F and P-value in L9 Taguchi Design
javadaria61
#11
Dear Miner
Thanks again.
This book is very old and only in hard cover, and can not access to it. Is there any other book to cover this problem? Moreover, I have Qualitek and design expert software. can you tell me what's the tittle that I search it in google.
Javad
javadaria61
#14
Thanks for all of your help to me. But I have only work with software. And I don't have any basic information about experimental design. So, although you introduce very good resource for me, but I don't used them.
Thanks again for your patient and very kindly attention to me.
Javad
P
Performer
#15
Hi, I came through this post while googling for the same thing. Taguchi design L9 is a saturated model, if you did only 9 experiments. In that case, you can eliminate one or two less significant terms from the model. It is called 'pooling'. When you did one set of repetitions you will have 9 more equations for estimating statistics. DOF of error/residual will be 9. With that you can calculate F and P values. Refer the following book. It's simple and easy to understand.
Design of Experiments Using The Taguchi Approach: 16 Steps to Product and Process Improvement
#16
Dear Colleagues,
I have experiencing a similar situation that has been highlighted in this forum. I used L9 array for my experiment via Taguchi DOE. I tried to analyse the result but the p-value and f-value come out as *. I really need these values to explain the result of my analysis.
I have 4 factors at three levels. There are 2 responses (i.e. Response 1 and 2). Response is to be evaluated at "smaller the better" and Response 2 at "Larger the better". I have attached a spreadsheet containing the DOE with the response values.
I would be glad if you could help me out with this. It is very urgent.
#17
You do have the same problem. The L9 array has only four columns. When you use all of the columns as you have, you have a fully saturated model with no remaining degrees of freedom for the error term, which is required to calculate the F ratio and the p-value.
As with the previous poster, you only have two options:
  1. Pool one term with the smallest effect (remove from model)
  2. Look up the book that I referenced near the beginning of this thread and remove the quadratic terms leaving the linear terms.
#18
Thank you very much for the response to my question. I really appreciate. However, I could not get the book you referred to in your reply. I would be glad if you could attach the book for me to see the how to deal with the problem via the second approach as highlighted.
In my case, if i decided to remove one of the terms (which I tried doing and the factor removed was very important factor in my model development) it might not be able to explain the model i am intended to develop. Do you have any suggestion. Thank you.
#19
There is a link for the book in an earlier post. I will not attach copyrighted materials.
So the factor with the smallest effect size is that important?
The only other approach I can think of is for you to replicate the experiment and analyze the complete experiment using GLM (General Linear Model).
#20
Thank you very much.
In fact when I realized this problem, I quickly repeated each of the runs. The ANOVA results showed a good outcome. However, because I have already stated in my experiments that I used L9, the new GLM results showed 17 total degree of freedom instead of 8 which I am quite skeptical to report in my research results.
FYI: I have seen the link for the book.
What do you suggest in this case? Should I just go ahead to report it as it is shown in the ANOVA table?
This is the out of the ANOVA after repeating each of the runs
Var DoF) SS MS F-value P-value (%)
A 2 1335.90 667.95 1471.30 0.00 63.40
B 2 305.74 152.87 336.73 0.00 14.51
C 2 448.89 224.44 494.38 0.00 21.30
D 2 12.40 6.20 13.65 0.01 0.59
Error 9 4.09 0.45 0.19
Total 17 2107.01
Q Best approach to get a real value as average? Statistical Analysis Tools, Techniques and SPC 6
F Missing value of Uncertainty B Measurement Uncertainty (MU) 8
F Calibration certificate content - Average Value and True Value ISO 17025 related Discussions 6
S In BAC5300 we have machining mismatch allowed is 3tau, what is the value of tau? Document Control Systems, Procedures, Forms and Templates 1
S Change value of target during a batch Capability, Accuracy and Stability - Processes, Machines, etc. 0
A Acceptance p-value for linearity and bias analysis in minitab results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
A Torque Value for Different types of Fasteners (Socket Head, Button Head, CSK) Manufacturing and Related Processes 2
M IATF 16949 - 8.5.6.1.1 Providing a list of process controls: Does this requirement add value to QMS? IATF 16949 - Automotive Quality Systems Standard 4
Q Cycle times, value stream mapping, inventory, average values? Lean in Manufacturing and Service Industries 1
Ashok sunder What are the criteria for setting a target KPI value against a quality objective? Benchmarking 7
S Adding Value prior to signing EASA Form 1 EASA and JAA Aviation Standards and Requirements 5
M Creating a Plant Level Value Stream Map Process Maps, Process Mapping and Turtle Diagrams 1
A IMDS - Changing the Locked Weight Value RoHS, REACH, ELV, IMDS and Restricted Substances 1
T Value Chain Map for Food Services Industry Service Industry Specific Topics 1
O P-Value less than 0.05. but everything else in control Statistical Analysis Tools, Techniques and SPC 19
Q P x I = Value interpretation for residual risk? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
O CPK with a P value less than 0.005 Manufacturing and Related Processes 8
G What degrees of freedom means in uncertainty budget and how do I set the value Measurement Uncertainty (MU) 2
Q Really do they add value (Vision, Mission, Values)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D What is the exact Temperature Coefficient Value to be set on a Conductivity Meter? General Measurement Device and Calibration Topics 2
M Value Stream Mapping Calculations Process Maps, Process Mapping and Turtle Diagrams 5
L How to interpret the average R bar Value shown in the R Chart Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
G Non Value Added Corrective Actions IATF 16949 - Automotive Quality Systems Standard 15
R How To Calculate & Print CDF and Lower Bound CDF value for some t(time) with Minitab? Using Minitab Software 1
P Purpose of calculating Uncertainty value in calibration study Measurement Uncertainty (MU) 5
J Agenda of Value Stream Mapping workshop required Quality Tools, Improvement and Analysis 1
M What is the value of documenting in-process rework for easily-detectable issues? Quality Manager and Management Related Issues 4
R VSM - Value Stream Mapping (catheter manufacturing unit) Customer Complaints 10
W Quality for value adding or certification? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
T Cpk for 0 as Ideal Value Statistical Analysis Tools, Techniques and SPC 1
dubrizo Internal Audit Value - What is the point of conducting internal audits to a checklist Internal Auditing 40
L 5 minutes only for this Survey on the Value of PDCA and Your EMS Miscellaneous Environmental Standards and EMS Related Discussions 1
M How calculate P value for Linearity and Bias using Excel Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
Sean Kelley Value of Ppk or Cpk when targeting thinner material Statistical Analysis Tools, Techniques and SPC 4
B How to validate Microsoft Excel Spreadsheet Calculations for the Cpk value Capability, Accuracy and Stability - Processes, Machines, etc. 9
V Analysis of 'Value Added' System & Process Steps - Inspection Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
P Which ISO 13485 clause(es) are applicable for Value Proposition Creation ISO 13485:2016 - Medical Device Quality Management Systems 1
R The Value and Effectiveness of In Process Inspection Quality Manager and Management Related Issues 17
D Value-Added Analysis - Staff (Employee) Satisfaction Quality Tools, Improvement and Analysis 11
T ISO Auditor Training - What online training is actually value added? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
M Specific Capability case - Target Value is same as the Lower Limit Capability, Accuracy and Stability - Processes, Machines, etc. 9
S GR&R for an "R" value instrument installed on my 10K Horizontal Tester Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Value Stream Mapping for a Product Family Lean in Manufacturing and Service Industries 5
WCHorn Are Inspection Operations Value Added? Lean in Manufacturing and Service Industries 50
J How does Layout Inspection determine Reference Value? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S Labeling Medical/Health Value Claims with No Sources to Back Up EU Medical Device Regulations 1
W DIN ISO 1101 - Show me the General Dimensioning Tolerance Value Other ISO and International Standards and European Regulations 3
8 VSM (Value Stream Map) Issue Lean in Manufacturing and Service Industries 5
V Best value for choice/money - Smart phone vs tablet After Work and Weekend Discussion Topics 7
C P value not greater than 0.05 for Capability Analysis Statistical Analysis Tools, Techniques and SPC 3
