Factory Inspection to Register and Certify a Medical Device in Brazil
Marcelo
#21
Usually from 6 to 10 months, but Anvisa is late in all registrations due to someproblems. A 8-12 months estimate is a better guess right now, but it can go beyond 12 months.
K
krishna007
#23
Dear Marcelo & Fellow Covers
we manufacture and want to register a Class IIb (in EU) device in Brazil. as you previously mentioned:
there would be 2 audits
1.B-GMP inspection
2.electro medical equipment certification
I have Questions on both:
1. B-GMP
- is this a mandatory requirement
- would ANVISA able to conduct this audit
- would there be any other organization/3rd party who conducts this audit - when can we expect this audit
- How can we argue that this audit is not necessary
2. electro medical equipment certification & relevant audit
- did i understand right that this is INMETRO mark
- which resolution and regulation of ANVISA cites this requirement - is it RDC 32-2007 & IN 08-09. do you have these in English
- what is the INMETRO certification process
- does it involve a audit/factory inspection
- who are authorised to do this
- can we argue anything against having the audit - i believe this might not be different from other audits we have for our produc certification
- Since we have periodic CSA audits, can this satisfy the requirement
- our Lab is accredited by DA Tech which is a ILAC member. does this argue our case for not having one more audit
- we also have our notified body, can our notified body help in this case, if so how
I am sorry to have set a flurry of questions. But i really need some help here!
Eager to see your feedback.
Greetings, Krishna
Marcelo
#24
1. B-GMP
B-GMP is mandatory for all medical devices. The B-GMP certificate is required for some.
Anvisa conducts the audit.
No.
It depends on when you requires the audit. Right now there´s months for the schedule.
You can´t.
Yes.
Yes. No, not in English.
Process for certifying medical electrical equipment according to IEC 60601 series of standards.
Yes.
product certification bodies accredited by Inmetro for this scope.
No. According to the new regulation which wil be published may/june 2010, you can use a valid ISO 13485 certificate or B-GMP certificate for accepting part of the requiements, but there will still be a need to audit some other parts.
No.
No. Audit (certificiation bodies) and test reports (testing laboratories) are two different parts of the process.
If your notified body certifies your ISo 13485 system (and it has a MOU with the brazilian certification body and fulfills some other requirements) you can use this certification as mentioned above.
DesiQE
#25
Marcelo,
Thanks for the great insight into the ANVISA. We were just told by our distributor for class III medical devices that for the next few products we register, we will be needing the ANVISA GMP certificate. From all the inputs from you, I gather that although we have ISO 9001 & ISO 13485, we will still be audited. Would you know of any consultant in India that would help us get there? As ANVISA is so close to US FDA GMP (like you mention), this would be nice to have as a step toward US FDA.
:thanks:
Marcelo
#26
ou correct, even having cartification for ISO 9001 and ISO 13485 you will stil need to be audited by Anvisa.
Sorry, i do not know of any consultant abroad that knows the brazilian regulation, as close to the GMP as it gets. There´s two main problems here:
1 - the portuguese language
2 - the fact that Anvisa inspectors have their own "way" of seeing things..so, it´s interesting to have info on other inspections as a way to better help - this info is also difficult for consultants from abroad to have.
jewels
#27
Does anyone know if the Anvisa requirements have changed lately. We were working with a distributor early in 2009 and got all the documents to them and then they said it was too late to send them in. That they had a deadline with Anvisa to submit the documents and that deadline passed. So we identified a different distributor.
Now we're working with a new distributor and they are pushing to get the supporting documents to send to Anvisa quickly. In their push, they told me that requirements changed as of July 1, 2010 requiring inspection of the manufacturing facility annually at a cost of $20,000 each year. I can't believe
that Brazil would require annual inspection of our facility each year???? We are ISO13485, our products are CE marked and we obtain US FDA 510(k) clearance for our products. This proposed inspection seems way over the top!
Were there any changes to the Anvisa requirements for diagnostic testing kits (medical devices) in the last year or so?
And if anyone has any information on inspections....please enlighten me. This is all new and from my understanding all the documents available from Anvisa are in Portuguese. Are there US based inspectors that can do this inspection at a more reasonable cost than $20,000 if this truely is something we're going to need to do?
Thanks!!!!!
Marcelo
#28
There´s been a lot of modifications in the past year or so. Please take a look at this thread - Medical Device Registration Process in Brazil - Anvisa - for more info.
The requirements changed as of May 21 to be more precise - one year after the publication of RDC 25, which is the regulation which now requires a B-GMP for some devices. I thinsk someone should have told you this way before.
I can't believe that Brazil would require annual inspection of our facility each year????
It´s being required.
It does not matter as those are not "recognized" by Anvisa.
You are right, there´s no official english information from Anvisa on brazilian medical devices regulations.
No, the inspection has to be done by Anvisa.
MIREGMGR
#29
I reckon the company for which I work isn't the only one that has looked at the market barriers and decided that, for the foreseeable future, our products just won't go into Brazil.
As we're a long-time, key supplier of disposables and accessories for several Tier 1 global makers of medical imaging equipment, that's likely to be both disruptive for our customers and disadvantageous for Brazilian doctors and patients, but we just can't justify the regulatory hassle-factor required to support the Brazilian market when there are many other markets with harmonized regulatory systems that are eager for greater access to our products.
Marcelo
#30
You are so true, and it´s my main worry that more of the medical device innovations won´t arrive in Brazil because of this (i mean more because we were always behind before, but with these new regs things might have sky-rocketed).
S QUALITY OBJECTIVEs for third party garments factory inspection ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
D Lean and Elimination of QC Inspection Points in a New factory Lean in Manufacturing and Service Industries 9
supadrai Remote Opportunity - Large Scale Glove Factory QMS / RA / Legal Job Openings, Consulting and Employment Opportunities 0
R Project Transfer to New Factory ISO 13485:2016 - Medical Device Quality Management Systems 6
D Clothes changing in pharmaceutical factory Manufacturing and Related Processes 8
M Benefits of Safety Helmet in manufacturing factory Service Industry Specific Topics 2
N IATF 16949 7.1.5.3.2 External Laboratory - Calibration of Nikon machine in factory IATF 16949 - Automotive Quality Systems Standard 24
B IATF 16949 manufacturing cell in ISO 9001 factory? IATF 16949 - Automotive Quality Systems Standard 15
E Measurement System Analysis/validation to new factory Manufacturing and Related Processes 2
S ISO14001:2015 Factory Process Mapping ISO 14001:2015 Specific Discussions 7
J Starting from the factory floor get any respect? Coffee Break and Water Cooler Discussions 13
D 5S Implementation in Cement Factory Manufacturing and Related Processes 3
M Lux Level for Orthopaedic Implant Factory Other Medical Device and Orthopedic Related Topics 4
D TS16949 & Design Responsibilities of a Contract Manufacturing Factory IATF 16949 - Automotive Quality Systems Standard 1
H Factory Dictated Sample Size Justification Statistical Analysis Tools, Techniques and SPC 9
Marc Definition IFAT - Integration Factory Acceptance Testing Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
Marc Definition FAT - Factory Acceptance Testing Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
L How to add a New Factory under a Prior 510K Establishment US Food and Drug Administration (FDA) 2
M Textile Control Plan for Electric Blanket Factory Supplier Quality Assurance and other Supplier Issues 2
S Need Supplier Audit Form to Audit Supplier or Factory Supplier Quality Assurance and other Supplier Issues 2
S Compliance and Certificate requirements for FDA Compliant Wheelchair Factory 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
S ISO 9001 Registration for Factory Site Only ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S Ipad or Tablet for Work Instructions (WI) in Factory Manufacturing and Related Processes 2
K Building Heavy Pollution Factory next to Medical Device Factory (ISO 13485) ISO 13485:2016 - Medical Device Quality Management Systems 6
U ISO 13485 mandatory for a factory making Medical Devices for EU? EU Medical Device Regulations 6
Q Factory Acceptance Test Report example wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S Calculating Cycle-Time for a factory line that produces each-design-different parts? Lean in Manufacturing and Service Industries 7
Stijloor A Dutch Factory Town, Now a Design Center Coffee Break and Water Cooler Discussions 4
Q Do we need to keep MSDS documents for all "chemicals" used in the factory? Occupational Health & Safety Management Standards 4
S Christmas Joke - The "Tickle Me Elmo" Factory Funny Stuff - Jokes and Humour 0
H FAI inspector could be a operator of factory, is it right? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
A What is more important - Head office OR Factory? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
G New gage calibrated at factory do I need the certificate? Calibration Frequency (Interval) 4
W Need a QA/QC plan for a Woodworking Factory Manufacturing and Related Processes 4
R APQP process as a planning tool for moving product lines to another factory APQP and PPAP 4
B What is Customer Owned Property for moulds and spare parts factory ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D 5S Templates for implementation in a concrete manufacturing factory Document Control Systems, Procedures, Forms and Templates 7
8 Simulated Factory - Assistance in simulation of a factory with a view to improving it Lean in Manufacturing and Service Industries 3
P How to plan new capacity for a cement tile factory Capability, Accuracy and Stability - Processes, Machines, etc. 11
S Resources about Visual Management - Visual Factory wanted Lean in Manufacturing and Service Industries 6
O Turkish factory under US umbrella - Small medical device manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 6
D Factory Air Quality Testing Miscellaneous Environmental Standards and EMS Related Discussions 4
K Factory Quick Assessment Model - Assessment a small factory (<50 employee) Human Factors and Ergonomics in Engineering 8
K Role of IT Head in Pharmaceutical Manufacturing factory - Especially during Audits? Career and Occupation Discussions 6
Q VDE Audit Experiences - German VDE factory certification audit General Auditing Discussions 5
J Establishing Proposal Metrics in a Factory Construction Company Quality Tools, Improvement and Analysis 6
Z Validation Of Process for Vehicle Manufacturing Factory ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
R Could Factory Process Auditor and Industrial Engineer Coexist? Lean in Manufacturing and Service Industries 2
P Small Business Spreadsheet Factory - a good site for excel, word ... Excel .xls Spreadsheet Templates and Tools 4
M Data Protection Act that publishes information within the general factory area Records and Data - Quality, Legal and Other Evidence 3
