False Pass/Fail Information from GR&R (Gage R&R) Minitab
K
kornfind
My question is based on interpreting Minitab data with GR&R being done for production process improvement.
We run PCBs on Automated Test Systems with a number of parameters being tested. For instance, for voltage measurements, I have a tolerance value, a measured value and an expected value.
I read in some earlier posts that I should consider the %Tolerance value off the Minitab GRR report? Is that right?
Also, can I extrapolate false Passes and false failures from a GR&R study? If yes, how? If no, is there any other SPC method I should consider to find False Passes and False Failures' percentage?
Thanks,
BE
Provided your test equipment is used for inspection, you should use % Tolerance.
The answer to your second question is yes. You can create a gauge performance curve as shown in the AIAG manual. The file attached to my blog will create this curve.
Allattar
There is an option, under the Gage R&R options that on entering specification limits, you can ask for probabilities of misclassification.
This should be the values you are looking for. (without the curves :) )
K
kornfind
Hi Miner,
Thanks but I couldn't find any direct info that tells me some X% False Pass and X% of False Failures. How do I get that info especially from the Minitab data report generated as in the attached file.
Appreciate your help.
Thanks,
BE
  • Minitab Analysis.docx
Allattar
If you are using 15 or 16 it should be in the gage R&R options to display probabilities of misclassification. You can select this on entering spec limits.
In Minitab, select Stat > Quality Tools > Gage Study > Gage R&R Study (Crossed) > Options. Select "Enter at least one specification limit", and check the "Display probabilities of misclassification" box.
The session window with display Joint and Conditional probabilities.
  • Joint probabilities assume no prior knowledge of whether the product inspected is good or bad.
  • Conditional probabilities assume prior knowledge. This means you are either sampling from a pile of rework or previously inspected and accepted product.
K
kornfind
All,
Thanks that helped. I have a couple more related questions,
1. What does the * mean under Probablilities of Misclassification?
Example: Conditional Probability
False Accept *
False Reject 0.537
2. What does "Degenerate bivariate detected: The variance-covariance matrix has
determinant = 0. Unable to proceed" mean? I get this at times under Probablilities of Misclassification?
Thanks for all the help
KF
J 'Failure rate leading to false-negatives and repeat testing' - MDCG and Common Tech Specs Other Medical Device Regulations World-Wide 0
J Customer Complaint & SCAR, false data Nonconformance and Corrective Action 14
JoCam False information provided for Medical Device Registration - What are the implications? Other Medical Device Related Standards 3
D Attribute Agreement Analysis - MSA - False Negative/Positive IATF 16949 - Automotive Quality Systems Standard 3
K False Alarms - Residual Risks or New Risk? ISO 14971 - Medical Device Risk Management 4
P CBs are not permitted to certify to AS9100 Rev C until 2011? True or False? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 18
S True or False - The operating procedures have nothing to do with the QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
P MSA Attribute Studies - Calculate Cross Tabs, Effectiveness, Miss Rate, False Alarm Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
N Effectiveness, miss rate and false alarm rate - Need formulas to calculate Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Wes Bucey FAA licensed pilots submit false medical reports Federal Aviation Administration (FAA) Standards and Requirements 4
P Miss rate & False Alarm Rate - What are they and how are they calculated? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D False Certification and Collusion? Registrars and Notified Bodies 16
G Test Plan - Pass/Fail Criteria for TR 60601-4-2 Other Medical Device Related Standards 0
C Does a Pass or Fail IP test need UoM on the report? Measurement Uncertainty (MU) 0
T First Pass Yield (FPY) of a Manufacturing Site? Manufacturing and Related Processes 11
H Is it a requirement for run charts to have inspection data or can it have just a pass/fail check mark Records and Data - Quality, Legal and Other Evidence 4
M Customer PPm (CPPM) on Pass-Thru Items Statistical Analysis Tools, Techniques and SPC 0
H Pin Gauges - tight fit = pass or fail? Reliability Analysis - Predictions, Testing and Standards 9
C Pass through characteristics on PFMEA FMEA and Control Plans 3
E Calibration-Conditional Pass Measurement Uncertainty (MU) 2
B Lowest cost way to pass Lead Auditor exam ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Is using ANSI/ASQ Z1.4-2008 the correct sampling plan to determine Pass/Fail of Apparel measurements? AQL - Acceptable Quality Level 8
Crimpshrine13 IATF 16949 and ISO 9001 Remote Support - Pass Through Inventory IATF 16949 - Automotive Quality Systems Standard 20
A IATF certification for pass through supplier IATF 16949 - Automotive Quality Systems Standard 1
S How can a R&D center pass IATF 16949 certification? IATF 16949 - Automotive Quality Systems Standard 9
J AMS 2750 E Clause3.5.17.13 TUS Pass/Fail Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Z Inspection Form With Pass/Fail Formula Excel .xls Spreadsheet Templates and Tools 11
B Best place is to purchase IEC 60417 labels that will pass markings test IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
D Supplier Scorecard, Assessment of Pass Through Items From Sub Tier Suppliers Supplier Quality Assurance and other Supplier Issues 4
K UL 6601 - Would an off-the-shelf Android tablet, powered by USB, pass UL 6601? Other Medical Device Related Standards 3
Q Can a fail still be a pass? (Criteria Level B for 61000-4-6 Conducted Immunity) IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M What CQA Preparation Material helped you to pass the exam? Career and Occupation Discussions 6
I Device Can't Pass IEC 60601-2 ESD Requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
B What is the implication for someone who does not meet the 70% pass mark for QMS-Lead. Professional Certifications and Degrees 2
T First Pass Yield - Welding Process Improvement Manufacturing and Related Processes 3
C Difference between "Pass/Fail Testing" "Test To Failure" "Degradation Test" FMEA and Control Plans 1
Z Pass-Though Characteristics in PFMEA (Process FMEA) FMEA and Control Plans 2
B How to begin tracking FPY (First Pass Yield) and "Downtime" tracking Manufacturing and Related Processes 3
S ISO 9001:2008 Sec 7.6 - Can we just log measurement devices as 'Pass/Fail'? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 118
B Calculation of First Pass Yield (FPY) Six Sigma 9
S Verify Software System Testing: Verify that results meet the Pass/Fail Criteria IEC 62304 - Medical Device Software Life Cycle Processes 1
J Reliability Prove-out, Pass-Fail Testing Reliability Analysis - Predictions, Testing and Standards 2
I Supplier Using Reference Part for PASS/FAIL Inspection Supplier Quality Assurance and other Supplier Issues 8
G How much time must pass after the first Certification Audit for us to appear in OASIS AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
L Definition Throughput Yield (TPY) or First Pass Yield Calculation - Help Needed Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
N VDA 6.x - Requirements Pass Down to Suppliers ....Obliged?? VDA Standards - Germany's Automotive Standards 5
Hami812 Gage R&R on Automated Tool that supports Pass/Fail and some Parametric Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
J Contractor Pass required for Contract Cleaners? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Hami812 Gage R&R Process Method - Pass/Fail Criteria Offered to Operators vs. Parametric Data Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
G Hoffman Scratch Hardness Test - General Parameters for Pass/Fail (Paint Coatings) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
