FAI (First Article Inspection) using Digital Design Data
K
kiwisfly
A recent article on the QF A380 incident highlighted a significant error caused by the FAI being undertaken against the manufacturing data rather than the original (digital) design data. I have come across this a few times and must admit that I probably have not paid enough attention to the original design data when reviewing the FAIR. In the incident, the FAIR was correct against the manufacturing data but the manufacturing engineers had made an error in the transfer from the design data. Does that mean that all FAI should only be against original design data? What if the manufacturer only receives digital design data, should auditors be checking that the transformation to manufacturing data ensures the design characteristic results? Should FAI only be against original design data? (somewhat rhetorical these) Any thoughts??
dsanabria
Re: FAI using digital design data
Are we discussing FAIR as in AS9102 or FAI as in production First artcle inspection.
I am thinking AS9102... so
We want to approach this as a process and the intent of AS9102 is to validate that the Manufacturing process is effective.
The manufacturing engineering process has a couple of areas to validate the effectiveness of their process. It appears by your statement that the engineering process needs to be evaluated and appropriate adjustments be made to minimize RISK.
K
kiwisfly
From AS9102:
FIRST ARTICLE INSPECTION (FAI): A complete, independent, and documented physical and functional inspection process to verify that prescribed production methods have produced an acceptable item as specified by engineering drawings, planning, purchase order, engineering specifications, and/or other applicable design documents.
FIRST ARTICLE INSPECTION REPORT (FAIR): The forms and package of documentation for a part number or assembly, including FAI results, as per this Standard.
I posted the same query at LinkedIn (AS91XX Series - Tips and Advice) if anyone is interested. There has been some useful contributions from Leon Himmelfarb and Jack Fletcher.
Cheers,
dsanabria
The Organization should conduct the following activities in support of FAI.
1. Review documentation for the manufacturing process (e.g., routing sheets, manufacturing/quality plans, manufacturing work instructions, etc.) to make sure all operations are complete as planned.
2. Review referenced exhibits supporting the FAI (e.g., inspection data, test data, Acceptance Test Procedures, etc.) for completeness.
Did I missed the question?:confused::confused:
K
kiwisfly
Yes you did, the question related to the completion of First Article when only digital design data is provided. No problems though, other site has been very informative, too much to repeat here.
Cheers,
dsanabria
OK, thought I provided the answer on other post but for other readers - AS9102 is not clear how digital design characteristic is handled.
Too often, the blames goes to the Quality department for missing something that they have no control over it, no tools or appropriate training nor time to review engineering works. AS9100 / 9101D OER provides a process to make those verification and validation (7.3) and internal auditors do not review that process or the RISKS associated with those process.
rider1
It is critical to maintain data set integrity (model, part list, notes). Ideally you do not want to translate the data from one format to another but... sometimes you just have no choice (CMM software, customer, etc.). You must create a procedure covering:
a. Procedure describing how to ensure all model based surfaces have been inspected.
b. Inspection format (E.g. number of data points per surface area).
c. Output format.
d. AS9102 FAI report format.
e. Inspection CMM software and Product Acceptance Software (PAS) (E.g. Cosmos, PCDMIS, etc.) to include the name, version, date of purchase, training certificates, etc…
f. Inspection CMM software and Product Acceptance Software (PAS) validation and certification procedure (i.e. calibration and validation certificates)
g. Software used in CAD/CAM (CATIA, ENOVIA etc.) and translation required from CATIA native data sets to include name, version, date of purchase, training certificates, etc…
h. Data/Model integrity:
ii. Verification procedure
iii. Translation validation procedure
i. Industry specifications conformance (AS-9100, etc…)
j. Inspection Process Planner software (DELMIA – DPM IPP2, Verisurf, …) to include name, version, date of purchase, training certificates, etc…
k. Supplier control
l. Training control
Take a look at ASME Y14.41-2003, you will find a lot of useful information.
K First Article Inspection (FAI) - Equipment used - Dimensions vs. Go/No-Go ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Is a First Article Inspection (FAI) Procedure required by ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 3
M FAI AS9102 - What does a First Article Inspection cover? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
U Whether First Article Inspection Report- FAI is mandatory for regular Human Factors and Ergonomics in Engineering 4
R AS9100 FAI - First Article Inspection to a prior Customers PO AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
G FAI (First Article Inspection) Responsibility - QC or Engineering? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R FAI (First Article Inspection) on source-controlled parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
K FAI (First Article Inspection) vs PPAP (Production Part Approval Process) APQP and PPAP 16
T FAI (First Article Inspection) of Large Assemblies/Tooling after move to new building AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
Q FAI IAW AS9102 - First Article Inspection Documentation Question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 20
D AS9102 B (FAI - First Article Inspection) is Released - October 2014 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
A AS9102 First Article Inspection and NC Parts - New FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D Delta or Partial FAI (First Article Inspection) - What are the differences? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
G What is meant by FAI (First Article Inspection) and how do we comply? AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 26
C Inexperienced Mechanical Inspectors and FAI's (First Article Inspection) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
L FAI (First Article Inspection) of Prototype Parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
S FAI (First Article Inspection) during Assembly of Sub-Assemblies Only AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
F Can you reference original FAI (First Article Inspection) after Delta? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R FAI (First Article Inspection) Report Number Method AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
Z AS9102 FAI (First Article Inspection) - Is a Ballooned Drawing Required? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
H FAI (First Article Inspection) Software Recommendations and Help Quality Tools, Improvement and Analysis 11
B AS9102 FAI (First Article Inspection) per standard or contract? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
L Selling Products Produced before First Article Inspection (FAI) Approval AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
E Understanding terminology for FAI (First Article Inspection) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
T FAI (First Article Inspection) - How many parts are measured AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S FAI (First Article Inspection) and Key Characteristics Requirements - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
J AS9102 FAI (First Article Inspection) Full or Partial - Changes to NC programming Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
J FAI (First Article Inspection) Do as I say not as I do AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
P Design Characteristics of the FAI (First Article Inspection) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
P First Article Inspection - FAI for every new product launch AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
K Incoming Materials First Article Inspection (FAI) Procedure needed Document Control Systems, Procedures, Forms and Templates 2
T First Article Inspection - Is FAI Design Verification? Design and Development of Products and Processes 3
M Measure "TYP" dimensions on a first article inspection (FAI) report? ISO 13485:2016 - Medical Device Quality Management Systems 10
I FAI (First Article Inspection) for Bulletproof Glass normally for Autos? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
I FAI (First Article Inspection) for Chemical companies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M Help needed with brilliantly engineered FAI (First Article Inspection) form 3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
I FAI (First Article Inspection) per AS9102A include gen. notes on form 3? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
gard2372 Our Parent company is our supplier? FAI (First Article Inspection) not required? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
B FAI (First Article Inspection) per AS9102 Form 2, sections 5 & 6 question Document Control Systems, Procedures, Forms and Templates 10
T AS9102 FAI (First Article Inspection) Form example Document Control Systems, Procedures, Forms and Templates 35
A AS9100 Clause 8.2.4.2 - First Article Inspection (FAI) - How do you comply? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
M First Article Acceptance FAI Letter and related Letters of Approval Supplier Quality Assurance and other Supplier Issues 10
A First Article planning - Is an FAI timeline for the product the same thing? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
L FAI Charge General Auditing Discussions 3
D "FAI" Requirements/Process for New Supplier Materials Design and Development of Products and Processes 3
H FAI Requirement After Moving CNC Machine? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
DuncanGibbons Pre FAI production terminology AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
NDesouza Is my Partial FAI an Assembly or Detail? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R FAI & P.O. Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 21
M Weld Symbol--Bubble Drawings for FAI Document Control Systems, Procedures, Forms and Templates 4
