Extent of Validation - New machine installed in manufacturing
jkc3usc
We have a new machine installed in manufacturing and paper work has been signed off for installation. If we check 1st piece as well as in process inspection to the part print do I still need to run a capability study? Again the risk for this part is low and critical dimensions are checked in 1st piece. I understand the more data to show capability is great (I also now the machines specs) but the machine is needed to run for parts production.
William55401
What is the machine? What is the process? It sounds like you have IQ completed. Without more information, it is uncertain what additional steps (OQ, PQ for example) are expected. Depending on the process, IQ only is often just fine.
yodon
The regulation / standard requires that any process (i.e., whatever your machine does) whose outputs are not (100%) verified needs to be validated. The means for validation are not prescribed. Some aspects related to validation are, indeed, listed in the standard. If you read through those, have the required documentation demonstrating compliance, and believe you're in a defensible position, then maybe you've fulfilled the requirement. As @William55401 notes, without more details, it would not be possible to give further advice.
Do also note that your internal procedures should be driving this! To have a QMS compliant with 13485, you should have procedures for infrastructure qualification, equipment qualification, and process validation.
jkc3usc
Understand. So We plan to run a 30 piece capability study. What about timing? The OQ,PQ can be done later? The machine is installed, employees are trained, Parts are being machined and checked as we do on all other machines. There is no safety risk for employees and parts go through inspection and a final inspection when product is built.
Mikey324
I would say 30 piece capability study. If you run any of the same parts on this machine as you do/did on your older ones you could compare results. Just to see if you are producing equivalent quality parts. Just depends on what all this new machine does.
yodon
Statistical rationale is emphasized in the standard and beibg assessed in reviews. Be sure '30' is statistically based and not just a seemingly good number
Ronen E
Problem Solver
Moderator
There is no one-size statistical basis available.
If we are being completely honest, most reviewers lack the background, motivation and time necessary for true statistical rigour. It's just too complicated; too many factors need to be considered for such determinations to be truly rational.
Pseudo-statistics are much more accessible and look just as nice in most cases, though.
yodon
I don't disagree about the statistical rigor and the ability to pass off pseudo-statistics. Reviewers, at least from my experience are not accepting the seemingly-large-enough sample size (or the rationale that 3 runs is sufficient, etc.). They may not be able to argue whether a statistical approach has legs but the do want to see it stood up, so to speak (some rationale for the decision).
Ronen E
Problem Solver
Moderator
Yes, that's exactly what I mean - it has to look "serious", not necessary be truly statistically defendable (which is quite difficult if you apply actual proper statistics and mathematics).
C 8.5.1.1 Control of Equipment, Tools, and Software Programs - Questions about the extent of control of NC programs AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
J Extent of 2017/745: providing 3rd party mass produced devices to NHS patients EU Medical Device Regulations 0
M SI #7 8.4.2.1 Type and extent of control_supplemental IATF 16949 - Automotive Quality Systems Standard 3
A IATF Sanctioned Interpretation No. 7 - Type and Extent of Control (supplemental) IATF 16949 - Automotive Quality Systems Standard 4
DuncanGibbons To what extent are NASA standards applicable to commercial aviation? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
I AS9100 8.4.2 Type and Extent of Control - External provider test reports Manufacturing and Related Processes 24
B Documented process for type and extent of control IATF 16949 - Automotive Quality Systems Standard 6
Q ISO 9001:2015 - Extent of Policy and Scope with Context and Interested Parties ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S Complying with IATF 16949 Cl. 8.4.2.1 - Type and extent of control IATF 16949 - Automotive Quality Systems Standard 1
E IATF 16949 Cl. 8.4.2.5 - Supplier Development Type and Extent IATF 16949 - Automotive Quality Systems Standard 2
N Extent of Product Traceability Required by ISO 13485 (Low Level Class I Devices) ISO 13485:2016 - Medical Device Quality Management Systems 3
V What are the criteria for determining extent of requalification (hardware upgrade) ISO 13485:2016 - Medical Device Quality Management Systems 2
I Definition Insubordination in Organizations - Definition, extent; vis-a-vis employee's rights. Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 14
E Extent of modification to be considered as Modified Adoption Other ISO and International Standards and European Regulations 1
L Can Extent of Documentation differ due to the Competence of Personnel? ISO 13485:2016 - Medical Device Quality Management Systems 9
M TS 16949 Cause 7.4.1: Type of Control vs. Extent of Control (Definitions) IATF 16949 - Automotive Quality Systems Standard 5
R 820.50 (A) (2)Define the Type and Extent of Control to be exercised over Vendor Misc. Quality Assurance and Business Systems Related Topics 5
P Risk Management - To what extent is Risk Management required by AS9100? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 17
A Extent of Gage R&R necessary on two Digital Height Gages Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J Extent of information required in COC (aka C of C and Certificate of Conformance) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
O Information on the extent of Statistics in the Six Sigma Green Belt Exam Professional Certifications and Degrees 9
R Extent of Recognition of ISO 10993-1 US Food and Drug Administration (FDA) 5
R FDA recognition standard - Extent of Recognition 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
T Raw Material Verification - AS9100 Rev. B - 7.4.3 - To what extent must a company go? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
T Traceability SOP Audit Finding - SOP does not describe the extent of the traceability ISO 13485:2016 - Medical Device Quality Management Systems 15
S Extent of Site manager (SM) Commitment - Upper Management issues Quality Manager and Management Related Issues 8
hogheavenfarm Extent of certification - Companies sharing manufacturing space in a building ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Sidney Vianna Outsourced Processes - Type and Extent of Control to be Applied - ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 40
F Need help about being more socialized - Hard to fit into my groups to some extent Career and Occupation Discussions 4
M Document Control Database - To what extent do document control requirements apply? Document Control Systems, Procedures, Forms and Templates 12
C To what extent should ppap be repeated according to the European Union ELV? APQP and PPAP 3
G Document Control - Extent of Responsibility Document Control Systems, Procedures, Forms and Templates 7
F Controlled Forms - To what extent do forms need to be controlled? Document Control Systems, Procedures, Forms and Templates 41
J To what extent does Emergency Prepardness need to be extended Miscellaneous Environmental Standards and EMS Related Discussions 2
J Validation Sample Size for Tray Seal Qualification and Validation (including 21 CFR Part 11) 1
F AS9100 - Validation, FAIR's, ITAR and Sub-Contracting AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R PCBA process validation Qualification and Validation (including 21 CFR Part 11) 0
A ISO 17025 - Methods validation and clients ISO 17025 related Discussions 3
S Sterilization validation after changing sterilization process provider Qualification and Validation (including 21 CFR Part 11) 3
B Sterilization Validation Plan Other Medical Device Related Standards 3
D Test Method Validation Qualification and Validation (including 21 CFR Part 11) 4
T Laboratory Verification after validation ISO 17025 related Discussions 3
silentmonkey Rationalising the level of effort and depth of software validation based on risk ISO 13485:2016 - Medical Device Quality Management Systems 10
D Questions regarding process validation ISO 13485:2016 - Medical Device Quality Management Systems 6
Y We found out we have been using a equipment without validation for past 4 years Quality Manager and Management Related Issues 6
Z Is IQ necessary for laser marking validation? EU Medical Device Regulations 3
E 13485:2016, Sections 4.1.6, 7.5.6 and 7.6 - Validation of Software - Need some Advice please ISO 13485:2016 - Medical Device Quality Management Systems 2
A Validation of Forced Aeration Process ISO 13485:2016 - Medical Device Quality Management Systems 3
M API 4F/7K/8C Design Package Validation Oil and Gas Industry Standards and Regulations 2
