Failed Calibration - Plain Plug Gages - They grow!
Wayne
Gage Crib Worldwide
#11
Gages can grow
Hardened steel does have the propensity to grow. The growth is usually noticed in larger sizes because it is an in/in type growth. I do not know the size the gage in question, but if it is noticeably growing I expect that it is over an inch in diameter.
What happens is when the steel is hardened the modules are trapped in stasis. Slowly the molecules relax and as they relax they cause an expansion of the material. The gradual relaxation process takes about a year. The larger size the more the change is noticed. The tighter the tolerance the more the movement is noticed.
To combat this phenomenon gage makers require that their hardened steel be triple cold stabilized. The process requires the gage to be cycled three times through a freeze/thaw process. This procedure will reduce the probability of gage growth. Note the use of the word “reduce” instead of “eliminate”.
Craig H.
#12
Wayne:
GREAT first post!!!! Welcome to the Cove!
Craig
Wes Bucey
#13
I, too, am impressed with this little bit of metallurgical legerdermain!
Who knew? (Let alone "suspected" such a thing could be?)
I gave you some "karma" for this helpful addition to our knowledge base. To see exactly how much, click on "User CP" in the navigation bar near the top of this page.
Welcome to the Cove!:bigwave: We'll be looking for more good things from you.
Dave Dunn
#14
Not something I'd expected to find in a material such as steel, but common in plastic processing and called molded-in stress. It's very common for plastic parts to slightly change in size just over time after molding, and more profoundly if the part is subjected to environments of high moisture or heat. The heat allows the molecules in plastic to relax and relieve the locked-in stress.
Very interesting to find out that steel can show similar properties.
#15
Ah.... Ok, I did know that this can happen and have seen examples, but nobody ever explained it to me before. Thank's Wayne.:agree1:
Furthermore: This can serve as food for thought for anyone who believes that there is no need to calibrate a tool that has not been in use. Std comment: -That is not necessary. It has not been out of the box, so what could possibly have affected it? Well, something could...
/Claes
Wayne
Gage Crib Worldwide
#16
/Claes
The probability of growth is most likely noticeable:
1. If the gage is over an inch in size. Because the growth is compounded as size gets larger it will be more apparent. On smaller tools the growth will most likely be considered within the range of uncertainty or be explained away as being from different technician/equipment/laboratory variation.
2. In the first year after it has been hardened. Most of the movement is aged out of the steel after the first year. Things like temperature variation and gage use will encourage faster aging. Being unused and in a box may encourage slower aging to a small degree. Any growth detected after the first year will most likely be considered within the range of uncertainty or be explained away as being from different technician/equipment/laboratory variation.
Jen Kirley
Quality and Auditing Expert
#17
I knew about expansion coefficients in high temperature environments and the subsequent need to control inspection lab environment, but I hadn't yet heard of the molecule relaxation phenomenon. Thanks for such excellent input, and welcome to The Cove! :bigwave:
cokyat
#18
I just read this posts and found out that I encountered the same situation back in 2001. Three things:
1) You gauge the Laboratory who conducted the Calibration by conducting an audit in the laboratory sight or at least talk to an official. Know whether they are practicing a valid calibration procedure (ASTM, ANSI,etc. where these standards require specific controlled calibration laboratory conditions like Temperature and Humidity) and know whether their calibration personnel have sufficient training and education.
2) Submit the gage to a different calibration agency (If resources are available otherwise, in-house observation). Compare the result to the first calibration.
3) Decide if you will replace this Agency based on the results of the two items above otherwise this event might happen again and your product quality inspection activity can be inaccurate.
#19
This should be done before deciding on a calibration source, of course.
Having two different sources check the same gage and get different results tells you only that one or both of them are wrong.
Wayne provided what appears to be the most likely explanation; your first two items, while providing additional evidence, likely won't provide enough to make a decision on sourcing.
Chitchat
Registered Visitor
#20
Re: Gages can grow
Hi Wayne,
Does the same princilple hold true for smaller size gages? I have a number of gage sets that have failed calibration where the gages have grown in size. For example: Deltronic imperial Class X+. Initial calibration was performed in 2007, front and back, subsequent calibrations performed at three positions, see attached data. These pins are typically used for measure the internal diameter of extruded material.
Thanks for your help!
G Gage Recall Analysis - Threaded Plug Gage has failed Calibration General Measurement Device and Calibration Topics 10
Q Micrometers to Measure Coating Thickness - Failed Calibration Flatness & Parallelism General Measurement Device and Calibration Topics 9
P Thread plug gauge failed calibration - Must I remeasure everything measured with it? General Measurement Device and Calibration Topics 23
D Transformation of Data Normality Failed Using Minitab Software 11
C TL-9000 Certifying Body Issue - Auditor failed to find an issue for 10 years TL 9000 Telecommunications Standard and QuEST 16
J Ignoring a Failed Gage R&R and upcoming external audit IATF 16949 - Automotive Quality Systems Standard 22
A Failed the AS9120B Exam Twice.....Need Help AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
S FDA electronic submission gateway (ESG): FAILED eMDR Submission Other US Medical Device Regulations 3
Q How to manage with customer % failed product ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
D Will A Few Failed Solder Joints Make Me RoHS Non Compliant? RoHS, REACH, ELV, IMDS and Restricted Substances 9
R Registrars offering to perform Second Party Audits - Have they failed their role? Registrars and Notified Bodies 105
N Final Inspection Retesting for Failed Batches Nonconformance and Corrective Action 6
S Statistics and Sampling - Accounting for Failed Tests Statistical Analysis Tools, Techniques and SPC 10
D Failed 350-018 exam Professional Certifications and Degrees 3
P Is it necessary to perform Root Cause Analysis for each failed part? Problem Solving, Root Cause Fault and Failure Analysis 16
S ISO/TS 16949 In Doldrums - Just failed disappointingly in the ISO9001 System Audit General Auditing Discussions 7
I I failed my CQE Exam Professional Certifications and Degrees 21
S Heating Test Failed - Capacitor in secondary exceed its rated temperature IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
Marc A NASA Failure Analysis of the April 28 2010 failed balloon launch World News 0
Moncia Traceability System to trace Failed Product for Corrective Action ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 38
Marc Saturn: Why one of Detroit?s brightest hopes failed World News 4
R My C=0 sampling failed to detect parts are out of round Inspection, Prints (Drawings), Testing, Sampling and Related Topics 20
S Supplier Development Process failed - Question regarding sub-suppiler audits IATF 16949 - Automotive Quality Systems Standard 4
J Canadian Medical Device License Requirements - What if we failed to meet it? ISO 13485:2016 - Medical Device Quality Management Systems 4
M Readiness Review Failed - Stage one audit for TS16949 IATF 16949 - Automotive Quality Systems Standard 7
Marc Has an Implementation by a Consultant EVER Failed? Consultants and Consulting 62
E Jumpstarting a Failed System ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
M About companies that have failed a surveillance audit Registrars and Notified Bodies 2
A Employee Support after Failed Promotion - Feelings of rejection, disillusionment, etc Career and Occupation Discussions 1
A Failed Re-Certifications - 9th Cycle Survey posted on the ISO website Registrars and Notified Bodies 2
lanley liao Question regarding the calibration of monitoring and measure equipment. Oil and Gas Industry Standards and Regulations 0
N IATF Calibration Lean in Manufacturing and Service Industries 4
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
E Calibration Records needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D Limited Range Calibration - 5000 lb Industrial floor scale General Measurement Device and Calibration Topics 3
D Calibration of Small Scales General Measurement Device and Calibration Topics 26
I IQOQ or just initial calibration required? General Measurement Device and Calibration Topics 3
B Calibration in real life ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Ron Rompen Calibration by manufacturer ISO 17025 related Discussions 4
Q Calibration verification records 7.1.5.2.1 IATF 16949 - Automotive Quality Systems Standard 2
W Next Calibration Due Date Calibration Frequency (Interval) 5
