies 1
A Anyone have experience with Transmille calibrators General Measurement Device and Calibration Topics 1
D Has anyone here had any experience with PQ-FMEA software? FMEA and Control Plans 1
C IATF 16949:2016 New CSR (CQI´s) - Share your experience IATF 16949 - Automotive Quality Systems Standard 1
S Has anyone completed IATF 16949 Certification - Share your Audit Experience? IATF 16949 - Automotive Quality Systems Standard 2
W Problems with our new Auditor (a Ph.D. with four months experience) ISO 13485:2016 - Medical Device Quality Management Systems 25
E Does anyone have experience implementing a Tiered QMS? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Moncia Complaint / Non-Conforming Product / CAPA Procedures - Please share your experience ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
L How to get more Auditing Experience Career and Occupation Discussions 11
R Does anyone have any experience on change control? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
ScottK Does anyone have experience with how MDD unanounced audits of suppliers are going? EU Medical Device Regulations 21
D What is your experience with FDA using "mixed load" i EO sterilization Other Medical Device Related Standards 1
P CQE Work Experience - New to Industry Professional Certifications and Degrees 1
S Any experience on filling form, FDA 3654 for the DICOM standard? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
A Does anyone have experience providing a summary of Pre-IDE discussions in the 510k US Food and Drug Administration (FDA) 1
K SSBB Qualifications and Experience Requirements Professional Certifications and Degrees 2
S IRCA Lead Auditor Certificate based upon Work Experience ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 4
A MDS software - Does anyone have experience with iPoint? RoHS, REACH, ELV, IMDS and Restricted Substances 8
P Experience / advice for integrating API Q1 9th with a WCM program Oil and Gas Industry Standards and Regulations 5
D Experience with Notified Body - ITC from Czech Republic for Medical Devices Registrars and Notified Bodies 15
J Experience with Licensale Submission Portal for Medical Devices Other Medical Device Regulations World-Wide 1
D Any experience with the SME/AME/Shingo/ASQ Lean BOK/Certifications? Lean in Manufacturing and Service Industries 2
N Willing to share my experience ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
M Does anyone here have experience implementing PCI DSS (Data Security Standard) IEC 27001 - Information Security Management Systems (ISMS) 10
M Offered Management Position - Limited Experience - Any Concerns? Quality Manager and Management Related Issues 13
GStough Rx-360 - Has Anyone Used This and What Was Your Experience? Supplier Quality Assurance and other Supplier Issues 3
B Japan PAL QMS Audit Experience Other Medical Device and Orthopedic Related Topics 5
D Minimum requirements/experience/qualifications to be head of quality Career and Occupation Discussions 6
J Does anyone have experience in submitting TSE Dossiers to EDQM? EU Medical Device Regulations 1
I Validation Software Experience? (Valgenesis, etc.) Quality Assurance and Compliance Software Tools and Solutions 1
Colin Anyone with Experience of BS EN 1090? CE Marking (Conformité Européene) / CB Scheme 7
D Any experience with Target Corporation Audit of Factories Supplier Quality Assurance and other Supplier Issues 1
