Failure Modes for Public Transport Vehicle Door Assembly - Your inputs please!
F
FroZen
Hello, I am currently trying to set up an FMEA for our company.
In this plant they are assembling doorsystems for public transport vehicles.
I listed all process steps, from part receiving to shipping, and now I am trying to determine the potential failure modes.
For the receiving and assembly proces I currently have the following failure modes:
Receiving and incoming inspection:
Parts are damaged.
Mis-labeled.
Missing label.
Wrong quantity.
Bad part passed inspection.
Parts are not according to specification.
Handling damage.
Placed in wrong location.
Assembling:
Part not mounted.
Wrong part mounted.
Part is not in accordance to specifiactions.
Handling damage.
Incorrect fasteners used.
Part is fitted to loose / over torque.
Step is not performed.
Wrong glue used.
Defects are not noticed.
These are the points I could think of.
What is your view on this, is this good, do I miss something or is this totally wrong?
Thanks in advance.
PS. Sorry for my bad English.
F
FroZen
Re: Failure Modes for Public Transport Vehicle Door Assembly
Thanks for your reaction.
I forgot to mention that I am making and Process FMEA and not an Design FMEA.
I already looked into that example before, but could not extract any information since it's an Design FMEA and about spraying parts.
In this plant parts are not getting adapted, it's just mounting parts for the doorpanel with screws, bolts and glue.
harry
............................. In this plant parts are not getting adapted, it's just mounting parts for the doorpanel with screws, bolts and glue.
If you can describe the step by step flow of this assembly process, it may be easier for others to share their opinions.
F
FroZen
Pre-mounting
Study drawings
Take parts from order car
Mount "Flapframe side" to "Flap frame extrusion" [2x M6 torx socket button screw ]
Mount "Flap frame inside" to "Flap frame extrusion" [1x M6 torx socket button screw ]
Shove "Tapping strip" in "Flap frame extrusion" and secure [2x M8 torx socket button screw + locking disk spring]
Shove "Tapping strip" in "Horizontal doorprofile" and secure [2x M8 hex head cap screw + locking disk spring]
Put the parts back on the order car
Assemble frame
Put 2x "Vertical doorprofile" on worktable
Mount "Horizontal doorprofile" [4x M6 Socket cap screw]
Mount "Flap frame" [4x M6 Socket cap screw + locking disk spring]
Check for flat connection between different profiles, possibly adjust
Mount "Coverplate" [4x M6 Socket cap screw]
Run through test- and inspection report
Put doorframe on waiting frame
Glue glass
Put doorframe on worktable
Apply sealing tape around the doorframe
Apply primer on the doorframe [Prep L]
Clean ceramic screening on the glass [Cleaner I]
Check glass for deviations
Mount "Handle plastic" in the glas (1 Nm) [2x M5 hex flange nut + Loctite 243]
Apply kit on the doorframe [STR 360]
Position glass on the doorframe
Press glass to sealing tape and secure with tape
F
FroZen
Anyone who can help me with this ?
RoxaneB
Awwww....the good ol' days when I worked for a public bus manufacturer. I'm curious now if we worked for the same company or the competition. Feel free to PM me to resolve that issue. ;)
That being said, having developed some of the documentation for the manufacturing processes, I did much of it with a cross-fuctional team. I trusted THEM to be the experts and my role was simply to facilitate the process. Could you do the same?
F
FroZen
I think it could be useful to see the entire sheet of your P-FMEA to have an overall overview.:bigwave:
The FMEA isn't written in English, so i think it won't help anything.
Awwww....the good ol' days when I worked for a public bus manufacturer. *I'm curious now if we worked for the same company or the competition. *Feel free to PM me to resolve that issue. *;)
I don't think we've worked for the same company, since this one is located in Europe.
That being said, having developed some of the documentation for the manufacturing processes, I did much of it with a cross-fuctional team. *I trusted THEM to be the experts and my role was simply to facilitate the process. *Could you do the same?
The failure modes listed in the OP are verified with them. We are not sure if we are doing it right like this.
N PFMEA repetitive failure modes in subsecuent stations. FMEA and Control Plans 1
J How to look up Failure Modes on FDA website FMEA and Control Plans 4
A Repairable System Reliability Analysis: Uptime/Downtime Hours, Failure Modes Data Reliability Analysis - Predictions, Testing and Standards 2
R 5% to 95% Non-Condensing Humidity Storage Test Conditions and Failure Modes APQP and PPAP 2
T Red Rabbits with Multiple Failure Modes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
V Failure Modes of 1-step being taken as cause in 2nd (subsequent/downstream) step FMEA and Control Plans 4
I Primary Failure Modes in a Production Line - Pls help a new member FMEA and Control Plans 5
V Common Failure Modes for a Product/Process Line ISO 14971 - Medical Device Risk Management 1
V Examples for failure modes of Design & Process FMEAs FMEA and Control Plans 5
K MIG Welding Failure Modes and PFMEA Sample Needed ASAP FMEA and Control Plans 10
V Failure Modes & Causes in dFMEA & pFMEA FMEA and Control Plans 3
K Developing a PFMEA - Confused about Potential Failure modes FMEA and Control Plans 7
J Maintenance FMEA to address machine failure modes FMEA and Control Plans 2
M PAA (Process Assurance Assessment) vs. FMEA (Failure Modes and Effects Analysis) FMEA and Control Plans 3
Q FMEA (Failure Modes and Effects Analysis) and Control Plan Process Diagrams FMEA and Control Plans 3
C Microscope Failure Modes and Horror Stories ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
N Definition Potential Failure Mode Definition and How to identify Failure Modes? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 33
T Failure Modes on Fluke products? General Measurement Device and Calibration Topics 10
C Does anyone have a Template of Failure Modes for Machining Operations? FMEA and Control Plans 4
T Failure Modes for Machine Set-up/Production Dimensional Checks FMEA and Control Plans 2
N Attr. R&R for subjective visual insp w/ multiple failure modes Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
J What determines the contents of an FMEA (Failure Modes and Effects Analysis)? FMEA and Control Plans 12
N PFMEA on lean tools - Failure modes of a PFMEA of the tool "implementation process", FMEA and Control Plans 6
M Family or individual PFMEA's (process failure modes effects analysis)? FMEA and Control Plans 3
A I have two doubts about PFMEA failure modes - How should I describe a "failure mode" FMEA and Control Plans 24
G PFMEA failure modes for Process Function of Inspection/test FMEA and Control Plans 10
Manix Failure Modes that are Solved by actions already in place! FMEA and Control Plans 7
A FMEA - How can I identify all the possible modes of failure? FMEA and Control Plans 16
I ISO 9001 Registration Audit coming soon - What Have I Missed? Failure modes? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
T Standard Causes of Registration Audit Nonconformances and Typical Failure Modes IATF 16949 - Automotive Quality Systems Standard 5
Marc TS 16949 Registrar Audit Failure Modes General Auditing Discussions 48
S Common "misses" (Failure Modes) in Initial TS 16949 Upgrade Audit IATF 16949 - Automotive Quality Systems Standard 3
T Program of the Day - Lifecycle and Failure Modes of 'Improvement' Programs Philosophy, Gurus, Innovation and Evolution 10
Marc AS 9100 Registrar Audits: Failure Modes General Auditing Discussions 27
Marc ISO 14001 Registrar Audits: Failure Modes General Auditing Discussions 4
T Process FMEA (Failure Modes Effects Analysis) Severity Rating and RPN IATF 16949 - Automotive Quality Systems Standard 17
A ISO 9001 Registrar Audits: Failure Modes General Auditing Discussions 27
J Seeking: FMEA (Failure Modes Effects Analysis) Training Advice Training - Internal, External, Online and Distance Learning 10
Y FMEA Ranking and Prioritization - Failure Modes with higher severity first? FMEA and Control Plans 21
A Seeking Ideas: Raw Material Storage Process Failure Modes FMEA and Control Plans 3
N Why do 'we' and ?our? QMS?s stop working? What are the Failure Modes? Misc. Quality Assurance and Business Systems Related Topics 62
T Seeking: FMEA (Failure Modes and Effects) Info FMEA and Control Plans 1
J FMEA Software to develop P&D Failure Modes Effects Analysis Quality Assurance and Compliance Software Tools and Solutions 12
M Test failure Root cause not found Customer Complaints 10
T Risks of failure to meet intended use ISO 14971 - Medical Device Risk Management 6
P Missing 1m visual alarm signal in case of software/display failure, mitigation? ISO 14971 - Medical Device Risk Management 3
D Failure rate vs hazard rate vs rate of failure Reliability Analysis - Predictions, Testing and Standards 2
silentmonkey How to measure severity if my product is designed for emergency use and failure would result in death? ISO 14971 - Medical Device Risk Management 9
