Failure Rates and Standard Acceptable Quality Level for Incoming Components
MattRamsle
Does anyone know a standard Acceptable Quality Level for incoming device components? Our contract manufacturer assembles an electronic handpiece for us, but when we test them, we find that at least 10% of them fail. I’d like to negotiate an acceptable number of nonconforming components from my supplier, but wanted a benchmark to start from.
John Nabors - 2009
Re: Failure Rates for Incoming Components
Matt-
Most of my prior experience has been in automotive and defense and they are very different cultures. In automotive, zero defects were a way of life and at that company (large multinational Tier II), suppliers were expected to maintain PPM's as follows:
'Green' supplier (dock to stock): 0-25 PPM
'Yellow' supplier (normal sampling inspection required): 26-500 PPM
'Red' supplier (tightened sampling inspection required): 501-2500 PPM
'Unacceptable' supplier (discontinue use): 2501+ PPM
A discontinued supplier could slither their way back into our good graces by giving us really, really good 8-D's and then going back to square one of the supplier approval process.
It was different with the military contractors. Both only had suppliers of metals to worry about (about 98% was steel and titanium bar stock, the remainer was oddball stuff like aluminum extrusions) so most of the inspection activity was in-process and final acceptance, not SQD. Defense procurement designated all features as either Critical, Major, Minor, or Unlisted and we had to inspect (in the presence of a DOD procurement specialist, called a 'DCAS') to the old MIL-STD105E (now ANSI/ASQ Z1.4-2003) with the following criteria:
Critical: 100% inspection
Major: 0.65 AQL, Level II
Minor: 4.0 AQL, Level II
Unlisted: Did not require final inspection
But every organization needs to make their own risk/cost analysis and come up with their own 'comfort zone' for supplier quality.
Did any of that blather help?
Regards -John
MattRamsle
Thanks John, that gives me a bit of a starting point. This particular supplier is the only one that would touch this job, so we're a little more flexible with them than normal. But we still don't like losing any more money that necessary.
CK lau
Hi! Dear,
Can anyone provide me a table of ANZI 1.4 ? What's the different between ANZI 1.4 & Mil Std 105e?:rolleyes:
Thank you
CK:agree1:
harry
Hi! Dear,
Thank you
CK:agree1:
ANZI 1.4 is protected by copyright and is the civilian equivalent of Mil Std 105e. According to some of our covers, there are some minor differences. See this link, especially post#7.
Welcome to the cove CK.
S Are P-Charts OK to use for LOW failure rates? Statistical Analysis Tools, Techniques and SPC 10
F Calculation of Failure - Constant Failure Rates of Parallel System Reliability Analysis - Predictions, Testing and Standards 11
J Seeking Excel Spreadsheet to help with cycle test for Weibull failure rates Excel .xls Spreadsheet Templates and Tools 2
M Test failure Root cause not found Customer Complaints 10
T Risks of failure to meet intended use ISO 14971 - Medical Device Risk Management 6
P Missing 1m visual alarm signal in case of software/display failure, mitigation? ISO 14971 - Medical Device Risk Management 3
D Failure rate vs hazard rate vs rate of failure Reliability Analysis - Predictions, Testing and Standards 2
silentmonkey How to measure severity if my product is designed for emergency use and failure would result in death? ISO 14971 - Medical Device Risk Management 9
C Corrective action for failure in documents control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
T Root Cause Failure Analysis - Not following Customer packaging Specification Problem Solving, Root Cause Fault and Failure Analysis 9
A Exact terms for a plating failure and difference between rejection rate and failure rate Manufacturing and Related Processes 9
JoCam Failure to test Class I medical device to IEC 60601-1-11 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
C Kaizen Events - Factors Affecting Failure Lean in Manufacturing and Service Industries 13
C Failure nets - Same level effects FMEA and Control Plans 0
C Failure mode at 0h, vs. 1 year vs. 5 year... FMEA and Control Plans 8
R How to properly use Survival Analysis to predict time to machine failure Reliability Analysis - Predictions, Testing and Standards 0
D Testing to failure for design verification Reliability Analysis - Predictions, Testing and Standards 11
M Informational US FDA – Ethicon Recalls Circular Staplers for Insufficient Firing and Failure to Completely Form Staples Medical Device and FDA Regulations and Standards News 0
C Detection Action for Failure Effects - AIAG 4th Edition Layout FMEA and Control Plans 5
Marc NASA Says Oregon Company Metals Fraud Caused $700 Million Satellite Failure - 2019 World News 16
C PCBA Hardware Component different failure types - How to rate detection? FMEA and Control Plans 8
N PFMEA repetitive failure modes in subsecuent stations. FMEA and Control Plans 1
P Detection rating for a user (surgeon) related failure mode in DFMEA APQP and PPAP 3
J How to look up Failure Modes on FDA website FMEA and Control Plans 4
P Electronic component failure analysis turnaround time Reliability Analysis - Predictions, Testing and Standards 0
C Design for Assembly in DFMEA - Failure Effect of Sub-System(s) FMEA and Control Plans 5
Marc Server RAM Failure - 7 Dec 2018 Forum News and General Information 3
K Spot weld - Peel test failure Manufacturing and Related Processes 3
C Electrical Power Plant Supply failure in PFMEAs FMEA and Control Plans 10
kisxena Memo to File - Failure to Validate Supply Chain Security Management Systems 1
Y IEC 62304 Section 4.3(a) - 100% probability of failure IEC 62304 - Medical Device Software Life Cycle Processes 3
S FMEA column column ''therblig motion'' for a given potential failure FMEA and Control Plans 12
J What does "factional and failure dependencies“ mean? FMEA and Control Plans 1
N PFMEA Potential Failure Mode for Weight FMEA and Control Plans 5
P Root Cause for a Process Validation Batch Failure 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
M Infusion Pump Power Failure Alarm IEC 60601-2-24 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
K Determining Effect of Failure without a DFMEA (Design FMEA) FMEA and Control Plans 1
R Will multi-time flashovers constitute a failure of Hi-Pot test? IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
P IATF 16949 - 10.2.5 Warranty and 10.2.6 Field failure IATF 16949 - Automotive Quality Systems Standard 1
J Medical Device Failure Effects - Where to draw the line? FMEA and Control Plans 8
kedarg6500 Potential Effects of Failure(s) FMEA and Control Plans 23
Marc Definition PFH - Probability of dangerous failure per hour Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
Marc Definition PFD - Probability of failure on demand Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
C Squeeze in one more - Rate of failure Statistical Analysis Tools, Techniques and SPC 6
L First Time Completing a 5 Why/RootCause Failure Analysis Nonconformance and Corrective Action 8
Z Failure Mode Identification in PFMEA according to AIAG FMEA Rev.4 FMEA and Control Plans 6
B IPCD Sterility test failure during MPQ (EO sterilization validation) ISO 13485:2016 - Medical Device Quality Management Systems 2
A Failure Mode from Operator "Components Fallen but Loaded" FMEA and Control Plans 3
