An AS9102 FAI requirement was flowed down from my customer for an assembly we are building for them. We will be generating an FAI for the assembly. However, the assembly is made up of two parts, both of which are source-controlled by my customer. The source control drawings call out a standard military part that is available from distributors. The source control drawings do not specify any modifications to these parts. They simply lift the part information from the mil spec. How do I attack the FAI for these?
I do not have access to the manufacturing information for these parts as they technically are catalog items. Do I just fill out Form 1 with the drawing part number then list the mil / catalog part number in the Parts List section?
If you have run across this before, how did you address this?
