'Failure rate leading to false-negatives and repeat testing' - MDCG and Common Tech Specs
Can anyone help me understand this sentence please:
"as part of the required risk analysis the whole system failure rate leading to false-negative results shall be determined in repeat assays on low-positive specimens."
It appears in MDCG 2021-21 Rev.1 Guidance on performance evaluation of SARS-CoV-2 in vitro diagnostic medical devices and also COMMISSION DECISION of 27 November 2009.
CE marking of the SARS-CoV-2 device I am working on will be comply to ISO 14971 for risk assessment plus IVDR risk management but this particular sentence is in relaiton to performance testing. I can't work out if maybe means something like whats pulled out of the risk analysis should dictate the performance testing design or something else?
D Failure rate vs hazard rate vs rate of failure Reliability Analysis - Predictions, Testing and Standards 2
A Exact terms for a plating failure and difference between rejection rate and failure rate Manufacturing and Related Processes 9
C PCBA Hardware Component different failure types - How to rate detection? FMEA and Control Plans 8
C Squeeze in one more - Rate of failure Statistical Analysis Tools, Techniques and SPC 6
M Population failure rate based on attribute data Statistical Analysis Tools, Techniques and SPC 4
N Medical Device Failure Rate as part of the Risk Management Report ISO 13485:2016 - Medical Device Quality Management Systems 10
B Quality Contracts with Clear Measures of Electronic Systems such as failure rate Quality Assurance and Compliance Software Tools and Solutions 5
F Reliability of a System - Estimation of R(t) having constant failure rate "Lambda" Reliability Analysis - Predictions, Testing and Standards 2
Q Why use AFactor in FRUR metrics - Monthly failure rate calculations TL 9000 Telecommunications Standard and QuEST 3
N What is a ?Reasonable? failure rate for an electronic device in the 1st year? Quality Tools, Improvement and Analysis 7
M Searching data for a reliability prediction - Calculating failure rate of an MCU Reliability Analysis - Predictions, Testing and Standards 1
B Package integrity Testing failure ISO 13485:2016 - Medical Device Quality Management Systems 6
S Sterile Disposable Cardiac Guidewire 3yr Real Time Sterility Failure When Confirming Accelerated Aging / Labeling US Medical Device Regulations 3
M How to show the effect of the failure mode on the manufacturing process as a customer of product design process? FMEA and Control Plans 3
B EO Production Batch Failure ISO 13485:2016 - Medical Device Quality Management Systems 1
S Reliability issue - Frequent component failure of the product Reliability Analysis - Predictions, Testing and Standards 0
Vader22 5 Why RCA for failure to test Contingency Plan IATF 16949 - Automotive Quality Systems Standard 9
S Die casting failure Manufacturing and Related Processes 9
N Failure Analysis-Potting Gel and Sealants Manufacturing and Related Processes 1
J NCR- Failure of contract review process - NADCAP audit AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
M Test failure Root cause not found Customer Complaints 10
T Risks of failure to meet intended use ISO 14971 - Medical Device Risk Management 6
P Missing 1m visual alarm signal in case of software/display failure, mitigation? ISO 14971 - Medical Device Risk Management 3
silentmonkey How to measure severity if my product is designed for emergency use and failure would result in death? ISO 14971 - Medical Device Risk Management 9
C Corrective action for failure in documents control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
T Root Cause Failure Analysis - Not following Customer packaging Specification Problem Solving, Root Cause Fault and Failure Analysis 9
JoCam Failure to test Class I medical device to IEC 60601-1-11 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
C Kaizen Events - Factors Affecting Failure Lean in Manufacturing and Service Industries 13
C Failure nets - Same level effects FMEA and Control Plans 0
C Failure mode at 0h, vs. 1 year vs. 5 year... FMEA and Control Plans 8
R How to properly use Survival Analysis to predict time to machine failure Reliability Analysis - Predictions, Testing and Standards 0
D Testing to failure for design verification Reliability Analysis - Predictions, Testing and Standards 11
M Informational US FDA – Ethicon Recalls Circular Staplers for Insufficient Firing and Failure to Completely Form Staples Medical Device and FDA Regulations and Standards News 0
C Detection Action for Failure Effects - AIAG 4th Edition Layout FMEA and Control Plans 5
Marc NASA Says Oregon Company Metals Fraud Caused $700 Million Satellite Failure - 2019 World News 16
N PFMEA repetitive failure modes in subsecuent stations. FMEA and Control Plans 1
P Detection rating for a user (surgeon) related failure mode in DFMEA APQP and PPAP 3
J How to look up Failure Modes on FDA website FMEA and Control Plans 4
P Electronic component failure analysis turnaround time Reliability Analysis - Predictions, Testing and Standards 0
C Design for Assembly in DFMEA - Failure Effect of Sub-System(s) FMEA and Control Plans 5
Marc Server RAM Failure - 7 Dec 2018 Forum News and General Information 3
K Spot weld - Peel test failure Manufacturing and Related Processes 3
C Electrical Power Plant Supply failure in PFMEAs FMEA and Control Plans 10
kisxena Memo to File - Failure to Validate Supply Chain Security Management Systems 1
Y IEC 62304 Section 4.3(a) - 100% probability of failure IEC 62304 - Medical Device Software Life Cycle Processes 3
S FMEA column column ''therblig motion'' for a given potential failure FMEA and Control Plans 12
J What does "factional and failure dependencies“ mean? FMEA and Control Plans 1
N PFMEA Potential Failure Mode for Weight FMEA and Control Plans 5
