FDA MAUDE Medical Device Reporting Database Analytics
G
gudushi.kutushi
Dear Experts,
I am trying to do some research around effectiveness of running analytics on FDA Maude database for my organization. I have a statistical and analytical background, however my experience around Medical Devices is limited.
I stumbled upon this forum when I was researching online. I was honestly, amazed to find such intellectuals in one single place! and thought I will raise the question to this group.
* What type of analytics can an organization run on FDA Maude database ?
* Does FDA run analytics or mine the MAUDE data to help them capture signals, that flags that they need to go after an organization for Audit?
It would be great if someone can give me some direction, and I shall gladly appreciate it.
Thank you very much in advance!
Regards,
GK
SteveK
We have about a dozen device types which I have matched to the FDA/MAUDE three letter designations. Every month (latest month) I check if any (competitor) devices in these classifications have had alerts as part of my post market surveillance procedure/risk analysis. I also make a note of the total number alerts in that particular month (have to keep it just to ‘deaths’ to get an actual number). I keep a track on an Excel spreadsheet/workbook along with alerts from other regulatory bodies (MHRA, HC, bfarm, Afssaps etc). I also keep hyperlinks to the actual alerts. Certain simple patterns/problems can show up e.g. electrical components failure, misuse of a device, material failure, fire risk etc. In this way I will update my Risk Management File (ISO 14791) – new possible failure mode for a particular device (which you can show an auditor to demonstrate your surveillance skills!:)).:2cents:
Steve
robert.beck
I have downloaded the latest Maude data files from FDA website and put all of the data into a SQL database that is full-text searchable. I've used this for several searches; here is my opinion:
1) the data is not very clean. There are a lot of records that aren't very useful.
2) the reports are not consistent, so when I'm looking for one specific topic I have to use a variety of search terms, and winnow records over several iterations.
3) Because of the amount of data, and because this is the only publicly available data of its type, it could be useful, but would be much more useful if the data were coded and categorized beyond what is done by FDA.
4) Unfortunately, this database is not a complete dataset on the topic of adverse events - see FDA's disclaimers, which are:
"MAUDE may not include reports made according to exemptions, variances, or alternative reporting requirements granted under 21 CFR 803.19."
"MAUDE data is not intended to be used either to evaluate rates of adverse events or to compare adverse event occurrence rates across devices"
"Please be aware that reports regarding device trade names may have been submitted under different manufacturer names"
Two exemptions of the FOIA are applied to MAUDE: "Exemption 4, trade secrets and confidential business information; and exemption 6, personnel and medical files"
I don't know how FDA uses this data, but I think your points are valid - FDA probably monitors it somehow and could definitely use it to identify flags and signals.
yana prus
As SteveK mentioned, it is a very useful tool for the post marketing survelliance, and risk management update. I use it also in the design stage when I would like to identify the potential risks and failures of the device to be taken into account for risk analysis, user requirements and technical specification.
Once I thought to use the database to explore the reliability (incident rate analysis) of the competitors products. The problem is as Robert mentioned that adverse events from the MAUDE database cannot be used to determine the rate of adverse events for a particular product or to compare adverse event rates between products. Manufacturers submit reports according to their interpretation of regulatory requirements and event reportability. For example, global or USA companies might submit more MDRs than small sized/out of USA companies as a result of internal compliance policy. What one company would consider as reportable, might not be reportable in interpretation of other company for the same type of device. Moreover, submission of the report does not mean the device caused the adverse event.
Nice resource on the problems with MAUDE system can be found here:
http ://www. fda gov/downloads/MedicalDevices/NewsEvents/WorkshopsConferences/UCM283555.pdf - DEAD 404 LINK UNLINKED
it mentions other challenges for the search in the MAUDE system:
- Duplicate and triplicate entries (follow-up reports),
? Blank narrative entries,
? Duplicate MDR ID numbers,
? Reports filed through the Alternative Summary Report (ASR) System not consistently updated to MAUDE
FDA has created the TPLC - total product life cycle database that combines data from various CDRH databases (data sources like MAUDE) to present an integrated record of premarket and postmarket activity for medical devices. The TPLC database integrates data by procode, a three-letter code associated with a generic type of medical device.
here is the link to the TPLC dabase - you can perform the search according to the device name or product code: TPLC - Total Product Life Cycle
For specific product code you could see there the types of device problems and number of the problems reported according to each type.
Another important source of the information that might be useful for your research is FDA's report for one of specific types of product - you could see there the method for mining the MAUDE data and the Public Health Notification that was issued as results of large number of adverse event received, with recommendations how to mitigate the risks. http :// www .fda. gov/downloads/AdvisoryCommittees/CommitteesMeetingMaterials/MedicalDevices/MedicalDevicesAdvisoryCommittee/ObstetricsandGynecologyDevices/UCM270402.pdf - DEAD 404 LINK UNLINKED
Regarding the signals for the audit - in my experience, I'm aware of 1 FDA inspection where the reason for inspection was lack of correlation in number of the user facility reports with the number of the manufacturer reports for the same cases. For that specific company there were about 20 user facility reports with 0 manufacturers reports for these cases as MDRs to FDA and the only reason for the FDA inspection was to inspect how that company responses, investigates and decides on the reportability for MDRs.
V
vaneswh
hi,yana! Thanks for your response and I learned a lot. I have some questions:
How do you find duplicate records in MAUDE database?
Can you estimate the numbers of reports that FDA received each year?
I did some analytics recently and used the variable "event_key" to find duplicates, here's an overview of report numbers by each year:
year frequency
1900 1
1991 15
1992 3,098
1993 4,407
1994 11,200
1995 9,724
1996 31,361
1997 73,275
1998 58,248
1999 49,329
2000 49,956
2001 56,188
2002 64,981
2003 70,288
2004 75,672
2005 94,262
2006 115,137
2007 149,273
2008 156,651
2009 204,213
2010 252,193
2011 369,321
2012 415,393
2013 488,359
The result is a little weird that the report number is dramatically increasing,especially from 2008. So I doubt whether I did enough "pre-processing" of the database.
I'd like to hear your opinion or advice.Thanks again!
drewsky1
I am currently doing a Post Market Surveillance and am searching the FDA MAUDE database. It appears there may be duplicate and maybe triplicate entries for the same event. Can anyone advise if there is a way to identify within the individual reports if it is connected to another event without having to read sometimes 100 reports that come up? It doesn't appear that the "key" numbers assigned or date of event would distinguish them.
Thanks:thanks:
For those looking for
It can be found here:
At the wayback machine web site just search for the above URL. I would paste it here but for some crazy reason, it will not let me :-( sorry
  1. Search google for Wayback machine,
  2. On the site search for the above link,
    1. be sure to fix the link remove spaces and add a . between fda and gov: fda.gov
  3. Click on 2015
  4. Click on June 12 to see the pdf
S FDA terms - Adverse Events, Medical Device Reporting, MAUDE and Customer Complaints US Food and Drug Administration (FDA) 1
D Vigilance - Public database of Vigilance reports (similar to FDA MAUDE database)? Other Medical Device and Orthopedic Related Topics 1
J Sub-supplier change from manual to automated process - same specs - Report to FDA? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
C FDA Establishment registration - Buying some medical devices from another manufacturer Medical Device and FDA Regulations and Standards News 2
I How to classify a medical device based on FDA? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
dinaroxentool Question about FDA Classification of a Device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S The US FDA requirements on Disposal of a medical device US Food and Drug Administration (FDA) 1
S FDA Requirements for Medical Device Label Reconciliation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
S What is considered a "core algorithm"? (From an FDA guidance document) Medical Information Technology, Medical Software and Health Informatics 4
B FDA-Medical Device Reporting (MDR )procedure compliant with 21CFR section 803 US Food and Drug Administration (FDA) 0
Stoic Are any medical device companies using the 2011 FDA process validation guidance instead of GHTF/SG3/N99-10:2004? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
D ISO 13485, FDA 21 CFR 820 and Auditing the Accounting Department ISO 13485:2016 - Medical Device Quality Management Systems 5
S FDA's E submitter - For clinical electronic thermometer Medical Device and FDA Regulations and Standards News 6
J FDA wants electrical safety testing on battery powered medical device US Food and Drug Administration (FDA) 7
A FDA and NB audit of Engineering Drawings in DHF and DMR. Medical Device and FDA Regulations and Standards News 1
D FDA De Novo Cover Letter - What is expected US Food and Drug Administration (FDA) 3
Ed Panek 21 CFR Part 820 - FDA Label Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
J Mislabeling - Consider this an FDA notified recall? CFR 806.10 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
O Hospital-Developed, In-House Device - FDA Clearance? Other US Medical Device Regulations 19
D FDA Approved Class II Medical Device? Other US Medical Device Regulations 11
R When does the FDA consider a component a medical device? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 17
N Risk Management besides mandated FDA requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M Informational US FDA – Ear, Nose, and Throat Devices; Classification of the Self-Fitting Air-Conduction Hearing Aid Medical Device and FDA Regulations and Standards News 0
L UDI Requirments Gap Analysis - EU MDR vs FDA CFR EU Medical Device Regulations 8
M Informational US FDA – Modifications to the List of Recognized Standards, Recognition List Number: 052 Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Draft Guidance – Breast Implants – Certain Labeling Recommendations to Improve Patient Communication Medical Device and FDA Regulations and Standards News 0
M Looking for third party reviewers for FDA submissions US Food and Drug Administration (FDA) 2
M Informational Work in progress at the FDA for biological evaluation – Color Hazard and RISk calculator (CHRIS) Medical Device and FDA Regulations and Standards News 0
M Informational US FDA – CDRH Proposed Guidances for Fiscal Year 2020 (FY 2020) Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Final Guidance – Coronary, Peripheral, and Neurovascular Guidewires – Performance Tests and Recommended Labeling Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Final Guidance – Intravascular Catheters, Wires, and Delivery Systems with Lubricious Coatings – Labeling Considerations Medical Device and FDA Regulations and Standards News 0
T Clinical trial - Medical device product not cleared (without FDA approval) in a drug trial Other US Medical Device Regulations 9
W How Often Does FDA State Consultant Recommended in a Pharma WL? US Food and Drug Administration (FDA) 1
M Informational US FDA – URGENT/11 Cybersecurity Vulnerabilities in a Widely-Used Third-Party Software Component May Introduce Risks During Use of Certain Medical Dev Medical Device and FDA Regulations and Standards News 0
M Informational US FDA paper – Epidemiological Evidence on the Adverse Health Effects Reports in Relation to Mercury from Dental Amalgam: Systematic Literature Review Medical Device and FDA Regulations and Standards News 0
M Informational US FDA paper – Biological Responses to Metal Implants Medical Device and FDA Regulations and Standards News 0
V Presubmission FDA for 510k US Food and Drug Administration (FDA) 4
M Informational US FDA Draft Guidance – Clinical Decision Support Software Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Final and update guidances – Software Medical Device and FDA Regulations and Standards News 0
M Informational From Medtech Insight – QSR/ISO 13485 Harmonization Update: FDA Enforcement Discretion Likely When New Rule Stands Up; Draft Reg Coming By Year’s End; Medical Device and FDA Regulations and Standards News 0
F FDA-registration and inspection cost 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M Informational US FDA Draft Guidance – Providing Regulatory Submissions for Medical Devices in Electronic Format – Submissions Under Section 745A(b) of the Federal F Medical Device and FDA Regulations and Standards News 0
D Framing FDA Questions - Validation US Food and Drug Administration (FDA) 1
M Informational US FDA CDRH’s Health of Women Program Strategic Plan Medical Device and FDA Regulations and Standards News 0
M Informational US FDA – Frequently Asked Questions (FAQs) About the Accreditation Scheme for Conformity Assessment (ASCA) Pilot Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Draft Guidance – Patient Engagement in Design and Conduct of Medical Device Clinical Investigations Medical Device and FDA Regulations and Standards News 0
M Informational Several US FDA draft guidances, including some specific device guidances for the Safety and Performance Based Pathway Medical Device and FDA Regulations and Standards News 0
MDD_QNA How to deal with FDA after not reporting anything for several years Other US Medical Device Regulations 14
M Informational Device Shortages Update – The US FDA Announces Two New Innovation Challenges on Device Sterilization Medical Device and FDA Regulations and Standards News 0
M Informational FDA draft guidance – Safer Technologies Program for Medical Devices Medical Device and FDA Regulations and Standards News 0
