External Document (Documents of External Origin) Control Template example wanted
tina014
Hi Guys,
I need help regarding External Document Control. Our auditor request a sample of external document masterlist, i really don't know how to start this one. Can somebody help me with this?
Thanks in advance.
Marc
Fully vaccinated are you?
It depends upon the external documents. There are standards and specifications, there are customer supplied prints, quality manuals, and a lot of other types of documents of external origin.
How your company controls *each* of these is the issue. In many companies, for example, engineering controls customer prints while QA controls customer documents such as Supplier Quality Manuals. On the other hand, some companies use a centralized document control department in which case there is typically a "Master List".
Can you tell us a bit more about what documents of external origin you company has and which department (for example) controls which ones?
tina014
Hi Marc,
Im from compliance team. Im talking about any external documents whether its from client or supplier. Im asking you how to create a template or sample masterlist of external documents.
Do I need the Doc. No? the Doc.Origin? the Doc.Format? something like that.
Marc
Well, assuming you're not a large company I'd just make up a spreadsheet.
Basics are:
Document Name
Document Number (if any)
Date of Document
Revision Level of Document (if any)
Source of Document
A few columns to put in any date(s) you checked to see if it is the "latest revision" (if appropriate)
Responsibility for ensuring it's the latest revision level (if appropriate)
Location (where it's kept)
That kind of basic stuff.
The key is whether each document (such as a standard) is the current revision.
But - There are times when having the latest revision isn't necessary. An example would be where a contract calls out an obsolete standard. You see that sometimes.
Hope this helps a bit. Some others here will probably have some suggestions.
Chris_Anderson
External documents may also have a document owner or custodian inside the company and a retention period. Tracking external documents is similar to tracking records.
E
ehatheway
My company is also working on this area.
I don't know where to draw the line between an external document begins (ISO9001:2008, ESD 2020, etc) and a design input (such as a customer specification or drawing). Does anyone have a recommendation?
Raffy
On the upper left portion, DAte of Change was reflected since for every new or revised updated from the template said date varies.
Document No and Revision, Document Title and/or Description, Reviewed By, Date the Document was sent for review, Due Date (normally ten working days for TS requirement), Action Item, Change Notice Number (if any), Person-In-Charge and Status.
Hope this helps.
Best regards,
Raffy :cool:
Stijloor
An external document can be used as design input. The key characteristic is external. Any document used in your quality management system but not produced by you. A simple matrix attached or linked to your document control procedure will suffice.
Stijloor.
P
pldey42
ISO 9001 does not require an external document master list so the auditor may be inventing a problem where none exists. Further, by suggesting a solution to the 4.2.3.f requirement the auditor is consulting and, if this is a Certification Body auditor, misbehaving.
A better audit question would have been, “What documents of external origin are used and how are they controlled?” This would be a valuable question to ask anyhow, for if there are no problems with the control and distribution of external documents, there is no need for a master list.
“Control and distribution” means making sure everyone is working to the correct versions of externally-generated documents, so the solution is more than a template: it's a process, of which a template might be a useful part.
Such documents will include, as has been said, specifications and drawings generated by customers and suppliers, contracts, reports generated by suppliers on request (e.g. reliability studies), international standards for equipment, components, interfaces and protocols, legal requirements, equipment manuals, calibration schedules, etc, etc. The intent is to make sure that everyone concerned can find the correct versions of such documents when they need to, that they are informed of changes, and perhaps are involved in approvals (e.g. of customer design change requests).
They do not necessarily need the latest versions of such documents and sometimes expressly need a specific, older version. For example, the help desk needs the documentation associated with product in the field, which might be a few revisions behind the material that R&D are working with. If there's a legal dispute, it may be necessary to go back to drawings, specifications, international standards and legal requirements pertaining at the time which, while obsolete, should be in the archives.
While most external documents will likely be available in some kind of internal (usually electronic) document control system, some (contracts perhaps) may only be in paper form and held confidentially by the contracts department, some (like international standards) will have been purchased, and some will be available on-line.
A single master list, if such is used, won't scale up. For organizations that have several projects or products in work at the same time, it will become a pinch point and the risk is that they will not use it. There might be a master list for each project in such circumstances.
But consider this: if the organization has a good electronic document control system, coupled with accountable document management processes (that, for example, identify those responsible for controlling documentation that comes from customers, from suppliers, from international standards bodies, from legal sources, etc, and faciliatating an appropriate change communication, review and approval process) and if documents are called up in a hierarchical structure by reference, one to another, what use is a master list?
A master list becomes rather cumbersome (or useless) when different teams need access to different versions of documents of external origin.
For example, we're communicating over the internet, and the communications protocol most of today's equipment uses is specified in something called IP, version 4. It's available online. The industry is working on equipment using a new version of IP, version 6, because IP v4 is running out of addresses and IP v6 offers the possibility of many, many more addresses. Specs for equipment like internet routers define whether they're IP v4 or IP v6 (or both). Many of the engineering companies that do this work employ knowledgeable engineers who do not need to be told what IP is or where to find its specs; it's part of their skillset. If their work involves contributing to developing and changing the IP v6 specifications themselves, they'll be communicating with other team members around the world using an internationally-agreed document control process, and trying to manage the IP specifications for such people using a master document list would be an unnecessary duplication of effort. (Furthermore, customers for such equipment usually only need to know if it's IP v4 or IP v6 (because they only want to know what they can connect to what) and do not need the specs themselves, so they won't attempt to control the specs as external documents.)
So I think the answer is not necessarily to give the auditor what is asked for, but instead find out what documents of external origin are used, how they are controlled now and whether the existing controls are effective. If they are, there's nothing to do. If not, maybe a master list would help, perhaps one per project or product line, but as part of a document control process. I would suggest that it might look like the suggestions above, and ought to show who is responsible for managing changes (not necessarily the same person) and making sure everyone who needs to know of changes is informed in a timely fashion. It also needs to take account of archiving previous versions in order to support maintenance of previous versions, and any liability issues that might arise.
Hope this helps,
Pat
P
Pamala
I've been asked to create a "users guide" for our external documents. This guide would tell anyone how to sign out an external document kept in the hard copy library. Anyone have a USERS guide template?
M Document Control Management - External documents flowed down from customers Document Control Systems, Procedures, Forms and Templates 2
A Document Control - Control of external documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
T Document Control at Suppliers - Control of External Documents ISO 13485:2016 - Medical Device Quality Management Systems 2
L Sample of Control of Document Procedure and Control of External Documents Document Control Systems, Procedures, Forms and Templates 2
Ed Panek External Standards List - Should this document include previously revised standards? ISO 13485:2016 - Medical Device Quality Management Systems 4
M How to Document Internal & External Communications - Suggestions/examples pls IATF 16949 - Automotive Quality Systems Standard 3
R External Standards List (Document Control) Document Control Systems, Procedures, Forms and Templates 3
smryan Satisfying the ISO 9001:2008 4.3.2.f External Document Control requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
F Can a website be considered a Document of External Origin? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
N How do you control weblinks used for external document requirements? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
P ISO 13485 Audit - EN 62366:2008 not in External Document File IEC 62366 - Medical Device Usability Engineering 1
C Document Control for External and Internal Projects (overseas projects) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
H External Document Control Procedure advice wanted ISO 13485:2016 - Medical Device Quality Management Systems 9
D Customer Quality Manuals - Document of external origin and must be controlled? Document Control Systems, Procedures, Forms and Templates 14
C External Document Control Document Control Systems, Procedures, Forms and Templates 2
D Customer Packaging Specification - File as a document of external origin? Document Control Systems, Procedures, Forms and Templates 1
M Gravimetric blender for resin in automotive industry - periodical calibration via external lab with certification Reliability Analysis - Predictions, Testing and Standards 0
T Company AS9100D External Audit Preparation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 17
D IATF16949 7.1.5.3.2 External Laboratory IATF 16949 - Automotive Quality Systems Standard 17
J 7.1.3.5.2 External laboratory - CIPM MRA IATF 16949 - Automotive Quality Systems Standard 3
W 7.1.5.3.2. External laboratory Sanctioned Interpretation IATF 16949 - Automotive Quality Systems Standard 4
T Internal and external communication procedure for Food Safety Food Safety - ISO 22000, HACCP (21 CFR 120) 2
J Biocompatibility for endoscope external handle/grip US Food and Drug Administration (FDA) 3
D 8.5.1.2 Validation and control of special processes requirements for Heat Treat External Processor AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
D IATF16949 external audit plan IATF 16949 - Automotive Quality Systems Standard 3
H Regarding external surface temperature limit requirement for lab incubators. CE Marking (Conformité Européene) / CB Scheme 2
A How to monitor new versions of external standards in your business Various Other Specifications, Standards, and related Requirements 2
Quality Specialist Quick question on the sequence of ISO 17025 external audits ISO 17025 related Discussions 14
M IATF external audit NC closure IATF 16949 - Automotive Quality Systems Standard 4
dubrizo Good Documentation Practice (GDP) as it Applies to External Contractors or Vendors Document Control Systems, Procedures, Forms and Templates 4
qualprod External consultant into a QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
W External PSU Providing a MOOP -- Will This Necessitate Conducted Emissions Testing? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
L AS9100 Section 8.4.2 - External provider test reports AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
Mikey324 External calibration - Finding in our 3rd party audit General Measurement Device and Calibration Topics 58
D Help Me. Non conformitty in External Audit IATF 16949 - Automotive Quality Systems Standard 13
P Is the second factor authentication (2FA) required for external users? Qualification and Validation (including 21 CFR Part 11) 1
J State of the Art for Documents of External Origin ISO 13485:2016 - Medical Device Quality Management Systems 17
D IATF 16949 SI 10, External non-accredited lab IATF 16949 - Automotive Quality Systems Standard 4
S Recommended software to send Quality scorecards to suppliers (external providers) Supplier Quality Assurance and other Supplier Issues 3
J External Standard Services Document Control Systems, Procedures, Forms and Templates 12
F Logistic/shipping companies as external providers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
J External third party audits Registrars and Notified Bodies 1
J Requirement for Retention of Records of Withdrawn Documents of External Origin Document Control Systems, Procedures, Forms and Templates 3
M Calibration Certificate Result issued by an accredited external laboratory General Measurement Device and Calibration Topics 9
L IATF external audit virtual (remote) IATF 16949 - Automotive Quality Systems Standard 13
A IEC 62304 safety classification, External Controls and off-label use related risks IEC 62304 - Medical Device Software Life Cycle Processes 5
R External Audit and Certificate prorogation due to the pandemic General Auditing Discussions 10
N Audit non-compliance API Q1 - Use of External Documents 4.4.4 in Product Realization Oil and Gas Industry Standards and Regulations 8
J 510(k) for a control kit for an external IVD test kit 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
