FAA RSM and QCM Manuals help!!!
W
warriorpilot
We need help, I need to find someone who can write both manuals for us?
Our manuals were rejected today!
I am running out of time, anyone recommends or advise any person or company that can write them?
:confused:
BadgerMan
It's best to do it yourself rather than to hire someone to try and document what you do. ARSA (www.arsa.org) offers a model RSM and QSM that you could use as a starting point to ensure that you cover all the regulatory requirements. I have heard that it's pretty comprehensive and that many FSDO's like the format. FWIW.
Oh, and I have no affiliation with ARSA whatsoever.
ARSA’s Model Repair Station and Quality Manual ("model manual") was completely revised to help companies develop a repair station and quality control manual that complies with Title 14 Code of Federal Regulations (14 CFR) part 145 and the associated Federal Aviation Administration (FAA) guidance material.
The new and improved model manual addresses every paragraph of 14 CFR part 145. It contains the requirements for both a repair station manual and a quality control manual and can be customized to the particular operation with approximately 20 to 40 hours of work.
This publication is geared towards small to mid-sized companies and will prove most useful to component repair stations. Although directed at domestic repair stations, very few adjustments would be needed to show compliance with foreign repair station requirements.....................
SPalmtree
I agreed with Badgerman, try your best to write it yourself otherwise you could end up stuck following procedures that don't fit your business model.
Make sure you keep in contact with the FAA and ask for advise when needed, in my experience they are willing to help, it's in their interest for you to comply with the requirements. Expect the manual to be reworked several times also before it's accepted, and probably a few times after as your Principal Inspector changes, as they all seem to have their own ideas on what is acceptable.
Don't try and copy someone elses RSM and QCM either, what was acceptable doesn't seem to be the case for a new applicant.
Stick with it, it will pass with work, and I found that writing the RSM and the QCM really were the hardest part of getting approved. Good luck.
K FAA Repair Station KPI's AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
D FAA inspection at my repair station - Rating Check Federal Aviation Administration (FAA) Standards and Requirements 0
DuncanGibbons FAA's Building Block approach to certification Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
DuncanGibbons FAA approval of articles (PMA, TSO) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
K FAA Audit - Major nonconformity for lack of timely calibration of two devices EASA and JAA Aviation Standards and Requirements 5
S FAA Form 8130-3 Signed in 2 places Federal Aviation Administration (FAA) Standards and Requirements 1
W FAA Advisory Circular (AC) Requirements (FAA AC 00-56) - Internal Audits AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
J FAA Maintenance Requirements - DER Repair to a PMA Part Federal Aviation Administration (FAA) Standards and Requirements 1
Sidney Vianna FAA and DCMA to leverage OASIS data to assist in planning risk-based oversight audits Federal Aviation Administration (FAA) Standards and Requirements 3
P EASA STC (Supplemental Type Certificate) on a Pre-mod FAA STC Configuration EASA and JAA Aviation Standards and Requirements 1
Q Supplier Accountable Manager Suspended - FAA 8130's while he is suspended? Federal Aviation Administration (FAA) Standards and Requirements 1
I Meeting AS9100, FAA, Transport Canada, EASA Training Requirements - Vent/Rant Coffee Break and Water Cooler Discussions 2
A ISO 9001:2015 vs. FAA, CASA, PNG 173 Requirements Federal Aviation Administration (FAA) Standards and Requirements 11
D When to complete FAA Form 337 (Major Repair and Alteration) Federal Aviation Administration (FAA) Standards and Requirements 4
S New FAA Form 8130-3 Effective 2/1/14 - Unlocked version attached Federal Aviation Administration (FAA) Standards and Requirements 3
D Technical Data required in Block 13 (Remarks) or FAA 8130-3 Federal Aviation Administration (FAA) Standards and Requirements 4
D FAA 8130-3 Repaired Leather Dress Cover problem Federal Aviation Administration (FAA) Standards and Requirements 2
F What is an FAA PAI Maintenance Function List? Federal Aviation Administration (FAA) Standards and Requirements 3
X EASA Part 145 / FAA Bilateral Agreement vs. Manufacturing under EASA Part 21 EASA and JAA Aviation Standards and Requirements 2
F What are the requirements for authorized person to release FAA repair shop product AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
I Where do we submit the FAA Preapplication forms? Federal Aviation Administration (FAA) Standards and Requirements 1
F When TSA stop to issue new Foreign FAA Part 145 Repair Station? Federal Aviation Administration (FAA) Standards and Requirements 1
F FAA Repair Shop Airworthiness Directives (AD) Application Help Federal Aviation Administration (FAA) Standards and Requirements 2
F FAA Letter of Need to establish Continuing Need Federal Aviation Administration (FAA) Standards and Requirements 1
C FAA/PMA Part Marking Requirements Federal Aviation Administration (FAA) Standards and Requirements 2
C AS9100C Audit must include FAA Part 145 (FAA Repair Station)? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Z Comparison between AS9100 and FAA 145 Repair-Station (CFR's, FAR's) Federal Aviation Administration (FAA) Standards and Requirements 3
Jim Wynne Breaking News: FAA Announces Ban on Plane Crashes Funny Stuff - Jokes and Humour 7
C FAA Part 145/M Compliance Checklist EASA and JAA Aviation Standards and Requirements 7
A FAA 8130-3 Approval acceptance by EASA DOA EASA and JAA Aviation Standards and Requirements 4
R FAA Part 145 Vs. AS9110A Comparison and Differences Matrix Federal Aviation Administration (FAA) Standards and Requirements 6
P Currency of Technical Data - FAA Part 145 Repair Station EASA and JAA Aviation Standards and Requirements 4
B Overhaul vs. Repair vs. Rework - FAA Definitions Federal Aviation Administration (FAA) Standards and Requirements 7
C New Guidance for FAA 145's with EASA Authority Federal Aviation Administration (FAA) Standards and Requirements 4
Marc Acronym FAA - Some FAA Acronyms Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
michellemmm Looking for SOI #2 Checklist and Guidance on FAA Level of Involvement Federal Aviation Administration (FAA) Standards and Requirements 1
D ITAR and FAA Repair Station Security Planning - Visitors IEC 27001 - Information Security Management Systems (ISMS) 4
B Writing a QMS Manual for our FAA 145 Repair Station AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
J Writing FAA Certification Plans - Compliance of the Design to the applicable FARs Federal Aviation Administration (FAA) Standards and Requirements 3
J FAA Requirements for Design and Manufacturers of Engine Turbine Mechanical Components Federal Aviation Administration (FAA) Standards and Requirements 2
apestate FAA Regulations: Is it ever OK to sign off on nonconforming type certified parts? Federal Aviation Administration (FAA) Standards and Requirements 8
H FAA Operator - Acceptance of EASA Form 1 for Repaired Parts EASA and JAA Aviation Standards and Requirements 5
J FAA Airworthiness Requirements Federal Aviation Administration (FAA) Standards and Requirements 3
Q Upcoming FAA Audit - What to expect (subtier for a Repair station)? Federal Aviation Administration (FAA) Standards and Requirements 5
C FAA Part 145 Compliance Statement help Federal Aviation Administration (FAA) Standards and Requirements 8
C FAA 8130-21G Airworthiness Approval Tag Form - New Changes? Federal Aviation Administration (FAA) Standards and Requirements 5
J AS9100 & recent amendments to FAA Title 14 (14 CFR) Federal Aviation Administration (FAA) Standards and Requirements 2
O Where to find FAA Part 21 Federal Aviation Administration (FAA) Standards and Requirements 3
D FAA Drug Testing Requirements - FAR Part 145.211 (c)(1)(vi) Federal Aviation Administration (FAA) Standards and Requirements 8
