FDA Definition of "Raw Material"
ryno fan
Does anyone know of FDA's definition of "raw material"?
Are there guidance documents or regulations applicable to raw material?
Is "raw material" in FDA terms, only applicable to drugs?
MIREGMGR
Re: FDA meaning of "raw material"
I'm not sure what your context or underlying question might be.
For devices, FDA does have Recognized Consensus Standards that define the chemical and physical nature and characteristics of a number of materials, which might be considered "raw materials".
insect warfare
QA=Question Authority
I think for drugs (instead of raw materials) they call it "API starting materials" (where the API stands for active pharmaceutical ingredient):
API Starting Materials: A raw material, intermediate, or an API that is used in the production of an API and that is incorporated as a significant structural fragment into the structure of the API. An API Starting Material can be an article of commerce, a material purchased from one or more suppliers under contract or commercial agreement, or produced in-house. API Starting Materials are normally of defined chemical properties and structure.
Active Pharmaceutical Ingredient: Any substance or mixture of substances indended to be used in the manufacture of a drug (medicinal) product and that, when used in the production of a drug, becomes an active ingredient of the drug product. Such substances are intended to furnish pharmacological activity or other direct effect in the diagnosis, cure, mitigation, treatment, or prevention of disease or to affect the structure or function of the body.
Reference: Manufacturing, Processing, or Holding Active Pharmaceutical Ingredients FDA Guidance
Brian :rolleyes:
ryno fan
Basically, we manufacture medical device software. We have vendors contracted to perform our coding and some testing. If the vendors are not producing a finished device (because we may add specs to it later to satisfy customer needs (as design changes), does raw material have anything to do with this? I am thinking raw material would only apply if they were actually building microchips for us or similar...
insect warfare
If you manufacture medical device SW, and you outsource the code and testing through approved vendors, they are actually supplying you with a tested component, which are the software bundles. I don't know your operation, but are you also handling the medium which the software is imprinted onto, such as a disk? You may have another vendor who supplies you with those. Together these are all raw materials that go into a finished product, which (in this case) would be a disk that contains the specific SW configurations.
Brian :rolleyes:
ryno fan
Thanks Brian (insect warfare).
In your example, do "raw materials" have the same meaning as "component" in the FDA regulations?
And which FDA regulations apply to raw materials? (for example, 820.50 Purchasing Controls, 820.80 Receiving Acceptance) Others?
Are you aware of any guidance documents specific to controlling raw materials as in your example (software)?
Any help is appreciated.
(I find this forum of great value...) :applause:
insect warfare
In this context I think they do:
From 820.3c - (Definitions)
Component means any raw material, substance, piece, part, software, firmware, labeling, or assembly which is intended to be included as part of the finished, packaged, and labeled device.
Technically, raw materials could apply anywhere where the term “product” (or “components”) is used. You would need to sift through the 21CFR requirements and make those determinations of applicability.
Not to my knowledge. I did a Google search and could not find anything pertaining to my example, but I would re-read 21CFR 820.1 – (Scope) and 820.30a(2) – (Design Controls) for more information specific to your operation.
Brian :rolleyes:
revolution_2006
ryno fan,
As the prior posts indicated, software is certainly considered a component of a medical device (or a medical device on its own, as applicable) and therefore requires the same controls as applied elsewhere in your company for your medical device.
The control of the raw material/component, in your case outsourced software or software modules/ assessments, would fall under your general purchasing controls. The primary standards for software control would be defined within the FDA Harmonized standard ISO 62304, and the general principals of software validation guidance from the FDA, GHTF and other agencies, as applicable. Some of the ones I have utilized in the past few years include:
? 21 CFR 820.30, Quality System Regulation, Design Control
? Design Control Guidance For Medical Device Manufacturers (March 11, 1997),
General Principles of Software Validation; Final Guidance for Industry and FDA Staff, January 11, 2002
? Guidance for the Content of Premarket Submissions for Software Contained in Medical Devices - Guidance for Industry and FDA Staff (05/11/2005)
Guidance for Off-the-Shelf Software Use in Medical Devices (09/09/1999)
? Applicable EU directive (i.e. 90/385/EEC Council Directive of June 20, 1990 relating to active implantable medical devices ? Active Implantable Medical Device Directive (as amended by directive 2007/47/EC, 21-Sep-2007, and previous)
? EN ISO 13485:2003 Medical devices - Quality management systems - Requirements for regulatory purposes
? ISO 14971:2007 ? Medical devices ? Application of risk management to medical devices
? EN 60601-1:2006/AC:2010 for Programmable Medical Software (?14)
? IEC 62304:2006 Medical device software ? Software life cycle processes
I would ensure that your supplier controls for the subcontractor are well defined. You may want to consider reviewing Appendix 2 of Guidance for Notified Bodies Auditing Suppliers to Medical Device Manufacturers for some important considerations to include in your contract with the outsourced partner that may help demonstrate adequate control during your next audit.
Raw material and software is also mentioned in the preamble for the QSR as a component. Anyway, just my :2cents:
O Clarifying FDA definition of "finished device" and “capable of functioning” 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
D Definition User Needs - Concrete definition for "User Needs" as required by the FDA Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
J FDA definition of a complaint - Customer orders spare parts 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
S Definition Medical Device Accessory - FDA Definition of Accessory Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 7
A "GMP Area" - FDA definition Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
S FDA Device Listing Question - "Each Device" Definition - 21 CFR Part 807 Other US Medical Device Regulations 4
D FDA Days - What is the FDA definition of FDA Days 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
AnaMariaVR2 Definition Test Site vs. Test Facility - FDA definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
M Risk Management in an FDA Context - Extended definition of "harm" 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
H Customer Complaint - FDA Definition of Complaint Other US Medical Device Regulations 9
M Do Package Inserts Meet the FDA Definition of Cut Labeling? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
L Definition Bench Test - Definition (in FDA context) and its difference with Clinical Study? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
C Definition Finished Medical Device - Definition of - FDA 21 CFR Part 820.1 Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 13
Z Definition Complaint - The FDA's definition of Complaint Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 12
S Transitional Adolescent A and B - "CDRH PREMARKET REVIEW SUBMISSION COVER SHEET FORM FDA 3514" Medical Device and FDA Regulations and Standards News 1
P MSDS for MVQ FDA White, Vinyl Methyl Silicone Rubber EU Medical Device Regulations 4
C RA (Regulatory Assurance) Training (FDA) looking for resources Training - Internal, External, Online and Distance Learning 5
E FDA 513(g) Cover Letter US Food and Drug Administration (FDA) 5
S Records - Do's and don't' of record entries (FDA - 21 CFR 820) Records and Data - Quality, Legal and Other Evidence 13
B New Facility register with FDA Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 4
J FDA regulation on decorative contact lenses Medical Device and FDA Regulations and Standards News 5
P Anyone have an Idea on UAE Medical device registeration- Class B with FDA only Other Medical Device Regulations World-Wide 0
F FDA classification for a mobile app Medical Information Technology, Medical Software and Health Informatics 3
Ed Panek IFU Contact Requirements - FDA and MDD/MDR US Food and Drug Administration (FDA) 1
O Any info on release date of FDA “Computer Software Assurance for Manufacturing and Quality System Software” document? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
P Writing a presubmission to the FDA prior to the De novo submission US Food and Drug Administration (FDA) 4
K FDA - Can we have more than 1 Initial Importer Medical Device and FDA Regulations and Standards News 4
K Two FDA questions regarding UDI (and potentially 803.52 MDR) Other US Medical Device Regulations 0
R Importers - For the FDA Registration/ Listing, is the CMO the importer? Medical Device and FDA Regulations and Standards News 6
Z Iterative development and FDA change requests IEC 62304 - Medical Device Software Life Cycle Processes 12
P FDA Approved Product Contact Parts ISO 13485:2016 - Medical Device Quality Management Systems 6
A FDA guidance on non-sterile Medical Device Packaging Medical Device and FDA Regulations and Standards News 7
JoCam FDA Registration for Sub-contract manufacturers Medical Device and FDA Regulations and Standards News 2
M FDA News FDA Releases Draft Guidance Clarifying Application of ISO 10993-1 Biocompatibility Standard Medical Device and FDA Regulations and Standards News 0
E Contract manufacturer FDA requirements foreign company US Food and Drug Administration (FDA) 6
P Choice of FDA reviewer US Food and Drug Administration (FDA) 6
J Is Device Tracking Card an actual requirement under FDA regulation? Other US Medical Device Regulations 0
T Definition Human Use (FDA) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 7
K FDA 510k electrosurgery 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
J Leveraging FDA 510k Clearance for International Registrations Other Medical Device Regulations World-Wide 2
