Failure nets - Same level effects
Cephissus
Dear all, I would love your opinion once again on this situation.
Let's imagine a simple Actuator made of a Motor and a PCBA.
So that the Actuator Moves until it hits a hardstop, the PCBA should Switch-on & switch-off when motor stalls, while the motor should transform electrical power into rotation.
Now of course if the motor fails, like if it "Doesn't transform elec. power..." the actuator fails as it "doesn't move"
Likewise, if the PCBA "Doesn't Switch-off", the Actuator "Doesn't stop moving when hitting hardstop"
But here comes the issue, if the PCBA "Doesn't Switch-off", the motor will also get burnt, and it will therefore have the same failure as "Doesn't transform elec. power..." so that ultimately, the actuator fails too as it "doesn't move".
Now I wouldn't net the Motor failure as an effect to the PCBA failure, since they are on the same level and that would violate the Structural Integrity, so I normally net the failure of the PCBA directly to the Actuator failure, but one of my colleagues raised doubts on this. How do you handle this situation?
M Braided Tube Twisted Failure Mode - looking for advice Other Medical Device and Orthopedic Related Topics 2
qualprod Subsequent failure can also be a root cause? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
M Bourdon gauge calibration procedure failure ISO 17025 related Discussions 3
H Microbiology count test failure Other Medical Device Related Standards 1
B Package integrity Testing failure ISO 13485:2016 - Medical Device Quality Management Systems 7
J 'Failure rate leading to false-negatives and repeat testing' - MDCG and Common Tech Specs Other Medical Device Regulations World-Wide 0
S Sterile Disposable Cardiac Guidewire 3yr Real Time Sterility Failure When Confirming Accelerated Aging / Labeling US Medical Device Regulations 3
M How to show the effect of the failure mode on the manufacturing process as a customer of product design process? FMEA and Control Plans 3
B EO Production Batch Failure ISO 13485:2016 - Medical Device Quality Management Systems 1
S Reliability issue - Frequent component failure of the product Reliability Analysis - Predictions, Testing and Standards 2
Vader22 5 Why RCA for failure to test Contingency Plan IATF 16949 - Automotive Quality Systems Standard 9
S Die casting failure Manufacturing and Related Processes 9
N Failure Analysis-Potting Gel and Sealants Manufacturing and Related Processes 1
J NCR- Failure of contract review process - NADCAP audit AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
M Test failure Root cause not found Customer Complaints 10
T Risks of failure to meet intended use ISO 14971 - Medical Device Risk Management 6
P Missing 1m visual alarm signal in case of software/display failure, mitigation? ISO 14971 - Medical Device Risk Management 3
D Failure rate vs hazard rate vs rate of failure Reliability Analysis - Predictions, Testing and Standards 2
silentmonkey How to measure severity if my product is designed for emergency use and failure would result in death? ISO 14971 - Medical Device Risk Management 9
C Corrective action for failure in documents control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
T Root Cause Failure Analysis - Not following Customer packaging Specification Problem Solving, Root Cause Fault and Failure Analysis 9
A Exact terms for a plating failure and difference between rejection rate and failure rate Manufacturing and Related Processes 9
JoCam Failure to test Class I medical device to IEC 60601-1-11 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
C Kaizen Events - Factors Affecting Failure Lean in Manufacturing and Service Industries 13
C Failure mode at 0h, vs. 1 year vs. 5 year... FMEA and Control Plans 8
R How to properly use Survival Analysis to predict time to machine failure Reliability Analysis - Predictions, Testing and Standards 0
D Testing to failure for design verification Reliability Analysis - Predictions, Testing and Standards 11
M Informational US FDA – Ethicon Recalls Circular Staplers for Insufficient Firing and Failure to Completely Form Staples Medical Device and FDA Regulations and Standards News 0
C Detection Action for Failure Effects - AIAG 4th Edition Layout FMEA and Control Plans 5
Marc NASA Says Oregon Company Metals Fraud Caused $700 Million Satellite Failure - 2019 World News 16
C PCBA Hardware Component different failure types - How to rate detection? FMEA and Control Plans 8
N PFMEA repetitive failure modes in subsecuent stations. FMEA and Control Plans 1
P Detection rating for a user (surgeon) related failure mode in DFMEA APQP and PPAP 3
J How to look up Failure Modes on FDA website FMEA and Control Plans 4
P Electronic component failure analysis turnaround time Reliability Analysis - Predictions, Testing and Standards 0
C Design for Assembly in DFMEA - Failure Effect of Sub-System(s) FMEA and Control Plans 5
Marc Server RAM Failure - 7 Dec 2018 Forum News and General Information 3
K Spot weld - Peel test failure Manufacturing and Related Processes 3
C Electrical Power Plant Supply failure in PFMEAs FMEA and Control Plans 10
kisxena Memo to File - Failure to Validate Supply Chain Security Management Systems 1
Y IEC 62304 Section 4.3(a) - 100% probability of failure IEC 62304 - Medical Device Software Life Cycle Processes 3
S FMEA column column ''therblig motion'' for a given potential failure FMEA and Control Plans 12
J What does "factional and failure dependencies“ mean? FMEA and Control Plans 1
N PFMEA Potential Failure Mode for Weight FMEA and Control Plans 5
P Root Cause for a Process Validation Batch Failure 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
M Infusion Pump Power Failure Alarm IEC 60601-2-24 IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
K Determining Effect of Failure without a DFMEA (Design FMEA) FMEA and Control Plans 1
R Will multi-time flashovers constitute a failure of Hi-Pot test? IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
