FDA Aspects - No Improvements to 12 Year Old Software
new_to_this
Before I start this job for this company there was a person pretty much put on CMM without any experience and started learning on his own and started writing programs. I give him lots of credits because it's not easy to start learning PCDMIS. Now 4 years later we run same jobs again and they want me to run same programs. I know they are wrong they need to be rewrote from scratch, but I can?t do anything about it because I guess per FDA, improvements are not on the menu. Even myself I would never run programs that I wrote 12 years ago because I know I made some unintentional mistakes and as I learned on my mistakes I improved my programming skills with over13 years experience.
How do I run programs that I know are not correct? Any suggestions, what to do? I would appreciate your inputs. Thanks!!!
yodon
Why would you say "per FDA, improvements are not on the menu"?
My next question is why do you think the programs written 12 years ago are bad? What's specifically not correct?
It may well be the case that they are wrong but just because they're 'old' doesn't mean they're wrong.
Presumably, your company should have some kind of change management process - either through the CAPA system or otherwise. You should be able to raise the issue through whatever mechanism that is and take necessary corrections.
new_to_this
Yodon,
First I would like clarify something. My original topic was: "FDA no improvements?"
I don't know how and who edited "FDA no improvement for 12 Year Old Software".
I never said that programs written 12 years ago are bad. I said it as an example if I have to run programs that I wrote 12 years ago I would rewrite them now because I learn a lot since then and i am sure I made some unintentional mistakes that time.
You can write program and because it will run it doesn't mean is correct.
You can write manual program with all kind of manual hits and all kind of incorrect alignments, it's still program. And you can write fully DCC mode with correct alignments and that is program too.
Programs that I am talking about are incorrect because alignments are wrong, scanning is wrong, labeling is wrong etc. Programs were never validated.
As far as improvements I was told that per FDA regulations you are not required to show improvements like ISO 17025, that’s the reason I put question mark on the and of the topic-"FDA no Improvements?".
Even if the program is correct but if you can make improvements to eliminate operator error and reduce the run time, reduce the set up time and still correlate with different measuring methods why you still have to use the old program?
I thought there is maybe way that we can write our own procedure to eliminate all the waiting from request to program change and getting all the signitures...etc. Thanks for your reply I greatly appreciate it.
yodon
The QSR (21 CFR 820) does include "CAPA" so preventive actions / improvements are definitely covered. There does come a point where business decisions have to be made. Will the benefits gained from the improvements (both business and patient safety considered) outweigh the cost of making the improvements? To make such changes would require (most likely) a re-validation of that system so it's by no means a simple process. If, for example, you prevent 1 error in 1 million and that error is caught in subsequent inspections AND the error poses no risk to patient safety then it's probably not worth it. If, though, the change prevents an otherwise undetected error that could pose a risk to human safety in the field, then actions are probably warranted.
I would suggest that you elevate it to the management team, indicating what errors would be prevented and the benefits of making the change. Now if the management team is not receptive to considering the idea, you may have bigger issues. :) Good luck!!
A FDA guidance on non-sterile Medical Device Packaging Medical Device and FDA Regulations and Standards News 4
JoCam FDA Registration for Sub-contract manufacturers Medical Device and FDA Regulations and Standards News 2
M FDA News FDA Releases Draft Guidance Clarifying Application of ISO 10993-1 Biocompatibility Standard Medical Device and FDA Regulations and Standards News 0
E Contract manufacturer FDA requirements foreign company US Food and Drug Administration (FDA) 6
P Choice of FDA reviewer US Food and Drug Administration (FDA) 6
J Is Device Tracking Card an actual requirement under FDA regulation? Other US Medical Device Regulations 0
T Definition Human Use (FDA) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 7
K FDA 510k electrosurgery 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
J Leveraging FDA 510k Clearance for International Registrations Other Medical Device Regulations World-Wide 2
shimonv FDA News FDA guidance on Multiple Function Device Products (8/2020) Other US Medical Device Regulations 1
N FDA UDI - Label vs. Labeling - Does the insert need to include UDI? Other US Medical Device Regulations 0
J FDA notification of address change US Food and Drug Administration (FDA) 2
N Usability testing required for FDA IDE (investigational device exemption)? Human Factors and Ergonomics in Engineering 3
A FDA Class Classification for a cabinet 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
L FDA Biocompatibility Requirements - Transitory Contact Other US Medical Device Regulations 1
Edward Reesor FDA DM and /or Class I Life Saving US Food and Drug Administration (FDA) 0
Watchcat FDA will not tolerate fraud…meaning what, exactly? Other US Medical Device Regulations 6
K FDA Premarket Cybersecurity Guidance - 4 questions Other US Medical Device Regulations 5
gunnyshore Form FDA 3500A MedWatch eSubmitter 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
Watchcat FDA Webinar Series - N95 Respirators Other US Medical Device Regulations 0
M Off-Label Use - Clarification of FDA Policy US Food and Drug Administration (FDA) 1
J Sub-supplier change from manual to automated process - same specs - Report to FDA? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
C FDA Establishment registration - Buying some medical devices from another manufacturer Medical Device and FDA Regulations and Standards News 5
I How to classify a medical device based on FDA? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
dinaroxentool Question about FDA Classification of a Device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
S The US FDA requirements on Disposal of a medical device US Food and Drug Administration (FDA) 1
S FDA Requirements for Medical Device Label Reconciliation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
S What is considered a "core algorithm"? (From an FDA guidance document) Medical Information Technology, Medical Software and Health Informatics 4
B FDA-Medical Device Reporting (MDR )procedure compliant with 21CFR section 803 US Food and Drug Administration (FDA) 0
Stoic Are any medical device companies using the 2011 FDA process validation guidance instead of GHTF/SG3/N99-10:2004? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
D ISO 13485, FDA 21 CFR 820 and Auditing the Accounting Department ISO 13485:2016 - Medical Device Quality Management Systems 5
S FDA's E submitter - For clinical electronic thermometer Medical Device and FDA Regulations and Standards News 6
J FDA wants electrical safety testing on battery powered medical device US Food and Drug Administration (FDA) 11
A FDA and NB audit of Engineering Drawings in DHF and DMR. Medical Device and FDA Regulations and Standards News 1
D FDA De Novo Cover Letter - What is expected US Food and Drug Administration (FDA) 3
Ed Panek 21 CFR Part 820 - FDA Label Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
J Mislabeling - Consider this an FDA notified recall? CFR 806.10 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
O Hospital-Developed, In-House Device - FDA Clearance? Other US Medical Device Regulations 19
D FDA Approved Class II Medical Device? Other US Medical Device Regulations 11
R When does the FDA consider a component a medical device? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 17
N Risk Management besides mandated FDA requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M Informational US FDA – Ear, Nose, and Throat Devices; Classification of the Self-Fitting Air-Conduction Hearing Aid Medical Device and FDA Regulations and Standards News 0
L UDI Requirments Gap Analysis - EU MDR vs FDA CFR EU Medical Device Regulations 8
M Informational US FDA – Modifications to the List of Recognized Standards, Recognition List Number: 052 Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Draft Guidance – Breast Implants – Certain Labeling Recommendations to Improve Patient Communication Medical Device and FDA Regulations and Standards News 0
M Looking for third party reviewers for FDA submissions US Food and Drug Administration (FDA) 2
M Informational Work in progress at the FDA for biological evaluation – Color Hazard and RISk calculator (CHRIS) Medical Device and FDA Regulations and Standards News 0
M Informational US FDA – CDRH Proposed Guidances for Fiscal Year 2020 (FY 2020) Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Final Guidance – Coronary, Peripheral, and Neurovascular Guidewires – Performance Tests and Recommended Labeling Medical Device and FDA Regulations and Standards News 0
