G
I am a new QA Manager to an ISO 9001:2008 company that builds aviation test equipment. For electronic and mechanical components, the current FAI procedure requires the vendor to supply the FAI data, which is then reviewed by the QC Inspector and then forwarded to Engineering. I do not see and issue for FAI testing of the vendor supplied electrical sub-assemblies since our Electrical Engineering has adequate capability and equipment.
For mechanical parts, however, the QC Inspector, nor does Mechanical Engineering, have the equipment to perform a complete FAI inspection. We must rely on the FAI Report from the vendor to state if the parts mechanically pass or fail.
Currently, the QC Inspector will initially verify if the FAI report and CoC is present with the shipment, and then measure what dimensions that they are able to. The parts are then forwarded to the ME who will do much of the same before approving the FAI. There are no instructions as to what dimension(s) should be measured, its a best effort depending upon the type of feature.
My first question is if it is acceptable to rely on the vendor to perform the FAI measurements and not verify this in-house? If not, do we have to invest in the metrology equipment and should the FAI inspection be the responsibility of QC or Engineering?
As always, your inputs are greatly appreciated.
gjkoenig
gjkoenig
