Extending a Shielded Cable into an AP
blazin912
I am updating a design to extend a shielded cable into an AP. The shield ties to earth through y-caps.
The applied part is a plastic enclosure with 3.3VDC voltage internal. To extend the shield we are looking at coating the inside of the enclosure but will have limited clearance from the secondary voltage to the "earthed" shield.
Trying to determine if this is an issue, or as I've seen elsewhere this shield connection is not a safety issue but rather EMC related and therefore does not need to meet the MOPP requirement of 0.8mm.
Any thoughts?
cdewitt
Questions -
Is the coating tied to the cable shield through this Y cap or is this a direct connection? If it?s direct and the cable becomes hot then the coating is also.
Is the coating accessible to the user or patient on the outside of the enclosure or is there at least creepage/clearance distance to someone touching it? If there is at least creepage/clearance and it becomes hot it may not matter.
If someone can touch it, how much leakage current is there?
Do you just need to meet touch current or is the enclosure an applied part in which case you need to meet BF or CF currents?
Have you done the risk management process from IEC60601-1 3rd edition, 4.6 ME EQUIPMENT or ME SYSTEM parts that contact the PATIENT?
C DeWitt
blazin912
Coating will be connected to Earth by Y Caps
Coating not on exterior
Type BF applied part
We passed originally without coating, by foil method.
This is an EMI mitigation so I'm trying to determine if it is acceptable.
If the coating is connected to signal reference ground, does that eliminate the creepage/clearance requirement?
Stackup:
Wall thickness (plastic): 0.5mm
Coating: 0.025mm
Air from coating to PCB copper: ~0.317 - 0.495mm
Your thoughts?
cdewitt
If you connect the coating to earth (PE) through Y caps then if there is an ESD discharge to the coating the charge will have no path to drain this charge back to earth. The coating may not be on the outside but ESD can still discharge to it at the seams. To prevent this either the seam needs to be sealed or there needs to be a large enough gap between the edge of the seam and the edge of the coating to prevent discharge. Roughly 1mm/1kV so to prevent discharge at 15kV the coating needs to be 15mm back from the edge of the seam on each side (30mm). This doesn?t work well as an EMC shield so something needs to cover the gap.
A related problem is creepage and air clearance at the seam. Even if you can?t touch the coating directly it still needs to be far enough from the seam to meet creepage otherwise it needs to meet BF leakage.
Is the shielded cable connected to any infrastructure or other equipment like an ethernet or USB cable? What we do is to connect the coating to PE but connect the cable shield to the coating with Y caps. That way the coating has an ESD discharge path to earth but is isolated from the cable so if the cable becomes hot the coating is not. This is not a perfect shielding solution, it?s a tradeoff between safety and EMC but it works fairly well.
C DeWitt
blazin912
Hmm, well I think were in the opposite situation:
Coating is on the remote housing, meaning that the only way to bring anything to it is through the cable.
So:
Housing Coating -- Cable -- Y Cap -- Earth
Housing is floating without the cable connection, this is a custom connection point, directly to electronic assembly. Take that cable out and the floating electronic assembly is isolated by > 1000mm of clearance. :lol:
cdewitt
OK, different systems require different solutions. You might think about paralleling the Y cap with a string of large value resistors to provide a discharge path for ESD.
C DeWitt
cdewitt
Assuming this is a high frequency signal and/or the shield is needed for immunity, bypass it to the coating on the case with the Y cap as you said but carry the shield through to the PCB. Do not use a pigtail to connect the shield at either the coating or the PCB, this adds inductance and makes the shield less effective. The Y cap will be sort of a pig tail but keep the path length between the shield and the coating as short as possible. Possibly use multiple caps to connect around the opening the cable comes in through. Make sure the jacket covering the cable extends into the enclosure at each end by the creepage distance or more. Check the leakage at the applied part by wraping it in foil and measuring leakage to ground.
C DeWitt
blazin912
I guess what I'm lacking understanding of is when Creepage and Clearance is required and between which items?
ie Clearance between what and Working voltage of <17V DC is 0.8mm
Operator? Patient? Mains? Earth?
I understand how we measure leakage, but trying to understand if one of these is a definite no, ie Shielding with Safety GND with very little clearance versus shielding with a highly isolated (CF rated) reference ground
Thanks for your help
M Procedure or Specification For Extending Gages Calibration Calibration Frequency (Interval) 2
E Extending current ISO 9001 registration scope to cover SW development Software Quality Assurance 2
G Validity of Extending Temperature Cycling Various Other Specifications, Standards, and related Requirements 3
J Extending QMS Scope to External Company Site (Outsourcing) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J Extending the Scope during Transition Audit to AS9100 Rev. C AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
C Extending the Calibration Frequency of a Measurement Device Calibration Frequency (Interval) 17
M Extending Surface Plate Calibration Frequency General Measurement Device and Calibration Topics 3
hogheavenfarm Extending control of measuring equipment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
B Calculation for extending control limits Statistical Analysis Tools, Techniques and SPC 7
M Illuminance Meter - Extending Manufacturer's Recommended Calibration Frequency Calibration Frequency (Interval) 3
RoxaneB ISO 9001:1994 Certificates of Compliance - Are any registrars extending these? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A Test Probes for measuring ohms per square on shielded plastic surfaces Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
S ECG Cable Banana to Snap or Tab electrode Adapters -- ISO 10993 Requirement Other Medical Device Related Standards 0
E How do you determine if hipot is necessary for a cable product? Manufacturing and Related Processes 8
O Is Patient Cable Exempted from EFT Tests? (IEC 60601-1-2) CE Marking (Conformité Européene) / CB Scheme 1
O EMC - EFT (Electrical Fast Transients) on SIP couples erroneously with other cable CE Marking (Conformité Européene) / CB Scheme 1
F Design check list for Cable and Wiring Harnesses Manufacturing and Related Processes 6
L Valid reasons to omit an "ear-tag" type label on a cable? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
S Does the cable assembly supporting a medical device gets classified accordingly? US Food and Drug Administration (FDA) 1
E IPC/WHMA-A-620C: Requirements and Acceptance for Cable and Wire Harness Assemblies Other ISO and International Standards and European Regulations 2
N Data Transfer cable For Medical Device EU Medical Device Regulations 2
J Can the shield of a cable be used as a protective bonding conductor? Design and Development of Products and Processes 2
K Problem with Cable Composed of Coextruded Litz Wire and Tube Manufacturing and Related Processes 1
T What Test Certificate should accompany supply of Cable XLPE/SWA/PVC 4CX150MM2 Document Control Systems, Procedures, Forms and Templates 2
B Detachable Power Supply Cable Connection ESD Clarification IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
R Cable used in Active Implantable Medical Device Other Medical Device and Orthopedic Related Topics 4
N Cable Connectors - Insulation does not go all the way into the back of the connector Manufacturing and Related Processes 4
E Safety Requirements for Bioimpedance Measuring Device Power via USB Cable IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
C Grounding of Ethernet Cable Shield IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
L Electrical Cable Harness Quality Control - Sampling Plan for Pull Test Manufacturing and Related Processes 4
R MS90387-1 Tension Verification Tool for Cable Tie Gun Manufacturing and Related Processes 1
K USB Charger Adapter/USB Cable - A Medical Device Accessory? EU Medical Device Regulations 2
I IEC 60601-2-52 - HD22.10 H05-BQ-F type Power Cable for Medical Beds IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
K Implementing AS9100 Rev C - Electrical Harnesses and Cable Assemblies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R Correct Cable Ports After Work and Weekend Discussion Topics 2
D Cable Manufacturing Build Audit Checklist Manufacturing and Related Processes 6
P Options for getting TV/Cable stations programming over the Internet After Work and Weekend Discussion Topics 6
A Validation of Process - Label Printing and Cable Marking IATF 16949 - Automotive Quality Systems Standard 4
V HALT vs. HASS (acronyms) - Tests for PCB and Cable Assemblies Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
B Labeling of a Non-Sterile Component that connects to a Sterile System via a Cable 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
T Assistance with a Cable Issue Manufacturing and Related Processes 5
B Audio Cable Classification - Class 2 wiring for the speaker outputs TL 9000 Telecommunications Standard and QuEST 11
Marc Cargo Transport by Cable World News 0
Q Traceability by Physical Marking for Cable Assemblies Manufacturing and Related Processes 3
S USB Cable (an accessory to our data management software) Changes and 510k IEC 62304 - Medical Device Software Life Cycle Processes 2
J Cable and Harness Marking - Standard referenced on a cable drawing Design and Development of Products and Processes 14
V Validation of Molding Process for Manufacturing Cable and Wire Harness ISO 13485:2016 - Medical Device Quality Management Systems 7
V Calculation of Cable Assembly DPPM Customer Complaints 6
Q Cable Specifications for use in Automation and Electrical Panels Manufacturing and Related Processes 1
Marc Google's Pacific fiber optic cable departs from Japan to connect to America After Work and Weekend Discussion Topics 1
